Cannot Compile on Arduino IDE
Hello! I found this framework some days ago and today I felt like trying it. But I have a problem compiling it. The error is pretty big. It's not finding the functions declared in all the other files. (setup() is in ESPEasy.ino and SpiffsSectors() is in misc. But as it compiles the files from left to right, it doesn't find it when compiling ESPEasy.ino)
ESPEasy_R78/Source/ESPEasy/ESPEasy.ino: In function 'void setup()':
ESPEasy:361: error: 'SpiffsSectors' was not declared in this scope
if (SpiffsSectors() == 0)
ESPEasy:372: error: 'emergencyReset' was not declared in this scope
emergencyReset();
(And much more)
What should I do?
emergencyReset();
(And much more)
What should I do?
Re: Cannot Compile on Arduino IDE
Did you read this tutorial ?
http://www.esp8266.nu/index.php/Tutoria ... are_Upload
Yes I did. Anyway, by the nature of the Arduino compiler I find logic that it doesn't work. When compiling a project with multiple files, it concatenate them. First it puts the file with the same name as the folder. The rest is in alphabetic order.costo wrote:Did you read this tutorial ?
So I don't understand how actually you have make it work
Apparently you did not read or understand the tutorial completely.espeeder wrote:Yes I did. Anyway, by the nature of the Arduino compiler I find logic that it doesn't work. When compiling a project with multiple files, it concatenate them. First it puts the file with the same name as the folder. The rest is in alphabetic order.costo wrote:Did you read this tutorial ?
The part called 'Download ESP Easy Firmware' explains how the libraries are downloaded and installed.
If you still have problems you should show what you have done, what is installed and what exactly all the error messages are. The more information you give , the easyer it is to give you a helpfull answer.
It's not a Library problem. I have them installed and I can use them in other projects.costo wrote:Apparently you did not read or understand the tutorial completely.espeeder wrote:Yes I did. Anyway, by the nature of the Arduino compiler I find logic that it doesn't work. When compiling a project with multiple files, it concatenate them. First it puts the file with the same name as the folder. The rest is in alphabetic order.costo wrote:Did you read this tutorial ?
https://www.dropbox.com/s/iy0ezajl77kq7 ... 2.png?dl=0
The problem is the order of the tabs.
emergencyReset();
ESPEasy:374: error: 'LoadSettings' was not declared in this scope
LoadSettings();
ESPEasy:395: error: 'ResetFactory' was not declared in this scope
ResetFactory();
ESPEasy:403: error: 'BuildFixes' was not declared in this scope
BuildFixes();
ESPEasy:407: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_INFO, log);
ESPEasy:413: error: 'WifiAPconfig' was not declared in this scope
WifiAPconfig();
Any idea?
So it seems you have troubles compiling ESPEasy R078
But ....
you do not say which IDE you are using. 1.65 or 1.68 or another one ?
you do not say which ESP library in the boardmanager you are using 2.0.0 , 2.1.0 or another one ?
But ....
Hi, I am having the same problem:
Arduino 1.6.7
ESP8266 community version 2.1.0
R078 source code
Edit- I also just tried with the current source on Github and it has the same issue
The issue does seem to be with Arduino not including files in the correct order, all the functions in the "Misc" file are not available for the main "ESPEasy.ino" at compile time. All the source files are in the same folder in my Arduino directory, and the libraries are installed. They are all visible in the IDE under different tabs when ESPEasy is opened.
Arduino 1.6.7
R078 source code
"\Arduino\ESPEasy\ESPEasy.ino: In function 'void setup()':
ESPEasy:363: error: 'SpiffsSectors' was not declared in this scope
ESPEasy:371: error: 'fileSystemCheck' was not declared in this scope
fileSystemCheck();
ESPEasy:374: error: 'emergencyReset' was not declared in this scope
emergencyReset();
ESPEasy:376: error: 'LoadSettings' was not declared in this scope
LoadSettings();
ESPEasy:397: error: 'ResetFactory' was not declared in this scope
ResetFactory();
ESPEasy:405: error: 'BuildFixes' was not declared in this scope
BuildFixes();
ESPEasy:409: error: 'addLog' was not declared in this scope
ESPEasy:415: error: 'WifiAPconfig' was not declared in this scope
WifiAPconfig();
ESPEasy:416: error: 'WifiConnect' was not declared in this scope
WifiConnect();
You want to compile the latest stable version R078.
For that you have to follow the instructions as given in http://www.esp8266.nu/index.php/Tutoria ... are_Upload
If you follow the instructions you read there:
if you do so, your can compile R078Download and install Arduino 1.6.5. from https://www.arduino.cc/en/Main/Software
Launch arduino.exe and select preferences
Enter the URL for additional boards. Currently we use the 2.0.0. stable version so you should enter:
http://arduino.esp8266.com/stable/packa ... index.json
etc etc
Can you explain why it should work, despite the fact Arduino compiles in alphabetic order? https://www.reddit.com/r/arduino/commen ... ches_that/costo wrote:You want to compile the latest stable version R078.
etc etc
Preferences:
https://www.dropbox.com/s/y4mzi5sk3ljce ... 6.png?dl=0
Libraries:
https://www.dropbox.com/s/89ilifledjr6n ... 8.png?dl=0
costo is right, it does work with Arduino 1.6.5 and ESPCommunity 2.0.0 and R078
It does not work if you use a newer arduino version, or if you use 2.1.0 of ESPcommunity... Or if you use the github code... It only works by following exact instructions AND versions on the tutorial. At least for me.
I'm assuming they will update certain parts to be compatible with the newer Arduino and ESPCommunity code eventually, I do not know enough about the code myself to make it work with them.
Luckily you can have many versions of arduino installed into folders.. I have about 15 different versions installed from various time periods. Just download the Zip version not the installer and extract then run. You can even point them all to the same Arduino folder and the libraries can be installed in that Arduino folder, you do not have to install the libraries local to each one (unless you want to use different library versions too).
costo wrote:Because the tutorial on http://www.esp8266.nu says it does.espeeder wrote:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 137 guests
