I am working in two different locations, one with 35 ESPEasy + 10 Tasmota devices, one with three ESPEasy + 7 Tasmota devices. In one of the locations I changed the router from Telekom Speedport W925 to Fritzbox 7490. The Fritzbox 7490 had firmware 7.21 installed, the Fritzbox 7590 at home 7.01. In this combination I have had problems to get NETBIOS through the VPN (Which I built up formerly using a 7272 behind the Speedport) and I upgraded the 7590 to fw 7.21. NETBIOS started working again.
But instantly it seemed as if I had an almost complete breakdown of the far away WLAN with the 7590, it has been working stable for years before (It felt more stable with the old 7272 and FritzOS 6.84, but I was forced by the provider to change to 7590 due to changing the DSL from ADSL to VDSL). The location with the 7590 is 500km away so I started analyzing here in the small network using the 7490.
One of the ESPEasy devices I attached to my PC using the serial port.
Setting WLAN security of the 7490 to WPA+WPA2 (yes, I know, I shouldn't do this anymore) results in an almost unaccessible WebGui of the ESP.
Setting WLAN security to WPA2(CCMP) I can see the following log with recurring MQTT disconnections:
161308 : Info : EVENT: MQTT#Disconnected
161396 : Info : EVENT: MQTT#Connected
184167 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 19976 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
192054 : Error : MQTT : Connection lost, state: Disconnected
192118 : Info : MQTT : Connected to broker with client ID: MobilTemp_55_55
192120 : Info : Subscribed to: domoticz/out
192127 : Info : EVENT: MQTT#Disconnected
192196 : Info : EVENT: MQTT#Connected
192626 : Info : BMP280 : Address: 0x76
192627 : Info : BMP280 : Temperature: 18.82
192627 : Info : BMP280 : Barometric Pressure: 1015.25
192675 : Info : Domoticz: Sensortype: 8 idx: 23 values: 18.8;1015;0;0
192725 : Info : EVENT: MobilTemp#T=18.8
192839 : Info : EVENT: MobilTemp#H=0
192897 : Info : EVENT: MobilTemp#hPa=1015
204614 : Info : EVENT: Clock#Time=Thu,10:30
214168 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 18376 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
223232 : Error : MQTT : Connection lost, state: Disconnected
223294 : Info : MQTT : Connected to broker with client ID: MobilTemp_55_55
223296 : Info : Subscribed to: domoticz/out
223303 : Info : EVENT: MQTT#Disconnected
223396 : Info : EVENT: MQTT#Connected
244167 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 18376 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
254349 : Error : MQTT : Connection lost, state: Disconnected
254412 : Info : MQTT : Connected to broker with client ID: MobilTemp_55_55
254413 : Info : Subscribed to: domoticz/out
254420 : Info : EVENT: MQTT#Disconnected
254520 : Info : EVENT: MQTT#Connected
The device I've monitored reports a RSSI of -77dB, so its almost impossible to loose connection. I tried ESP_Easy_mega_20201130_normal_ESP8266_4M1M as well as ESP_Easy_mega_20201130_normal_alt_wifi_ESP8266_4M1M, Wemos D1 mini.
Due to compatibility for some old hardware at home, the 7590 was set to WPA+WPA2 - what a mess.
For me it looks like as if the FritzOS 7.21 with its huge changes of the different WLAN protocols including Mesh functionality causes the problems. Does anyone have similar observations?
