Gotmy w25q32 today :-)
In this weekend i will see if I can replace a 1MByte eeprom with a 4MByte eeprom.
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Re: Gotmy w25q32 today :-)
You do this mod ? http://smarpl.com/content/esp8266-esp-2 ... and-gpio10
Very easy to do when the flash chip is removed, it makes GPIO9 and GPIO10 fully usable, disconnects them from the flash chip.
No just want to upgrade the EEProm to 4MByte
It is real easy, bend two pins up so they are not soldered to the board and connect them with a wire to Vcc. The only thing you have to check is that you compile with the option DIO and not QIO. You do not have to cut any board traces.asm7100 wrote:No just want to upgrade the EEProm to 4MByte
Only need more space not more pins
Users browsing this forum: No registered users and 58 guests
