i take V101 on an resetted ESP-01 and tested the autoconfig:
see ESP_0 on my iPhone
login to these AP
set the WLAN Parameters,
see in the serial line, he´s logging in
get an IP via DHCP (another IP Range, outside the old one)
after that i did´nt can´t access this site, there´s an redirect to:INIT : Boot OK
INIT : Normal boot
>settings
System Info
IP Address : 0.0.0.0
Build : 101
Unit : 0
WifiSSID : ssid
WifiKey : wpakey
Free mem : 26072
Ok
WD : Uptime 0 ConnectFailures 0 FreeMem 26200
add 1
aid 1
station: 90:b9:31:09:3c:87 join, AID = 1
WD : Uptime 1 ConnectFailures 0 FreeMem 25056
scandone
WD : Uptime 1 ConnectFailures 0 FreeMem 24256
WIFI : Connecting... 1
scandone
state: 0 -> 2 (b0)
station: 90:b9:31:09:3c:87 leave, AID = 1
rm 1
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with xxxxxx, channel 2
dhcp client start...
ip:192.168.113.239,mask:255.255.255.0,gw:192.168.113.1
WIFI : Connected!
192.168.4.1/setup
and this is outside the possible range.
I did´nt see any "FLASH: Settings saved" on the serial line.settings
System Info
IP Address : 192.168.113.239
Build : 101
Unit : 0
WifiSSID : xxxxxx
WifiKey : xxxxxxxxxxxxxxxxx
Free mem : 24136
Ok
a week ago i wrote a bug report regarding ESP-12F, see
http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1368
it looks like the same problem.
PS:
found a workaround until these problem is solved:
call:
this is running fine
click on the "submit" Button
u can see in the serial line:
what is NOT Running:FLASH: Settings saved
after that change to "Tools" and press the reboot button.
This runs:
Press the resetbutton on the hardware
or repower it.
AFTER this INIT u can use your ESPeasy on the normal way
