Control 5v SSR relay with ESP01 GPIO
Would it be possible to control a 5v SSR relay from my GPIO?
When I connect the rely it does not switch on seems voltage drops, while a common 1.2V pair of rechargeable batteries can operate the Relay easily.
When I measure the GPIO at High it provides 3.3V but when Relay is connected i'm left with 2 volt only.
Would it be possible to solve this?
I tried to use GND/RX as a relay - but the circuit is always closed, even at 0v, is there and easy way to use it like NO/NC so without a relay?
Cheers,
Happy Easter!
Cheers,
Happy Easter!
Re: Control 5v SSR relay with ESP01 GPIO
Connect the SSR over a transistor with a resistor at the basis. Maybe the ESP has not enough current at the output.
Current may be a factor here indeed, but you may also try to have a look at the schematic of the SSR.
As far as I know, they are very much like an optocoupler, which means there is a LED inside.
A LED should have a resistor in series or else it will draw too much current which will eventually destroy the LED.
The output a GPIO pin can give probably protected the LED, but if you power it via a battery you may damage it.
Would any transistor do? Do i also need to place a diode to protect the flow back?
How would ik be connecting the transistor i have 3.3v and gnd coming from the esp. The transistor has 3 legs so where does what go? Appreciate the help.
I’m not that familiar with electrical circuits.
Hemant.
Hemant.
What exact SSR do you use?
Maybe adding a simple resistor is enough
It is a ITA-gz1-gl 100049de62.
Hemant
Hemant
Sorry someone told me ssr, it is indeed complete coming from a sonoff basic board, as the sonoff itself is broken i was hoping to reuse it with my esp-01.
Hemant
Hemant
Hi Any updates on this?
So situation is as follws, I want to control W11-1a2ste 5v, thorugh GPIO, problem is when directly connecting it to the GPIO and ground the voltage drops to less then 2.7 volt which is minimum to operate.
Is there a workaround to fix this?
Hemant
Hemant
You can't conect a 5v relay direct to a ESP GPIO!
You need a transistor to boost the current, maybe you need also more then 3.3V to switch the relay.
A simply NPN transistor in common-emitter-circuit should do that.
Please check the Wiki.
There is a detailed description of relay types, advantages, disadvantages and so on.
How to connect relay types and relay boards to ESP-Chips is described in detail.
https://letscontrolit.com/wiki/index.ph ... cs:_Relays
thanx, trying:
I have a transistor: P45N02LD
Diode: 1N5406
20K resistor between GPIO and B
GND connected to E (coming from ESP01)
C connected to Diode >| other side to 5v
But relay is not clicking
hemant
Diode: 1N5406
hemant
P45N02LD is N-Mosfet. Or I'm wrong?
No B/C/E !
No B/C/E !
Correct also tried with B1204 with BCE.
I can see switching with my multimeter, but as soon as i attach the relay the voltage drops.
Hemant
Hemant
Users browsing this forum: Google [Bot] and 122 guests
