It was hard but i learned a lot and fortunately had help. I´ll try to do a bit more documentation later....
Feautures:
-listing the all devices
-value updates in realtime
-easy access to node
- easy blacklisting devices in the code
//Blacklist Devices e.g. ["Display", "Sensor"]
const blackList = [];
![Lach :)](./images/smilies/icon_e_smile.gif)
Screenshots: Code:
<!DOCTYPE html>
<html lang='en'>
<link rel="stylesheet" href="/esp.css">
<meta name="viewport" content="width=device-width, initial-scale=1">
<STYLE>
body {
margin: 0;
#container {
display: flex;
flex-direction: column;
align-items: center;
position: relative;
margin: auto;
padding: 10%;
flex-wrap: nowrap
#sensorList {
display: inline-grid;
grid-template-columns: auto auto auto;
grid-column-gap: 2vh;
grid-row-gap: 2vh;
position: absolute;
top: 75%
.sensorset {
display: inline-flex;
justify-items: stretch;
padding: 4.2px;
flex-wrap: nowrap;
border-radius: 5px;
align-items: stretch
.sensors {
text-align: left;
text-transform: capitalize;
padding-bottom: 5%
.values {
grid-template-columns: auto auto;
grid-column-gap: 20px
.sensorset,
.sensors,
.values,
.values div {
background-color: #ebebeb;
color: black
a {
display: inline-block
div {
text-align: center
.temp.soll span {
/*font-size: 30px;*/
.button {
margin: 4px;
padding: 14px 60px;
text-decoration: none;
border-radius: 14px;
display: block
.button:hover {
background-color: #07D;
display: block
.button:active {
background-color: #44607a;
display: block;
transform: scale(1.1);
-webkit-transform: scale(1.1);
transition: 0.1s
#opener {
top: 88%;
min-width: 200px;
max-width: 257px;
display: flex;
width: 100%;
position: fixed;
justify-content: space-around
#opener,
#opener span {
background: transparent;
.sidenav {
height: 100%;
width: 0;
position: fixed;
z-index: 1;
top: 0;
left: 0;
background-color: #111111d9;
overflow-x: hidden;
transition: 0.5s;
display: flex;
flex-wrap: nowrap;
justify-content: center;
.sidenav a {
padding: 8px 8px 8px 8px;
font-size: 25px;
display: block;
transition: 0.3s;
color: white;
.sidenav a:hover {
color: #f1f1f1
.sidenav .closebtn {
position: sticky;
top: 90%;
right: 0px;
font-size: 36px;
margin-left: 69%
@media screen and (max-height: 450px) {
.sidenav {
padding-top: 15px;
.sidenav a {
font-size: 18px;
@media screen and (max-width: 450px) {
#sensorList {
grid-column-gap: 1vh;
grid-row-gap: 1vh
.sensors {
padding-bottom: 2%
@media (prefers-color-scheme: dark) {
background-color: #222
.sensorset,
.sensors,
.values,
.values div {
background-color: #444;
color: #b3b3b3;
element.style {}
.sidenav a {
color: white
.button:hover {
</STYLE>
<script>
function openNav() {
document.getElementById("mySidenav").style.width = "250px";
function closeNav() {
document.getElementById("mySidenav").style.width = "0";
</script>
<!--Run the function when the site is loaded-->
<body onload="fetchJson()">
<script>
async function fetchJson() {
response = await fetch("json");
myJson = await response.json();
let html = '';
unit = myJson.WiFi.Hostname;
document.getElementById("unitId").innerHTML = unit;
myJson.Sensors.forEach(sensor => {
// Has the entry TaskValues
// uand is is not in Blacklist?
if (sensor.TaskValues && !blackList.includes(sensor.TaskName)) {
firstItem = true;
sensor.TaskValues.forEach(item => {
// is it the first value of a sensor?
if (firstItem) {
firstItem = false;
// add container with name to HTML h:
html += '<div class="sensorset">' + '<div class="sensors" style="font-weight:bold;font-size: 14pt;">' + sensor.TaskName + '</div>';
} else {
// add empty container to HTML:
html += '<div></div>';
// add container with name and value to HTML:
html += '<div class="values">' + '<div style="text-align: left;">' + item.Name + '</div>' + '<div style="text-align: right;">' + item.Value + '</div>' + '</div>';
console.log(sensor.TaskName + ':' + item.Name + '=' + item.Value);
html += '</div>';
console.log(html);
document.getElementById('sensorList').innerHTML = html;
} else if (!blackList.includes(sensor.TaskName)) { html += '<div class="sensorset">' + '<div class="sensors" style="font-weight:bold;font-size: 14pt;">' + sensor.TaskName + '</div>' + '<div></div>' + '<div></div>' + '</div>'; }
setTimeout(fetchJson, 5000); //how often fetch the data in ms
</script>
<script>
//function to get all the node is only called when clicking the menu button
//is a node missing open and close the menu sveral times or put it in a loop
async function getNodes() {
let html2 = '';
myJson.nodes.forEach(node => {
html2 += `<a id="${node.name}" onclick="window.location.href = 'http://${node.ip}'">${node.name}</a>`;
document.getElementById('menueList').innerHTML = html2;
</script>
<script type="text/javascript">
function submitdown() {
var xhr = new XMLHttpRequest();
xhr.onreadystatechange = function () {
if (xhr.readyState === 4) {
xhr.open('get', 'control?cmd=event,down', true);
xhr.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
xhr.send();
</script>
function submitup() {
xhr.open('get', 'control?cmd=event,up', true);
xhr.send();
</script>
function submitboost() {
xhr.open('get', 'control?cmd=event,boost', true);
xhr.send();
</script>
<div id="mySidenav" class="sidenav">
<a href="javascript:void(0)" class="closebtn" onclick="closeNav()">×</a>
<a id="menueList"> </a>
</div>
<div id="container">
<div id="unitId"> </div>
<div id="sensorList"> </div>
<div id="opener">
<span style="font-size:30px;cursor:pointer" onclick="openNav(); getNodes()">☰</span>
<span style="font-size:30px;cursor:pointer" onclick="window.location.href = '/tools';">⌂</span>
</div>
</div>
