ESP Easy Pulse count problem / bug
Maarten112
#1 Post by Maarten112 » 01 Apr 2016, 12:05
Hi Everyone,
I'm busy settings up a simple pulsecounter with ESP Easy to measure my energy consumption on an analog Energy meter. I'm upgrading from a home made arduino project to do the same, since I love the WiFi functionality of the esp8266.
I'm using the following software/hardware:
- ESP-01
- tcrt5000 sensor with breakout board on GPIO2 like the one used on the wiki: http://www.esp8266.nu/index.php/PulsCounter
- temporary USB to TTL unit to supply the circuit with stable 3.3V (will be removed as soon as everything is working).
- ESPEasy_R78
The problem is that pulses are counted multiple times after the "black" mark on the analog energy meter wheel has passed. I suspected that the interrupt would be FALLING or RISING, since it's most convenient for most applications. However, it seems that ESPEasy is counting both FALLING and RISING. I've checked the sourcecode, and noticed however that the Interrups are programmed as FALLING (e.g.
attachInterrupt(Par1, Plugin_003_pulse_interrupt6, FALLING);
) However...it still seems that both FALLING and RISING (so BOTH) are counted!
A simple solution would be to set a delay in the espeasy software, but the problem with that delay is that the delay must be long enough to not double count pulses on low current consumption, but short enough to not miss any pulses on high current consumption. It's really not convenient, since I am unable to find the sweetspot to measure all my current use (e.g. if I set the delay such that low current pulses are not double counted, it will miss pulses at high current consumption).
Would it help to use a pull up resistor between GPIO2 and VCC...or is it some kind of bug? Thanks already!!
Backbone
Re: ESP Easy Pulse count problem / bug
#2 Post by Backbone » 02 Apr 2016, 22:18
Maarten,
USB to TTL converters can deliver maximum 300 ma.
ESP8266 need more power if the wifi works! Beaware if you have problems your not the first.........
Use breadboard power supply with 1 amp power adapter to trouble shoot.
I run the same set up but my detection point is a silver spot on the dial in the number 6 (gasmeter).
Unchanged ESP EASY code and it runs fine with low and high rate of powerusage.
Paco
Maarten112
#3 Post by Maarten112 » 04 Apr 2016, 17:05
Hi Paco,
Thank you for your reply! I will change the usb to ttl adapter for a dc dc converter that will do > 1Ah and will report my findings!
dduley
#4 Post by dduley » 28 Apr 2016, 07:51
Hi All,
I am trying to use the pulse count feature to read the output of a water meter. I get 1 pulse for every ten gallons of water. That all works fine but when I try to use the formula to convert pulses to gallons all I get is the pulse count and total. The total increments by 1 for every pulse but I have a formula set up that looks like this: %value%*10. I would expect the totals to increment by 10. Are the formulas working for the Pulse count plugin?
Dave
andy
#5 Post by andy » 28 Apr 2016, 18:17
I may have found a clue. Line 27 in _P003_Pulse.ino states:
        Device[deviceCount].VType = SENSOR_TYPE_SINGLE;
...which indicates to me it may only report one value to ThingSpeak (my issue in another thread) and may only apply a formula to the first result.
If you look at line 23 in _P005_DHT.ino, you'll find:
        Device[deviceCount].VType = SENSOR_TYPE_TEMP_HUM;
...where, indeed, you can apply formulas to both values, and both values are reported to ThinkSpeak.
I think we need line 27 in _P003_Pulse.ino changed to:
        Device[deviceCount].VType = SENSOR_TYPE_TEMP_HUM_BARO;
While that's not technically correct, it drops the values into _C004.ino into the correct case and may also permit formula application to three values instead of one.
dduley
#6 Post by dduley » 29 Apr 2016, 16:46
andy wrote:I may have found a clue. Line 27 in _P003_Pulse.ino states:
Hi Andy
I think you are on to something for your Thingspeak issue but the formulas don't seem to work on either of the variables (Count or Total). I was going to look at the plugin code today to see if there was a simple change that would fix it.
Dave
dduley
#7 Post by dduley » 29 Apr 2016, 17:07
Hi All,
The other thing I just noticed is that the count values are not non-volatile. If you reset the module all the count information goes away. It would be good to save the count in flash and have a clear button on the count task or something like that. I am using mine to accumulate water usage information. If there was a power failure or the module just felt like hiccuping, as these are prone to do, then the accumulation would be lost. You would then really have to be connected to another system that provided that persistence like Thingspeak or Openhab in order to not loose that information.
Just more thoughts
Dave
costo
#8 Post by costo » 30 Apr 2016, 12:07
dduley wrote:Hi All,
Just more thoughts
Dave
In my opinion that's exactly what the ESPEasy project was meant for, collecting sensor data and sent it , wireless over IP, to a server/system where the data is saved, processed and displayed in the form you want it. That is why I use Domoticz for that purpose.
I prefer Domoticz over all the web/cloud based systems where you are dependent on a third party. A party that (to their own terms) owns your data, can change it's license and API as much and at any time as it likes and could charge you (in future) to have access to your own data.
dduley
#9 Post by dduley » 30 Apr 2016, 18:45
Hi Costo,
I disagree. Here's an example: I want to have a local display for my water meter. I want ESPEasy to accumulate the pulses from the meter, multiply the value by 10 (to get gallons), display that value and also transmit it to whatever persistence service I have chosen (Thingspeak, Domoticz, or OpenHab) for trending, Max, Min, Mean etc. I would like a local button to clear the count but I don't want the local display to loose its count because of a power failure or the all-too-often reset. I can't load the count with a value so now for the remainder of the month (Until my next water billing cycle) I have to do mental math if I look at the display. It also means that I could loose count of some events if my reporting isn't very often such as Thingspeak's 15 second update rule. This might not be so important for a simple water meter but for other applications it might be. Resets for these things can come from many places. If the wifi strength is a little weak the module can loose connectivity briefly. If there are 30 errors trying to connect to OpenHab the module resets and looses its count, if the wifi drops out for too long the the module resets etc.
Value persistence would be a major plus as would local reset and pre-loading of the count register so the value doesn't always have to start with zero (like syncing the ESP with the value already displayed on the mechanical counter of the water meter)
The Formula thing and the Thingspeak transmission issues are just simple bugs that I am sure will get sorted out in the next couple of revisions.
Best regards
Dave
Yves911
#10 Post by Yves911 » 21 May 2016, 17:43
First of all i am new here and want to thanks for all the great work you have done here.
I am considering moving my Gas/Elec counter program by ESPEasy.
I notice that from the Pulse plugin i receive only "count" values and not Total and Time into MQTT messages.
Don't know if total should be keep across reboot (because in that case you have to save the value into the flash and so the flash will die soon).
But i think that Time is needed to be send for calculation of the current consumption...
Cheers
Yves
tocks
#11 Post by tocks » 25 May 2016, 20:35
any new about the problem of save total on a reboot ?
at4501
#12 Post by at4501 » 12 Dec 2016, 16:26
i seem not to be able to transfer to Domotics pulses, it only sends idx not the value:
checked from wireshark:
[Full request URI: http://192.168.1.10/json.htm?type=comma ... ice&idx=16]
However, pasting correct url, domoticz gets updated. Problem is in Pulse sketch somewhere. Already have the newest available EasyESP version
///// sorted by version upgrade, where, it isnt possible to set up on ESP side TOTAL for the pulses. It actually warns,that, it isnt persistent. Thus, only option is delta. Now, value is sent ok.\\\\\\\
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 134 guests
