WT32-ETH01
Re: WT32-ETH01
How can i attempt to resolve that?
Re: WT32-ETH01
Not sure, I have to look into the code for this.
Re: WT32-ETH01
217 : Info : Connect to:
217 : Info : Ethernet
218 : Info : Eth Wifi mode: Ethernet ETH: PHY Typee: LAN8710 PHYAddr: 0 Eth Clock mode: External crystal oscillator MDC Pin: 16 MIO Pin: 17 Power Pin: -1
222 : Info : ETH Started
4223 : Info : ETH Connected
4224 : Info : firstLoopConnectionsEstablished
7230 : Info : ETH MAC: A4:CF:12:64:B3:8F IPv4: 10.0.1.44 (ESP-Easy) GW: 10.0.1.1 SN: 255.255.255.0 FULL_DUPLEX 100Mbps
Re: WT32-ETH01
Ah, so it does have its own crystal oscillator?
Yep, then you should set it to have one external
Re: WT32-ETH01
Yep. Just spotted it also..
The new lan8720 i put on has quite different look then old one. It is more round off whereas the old was very edgy, alot like these bga memory chips. Wasnt easy to get it on with a paint removal gun
- 6FDBCAAC-9725-49F9-B6A6-7C093D6D4B26.jpeg (2.96 MiB) Viewed 1828 times
- 9A82A939-5364-4CB8-A70E-73AAB967446B.jpeg (2.98 MiB) Viewed 1828 times
Re: WT32-ETH01
Wow, you removed it using a paint removal gun?
The LAN8710A does have 32 pads, while the LAN8720A has only 24 (25 if you count the GND at the bottom)
Difference between both is that the LAN8720A only supports RMII and no longer the older 4 wire version.
But since we only use that one, it doesn't matter to us.
Re: WT32-ETH01
Weapon of choice
- 67193D76-B3C3-4EFC-A2CD-C6322B022575.jpeg (3.93 MiB) Viewed 1820 times
Re: WT32-ETH01
Well I don't think I can do that with such a blower myself, so respect
Re: WT32-ETH01
Now could you aybe add the setting for the wESP32 in the code so there will also be a .bin which has directly the correct settings inside for other users that maybe also like the wESP32? despte its higher price its pretty well made thing with proper PoE power identification and galvnic isolation etc.
Re: WT32-ETH01
Please show me the settings you now use and I will add them.
Re: WT32-ETH01
Re: WT32-ETH01
is in the current release for ESP32 .bin which one can flasch to WT32-ETH1?
Or I need to create my own for WT32.
Re: WT32-ETH01
You can flash any esp32 eth build as long as your board uses LAN8710A or LAN8720A (or the tk<somewhat> board which I forgot the name)
Only thing is, you may need to configure the eth yourself by hand as we don't have a predefined "factory default" setting for it yet.
Re: WT32-ETH01
Everything works.
To summarize:
Board WT32-ETH01
USB to RS232 converter
IO0 to GND
Flash: ESP_Easy_mega_20210114_normal_ESP32_4M316k_ETH-factory.bin
Connect to wifi and setting lan. Disconnect IO0
Restart and the module will connect to the lan.
To summarize:
Board WT32-ETH01
IO0 to GND
Re: WT32-ETH01
Re: WT32-ETH01
@TD-er perhaps it is safe to assume it is time to set a predefined setting for this ?
-D
Re: WT32-ETH01
I created a nice enclosure for the WT32-ETH01 + Relays
see thingiverse.. https://www.thingiverse.com/thing:4750234
Re: WT32-ETH01
Yep.
Can you make an issue on Github for it, as these things on the forum as next to impossible to find back later when I'm at a computer I can actually code and compile on and the forum doesn't have a mark unread....
Re: WT32-ETH01
Nice enclosure!hamster wrote: ↑04 Feb 2021, 21:38 I created a nice enclosure for the WT32-ETH01 + Relays
