Rule in espeasy für Hysterese
Mynameisfu
#1 Post by Mynameisfu » 15 Mar 2019, 22:13
Ich habe ein rule auf meinen ESPeasy Relativ einfach. er zeigt mir temp 1 die Kollektor Temperatur und mit temp 2 die Puffer Temperatur und schaltet eine Pumpe ein wenn temp 1 größer als temp 2 ist. So weit so gut das funktioniert auch bombe aber ich möchte eine Hysterese einbauen also temp 1 plus 10grad damit die pumpe nicht so viel taktet.
on 1#Temperature do
    if [1#Temperature] > [2#Temperature]
        gpio,5,0
    if [1#Temperature] < [2#Temperature]
        gpio,5,1
That's wonderful, but I do not get any hysteresis
I thought of something like that.
on 1#Temperature do
    if [1#Temperature] + 10
        gpio,5,0
        gpio,5,1
I hope you can help me with my problem love greetings Fu
ps. Sorry for my english :roll:
Re: Rule in espeasy für Hysterese
#2 Post by Shardan » 16 Mar 2019, 00:59
Maybe something easy helps
It should be possible to calculate a hysteresis into the rules.
I can't say if calculations can be done within the "if"... if so, it should be possible to use something like
on 1#Temperature do
    if [1#Temperature] > ( [2#Temperature] + 5 )
        gpio,5,0
    if ( [1#Temperature] -5 ) < [2#Temperature]
        gpio,5,1
for a 10° hysteresis.
Please beware, i didn't test that.
If these calculations do not work, it should be possible to use a dummy variable to calculate it.
Mynameisfu
#3 Post by Mynameisfu » 16 Mar 2019, 19:52
That's exactly how I imagined it, but unfortunately it does not work. It shows no reaction.
How did you mean that with the dummy?
PS
I have also tried another reins but also without success.
#4 Post by Shardan » 16 Mar 2019, 20:25
A dummy is a task without any sensor or actor.
Let's say you use task No. 5 and define it as a dummy as you define an usual sensor or actor.
A dummy has 4 "outputs", var1...var4.
It can be set from rules with the command
taslvalueset <tasknr>,<valuenr>,<value>
So create a dummy in task 5, call it "TempHys" for example, call the values var1...var4.
You may set the values with
taskvalueset 5,1,[1#Temperature}-5
taskvalueset 5,2,[2#Temperature}+5
You can check the results inside the task list.
These values can be used as any other sensor value, so change your rules to
on 1#Temperature do
    if [1#Temperature] > [TempHys#var2]
        gpio,5,0
    if [TempHys#Var1] < [2#Temperature]
        gpio,5,1
It might even be possible to use the formula field within the dummy variables,
they can be set to "%value% - 5" and "%value% + 5".
Just antother thing I didn't note with my last post:
Are you sure, the tasks are just called "1" and "2" as [1#Temperature] says?
This might be not a good idea. I'm not sure if these are really recognized as an event.
If I may suggest (Assuming that it is a heating flow measuring) to call them
Task name: Vorlauf, Value name: Temp
Taskname: Ruecklauf, Value name: Temp
You may check the log if an event is generated at all.
If temperature changes a line with "EVENT Vorlauf#Temp xx.xx" should occur.
(Or "1#Temperature xx.x" with your actual rule)
If no such event is generated, nothing will happen.
Mynameisfu
#5 Post by Mynameisfu » 16 Mar 2019, 23:13
on 1#Temperature do
taskvalueset 7, 1, [1#Temperature]-5
taskvalueset 7, 2, [2#Temperature]+3
gpio,5,0
if [TempHys#var1] < [2#Temperature]
gpio,5,1
So it worked, thank you very much and wish you a nice day.
LG Fu
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 0 guests
