Hi guys
Im trying to output only Current values from an INA219 Voltage/Current/Power sensor.
The problem is that, in the plugin, when I select "Current" in the Measurement Type box I continue to get Voltage, Current and Power values sent out.
Is this a bug in the plugin or finger trouble on my part?
PS - I know I could just ignore the unwanted data but I actually want to send just the TaskName and not the Valname over MQTT so as to format the MQTT to mimic SignalK keys
INA219 Values - Plugin Bug ?
Re: INA219 Values - Plugin Bug ?
The omission is probably that the value count isn't reset to 1, from 3, if only 1 value should be sent.
Can you report this on the Github issue tracker as an issue so it won't get lost?
Logged in Github
Users browsing this forum: Ahrefs [Bot] and 50 guests
