I would like to build a water alarm sensor with the ESP01 (battery 3AAA).
I modified the ESP01 so that it goes into deep sleep. When water should be detected
the ESP01 wake up and report. The ESP01 should wake up at regular intervals
and send its status including the battery voltage via mqtt.
In order for the ESP01 to boot, the reset pin must be briefly set to high.
What's the best way to do this? With a transistor?
Greetings Dondolo
Water alarm with ESP01, deep sleep and message via mqtt
- esp01.png (70.79 KiB) Viewed 7702 times
Re: Water alarm with ESP01, deep sleep and message via mqtt
A transistor is one option. Just make sure the pulse is a nice block pulse.
It is set to the reset pulse, so if the pulse remains high (or gets triggered a number of times), the ESP will not boot at all or continuously reset.
Another problem here is that the ESP still consumes some power. Typically 60 uA and some repor that if the sleep timer has been passed the ESP is not as dormant as before, thus drawing more sleep current until it wakes.
So why not use the water sensor to power on the ESP instead of trying to wake it?
You could use a FET to power on the ESP and keep it powered until you decide to power it off again.
I am sure I did see some video on it, but I cannot find it right now.
I did find this nice project: https://homecircuits.eu/blog/battery-po ... ot-logger/
Users browsing this forum: Google [Bot] and 97 guests
