ESP8266 warming, heat radiation
Is it possible to reduce warming, heat radiation by setting ESPEasy?
For example, when I have a DS18B20 temperature sensor connected in a box on the wall. ESP warms him.
It sends only once in 60s via generic UDP.
Re: ESP8266 warming, heat radiation
You can reduce the heat produced by enabling "ECO mode" or use deep sleep.
An ESP typically uses 80 - 100 mA on average.
At 3.3V that's over 0.25 Watt.
At 5V it is 0.4 - 0.5 Watt.
With ECO mode enabled its average current consumption can get as low as 25 mA, but that is not constant.
In a confined space it will heat up its internals until you reach some equilibrium of heat dissipation with the environment.
Within a small temperature range and constant air flow and constant current usage, this could be considered a constant offset in temperature.
So you can also try to calibrate the offset and apply that in the formula field.
The best would be to place the temperature sensor outside of the enclosure of course.
Maybe it's the DS18b20 itself !?
If the time between the measurements is to low, the DS18b20 warms up itself.
I mentioned DS18B20 only as an example.
This is an image with an S8 connection to Wemos D1mini. I'm testing sleep mode.
I think it will help.
Do you have a normal photo too with the same orientation, so we can better see what components get warm?
It looks like the heat does come from the voltage regulator, but I'm not sure. (would make sense though)
I have a picture, but it does not sit, thermo and real.
It's photographed too much from a short distance.
That big heat is the processor, the small right the bottom stabilizer.
OK, on the thermal image the chip that wasn't hot looked more like the ESP chip.
But 51C is quite hot.
Had not expected it to become so warm. (20C above ambient temp)
Wemos D1 does not have a metal cover, so it heats up the processor.
Here is an example of NodeMcu Lolin ESP12E
I indicated a shift in the pictures.
The metal cover dissipated the heat from the procecore.
The warmest place is the stabilizer marked in red.
Nice to see the antenna is the coolest place on the board.
Not
thermo image and real image are shifted
The cool place is the metal cover ESP12
According to 802.11n spec, ESP should dynamically adjust TX power based on RX level or RSSI, so we can expect possible heatup in case of poor reception. Just like with mobilephones.
In the last test builds I made ESPEasy does this even more extensively.
Problem with variable power consumption is that you can't compensate for the heat with a fixed offset in temperature anymore.
I set
Sleep awake time: 60s
connected GPIO16 (D0) to GND
but the board does not sleep,
I test so that the website is still available,
it is also possible to ping.
You can also call to go to sleep from within the rules.
See for an example the wiki documentation: https://www.letscontrolit.com/wiki/inde ... =SleepMode
Micha_he yes, I conected GPIO16 to RST.
I don't control the rules much
I created rule:
on WiFi#Connected do
If [Switch#State]=0
publish,%sysname%/status,"Start"
timerSet,1,5
Else
publish,%sysname%/status,"Deepsleep Disabled"
EndIf
EndOn
On Rules#Timer=1 Do
deepsleep,60
EndOn
the system displays
62075 : Info : EVENT: System#Sleep
62087 : Info : SLEEP: Powering down to deepsleep...
and restarts immediately
I created rule:
If [Switch#State]=0
timerSet,1,5
Else
EndIf
EndOn
On Rules#Timer=1 Do
deepsleep,60
EndOn
the system displays
Instead...
when you publish to the MQTT server.
And, I mean, you must set the 'Sleep awake time' to 0 to disable it, when you use a rule to go into sleep-mode.
better use...on WiFi#Connected do
If [Switch#State]=0
on MQTT#Connected do
If [Switch#State]=0
I do not use MQTT
is MQTT internal?
I am sending Generic UDP
is MQTT internal?
But 'publish' is MQTT !? When you need a info in the log, you should use 'LogEntry'
Info: https://espeasy.readthedocs.io/en/lates ... mmand.html
I get it
but set the controller to put the system to sleep
when i don't use MQTT?
Sorry for the stupid questions,
but the rules are new to me.
I need to set a timer or just use:
On Rules # Timer = 1 Do
deepsleep, 60
EndOn
deepsleep, 60
EndOn
Publish is an internal command, but it does take the MQTT information from the first enabled MQTT controller.
Thus it needs to have an MQTT controller configured.
So you should set a timer too if you want to use the rules to set the node to sleep.
It is possible to use deep sleep without the rules, but then you probably need to let the unit run longer than needed to also cover the situations where getting a WiFi connection may take slightly longer than usual.
This will only fire if you set a timer.I need to set a timer or just use:
deepsleep, 60
EndOn
You don't need MQTT for the usage of rules !
Simply omit the publish-commands or replace them with "LogEntry, 'text in the log'" in your rule example.
It already works for me.
My settings:
on System#Boot do
timerSet,1,4
On Rules#Timer=1 Do
deepsleep,60
SendTo,%sysname%/status,"Disabled"
EndOn
The temperature dropped significantly.
Now the warmest place is the stabilizer 30 ° C.
My settings:
on System#Boot do
timerSet,1,4
On Rules#Timer=1 Do
deepsleep,60
EndOn
I'd love to.
But I set 4 seconds
I can't deactivate sleep mod.
I have to make a back door in the rules.
I'll do it in the evening.
But I set 4 seconds
GPIO16 to GNDI have to make a back door in the rules.
The first sleep after a power cycle will allow you to change settings within 30 seconds.
@TD-er: Even the one in rules?
Good question.
I think so, as in the end they do call the same function.
But I do have to check the code for this.
As I have a rule,
so fall asleep after 4 seconds
Even after a reset,
even after power up.
I think there must be the condition on GPIO16.
Even after a reset,
Happy hand, deactivated the rule within 4 seconds.
I don't know how it should work, but my solution.
Linked GPIO16 to RST.
The rule
on System # Boot do
if [DR # State] = 1
LogEntry, "True"
timerSet, 1.10
LogEntry, "false"
EndOn
deepsleep, 60
EndOn
I created a DR switch
I control whether to start the timer after the restart,
sleep or not sleep.
The rule
on System # Boot do
if [DR # State] = 1
LogEntry, "True"
timerSet, 1.10
LogEntry, "false"
EndOn
deepsleep, 60
EndOn
sleep or not sleep.
