Hello Community,
Couldn't find any post about the KY-024 Hall Sensor.
My question, is it possible to set a KY-024 Hall Sensor as Device in ESPEasy?
Thanks for your help!
KY-024
Re: KY-024
It can be connected as a Switch device for the digital output and/or you can connect it to the Analog input with its A0 output, but you have to take care that some ESP's only allow between 0 and 1 Volt on that input (though NodeMCU and Wemos D1 Mini's often have a voltage divider that accepts up to 3.3V).
These plugins are available in the 'normal' builds. Please use the latest, as available on Github: https://github.com/letscontrolit/ESPEasy/releases (Expand the 'Assets' link at the end of the release notes section for separate downloads for ESP8266 and ESP32).
Re: KY-024
I´ve set the Sensor as an Pulse Sensor and connected D0 on the GPIO.
Works fine!
Works fine!
Users browsing this forum: Bing [Bot] and 78 guests
