Page 9 of 10
Re: Nextion display plugin
Posted: 04 Oct 2018, 20:04
by agribaldi
I do not get you.
need to use node red?
Posted: 04 Oct 2018, 20:07
by grovkillen
Well if Domoticz is not allowing you to publish to a MQTT topic with only a single value then node red is your best choice I guess.
Posted: 04 Oct 2018, 20:10
by agribaldi
I understood.
Posted: 05 Oct 2018, 14:39
by agribaldi
it was possible to transfer temperature data using node red.
now trying to make feedback with the switch nextion display , something is not working yet.
Posted: 05 Oct 2018, 14:47
by agribaldi
2018-10-05 15_46_34-ESP_Easy.jpg (29.85 KiB) Viewed 13047 times
Posted: 05 Oct 2018, 16:55
by agribaldi
Can I change the state of the button on the display with this rule?
on STH#Sw-Lamp do
if [STH#Sw-Lamp] = 1
Publish Nextion#page0.bt0.pic=0
if [STH#Sw-Lamp] = 0
Publish Nextion#page0.bt0.pic=1
Posted: 05 Oct 2018, 17:29
by grovkillen
Publish command is used for MQTT publishing. It got nothing to do with nextion commands. I think nextion is the command you're looking for?
Posted: 05 Oct 2018, 19:00
by agribaldi
here is almost a working version
only sometimes on or off works the second time.
on STH#Sw-Lamp do
Nextion,page0.bt0.val=0
on STH#Sw-Lamp do
Nextion,page0.bt0.val=1
Posted: 05 Oct 2018, 19:11
by ThomasB
Assuming your page0.bt0.val variable is working correctly, then try this rule code:
on STH#Sw-Lamp do
 if [STH#Sw-Lamp]=0
 if [STH#Sw-Lamp]=1
Posted: 05 Oct 2018, 19:13
by grovkillen
agribaldi wrote: 05 Oct 2018, 19:00 here is almost a working version
on STH#Sw-Lamp do
on STH#Sw-Lamp do
on STH#Sw-Lamp do
You never closed the if chunk with a "endif" and since it's a simple if/else you can make it like I suggest above.
Posted: 11 Oct 2018, 15:11
by Bryt
Hi! Im trying to read out value from an counter n domoticz to send to a textbox in nextion but i cant get it to work.
I can read out sensors and send but not counters.
I have used the luascript Ierlandfan posted earlier her
but cant get it to work.
Domoticz log says LUA: Counter = 75.015
I would be very grateful for help, here is the script
-- we need this function to send the quotes around the values
function url_encode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w %-%_%.%~])",
        function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  end
  return str
end
countervalueintext = otherdevices_svalues['Counter'] --this values can be for example 88.5 or 1433.2, just like temperature can be 2.3 or -4.4)
countervalueinquotes = '"' ..countervalueintext.. '"' --First part of the magic
commandArray = {}
print('Counter = '..countervalueintext) --This shows up in Domoticz log
counter =tonumber(countervalueintext) -- If you want to compare numeric values, see example later on
if (devicechanged['Counter'])then --If value changes of device SolarEnergyLive
os.execute('curl -s "http://192.168.x.x/control?cmd=NEXTION,page2.t7.txt=' .. url_encode(countervaluesinquotes) .. '"') --sending value to textbox in quotes
print('Sending data to Nextion') --This shows up in Domoticz log
return commandarray --execute the commands
end --To close the If
Posted: 24 Oct 2018, 18:46
by Wiki
meanwhile I think, I am stupid. I scrolled through the whole thread. My Nextion is connected to a Wemos D1, blue cable=> D7, yellow cable => D5. Serial port disabled.
Configuration of the Nextion in ESPEasy:
In Nextion, I have a textfield named "WZt", when I am tying to send esp_ip/control?cmd=NEXTION,page0.WZt.txt="hallo" nothing happens.
Posted: 24 Oct 2018, 22:35
by ThomasB
1. When you issue your http command from a web browser, does the browser show a response that looks like this?
NEXTION075 : WRITE = page0.WZt.txt="hallo"
2. Your Line 1 Nextion Command Statement is configured to write "24.5" to the Nextion WZt text field every 10 seconds. Do you see this value on the Nextion Display?
Posted: 25 Oct 2018, 01:06
by Wiki
Yes, the browser shows me exactly the response that you've posted. Sorry, I should have added this info to my post.
And no, the "24.5" doesn't appear on the Nextion. Thats why I tried to send whatever to the node connected to the Nextion using the http control command.
Posted: 25 Oct 2018, 03:54
by ThomasB
That confirms the Nextion plugin is active.
1. Check the ESP's serial wiring for problems.
BTW, don't forget the Nextion's black (ground) wire needs to be connected to Wemos ground. Nextion requires 5.0V (not 3.3V).
2. Check your Nextion software that you created. Maybe there is an error in your code.
Posted: 25 Oct 2018, 16:35
by Wiki
......and yes, I AM stupid.
Wiring OK, Plugin OK, Nextion OK. But now I've learned, that I should have checked the source of the Nextin for typos. If I want to send to "WZt" but the field was named by me "WWt" it could not work.
Never mind, sorry and thanks for your thoughts and tipps, and thanks for the plugin. Works absolutely perfect now.
Posted: 25 Oct 2018, 16:40
by ThomasB
Glad to hear you got it working.
Posted: 29 Oct 2018, 17:40
by Wiki
Thanks a lot for the efforts you have had with the plugin. The WAF (women's acceptance factor) raised up to 100%.
Short question: using the original RX/TX hard serial on the Wemos D1 mini (GPIO3/1) works 100% reliable (opposite to the soft serial) - you described this some pages earlier. But if I'm configuring the speed higher than 9600 I get no connection to the Nextion. Normal behaviour?
Posted: 29 Oct 2018, 17:44
by grovkillen
Wiki wrote: 29 Oct 2018, 17:40 Hi,
Up to 115200 is supported as far as I know but if the plugin is programmed for 9600 I guess setting it to something else will make the communication miss.
Posted: 29 Oct 2018, 18:44
by ThomasB
The Nextion display module defaults to 9600 baud. It does NOT automatically detect other baud rates.
So if you select anything other than 9600 in the plugin you will also need to change the baud setting in the display module. Nextion's Baud command syntax is found here:
https://nextion.itead.cc/resources/docu ... ction-set/
https://www.itead.cc/wiki/Nextion_Instruction_Set
Posted: 30 Oct 2018, 11:44
by Wiki
Thank you for the information and the links.
I did'nt think that it would be useful for me to use a higher speed than 9600 baud because up to now I only fill a few variables and check one button to be pressed. These few bytes seemed to be communicated fast enough between the devices. Just from curiosity I changed the speed to 115200. At 9600 baud I had a lack of around 1.5 seconds betweeen pressing the button and switching the light on. Has been good for me, because the relay for the light is connected to another node in my network. At 115200 the light is switched on almost instantly. Never stop learning....
Posted: 30 Oct 2018, 12:22
by grovkillen
I feel that the plug-in should have a baud rate setting.
Posted: 30 Oct 2018, 16:15
by Wiki
Setting the desired baudrate in the initializing section of the Nextion works fine. The plugin in its current state seems to me pretty stable and almost complete.
The one and only thing on my personal wishlist would be the possibility of flashing the Nextion over network. Its such a pain to unmount the display off the wall for only adding a textfield that I have ordered This one to get an useable access to the sd cardslot of the display mounted to the wall. Somehow I will integrate the cable in the future housing of the Nextion.
Posted: 30 Oct 2018, 18:04
by grovkillen
Could it be combined with a WiFi SD card or isn't the nextion that simple to set up?
Posted: 30 Oct 2018, 22:56
by Wiki
The combination should be that ESPEasy plays the Wifi card for the Nextion.
Flashing the Nextion using UART works perfectly out of the Nextion Editor while connected to my Laptop, in the Arduino library published by Itead there is an explicit function for doing this, too.
I am pretty sorry for the fact, that my coding skills are not sufficient do realize this wish. But looking at the Arduino libraries might show the way how to flash the Nextion over network using the existing - in my opinion pretty stable - serial connection of ESPEasy to the display - prerequisit hard serial.
Posted: 31 Oct 2018, 02:40
by ThomasB
I've never used the Ser2Net plugin, but maybe it could be used to assist with flashing the Nextion? Or maybe a spinoff of Ser2Net that has been altered to support Nextion's hardware serial wiring scheme. Minor code tweaks shouldn't be a problem, but a major code rewrite would be a deal killer for me.
Ideally we would need a virtual com port on our developer PC that the Nextion IDE could use to redirect its com port to TCP for flashing. Something like this (randomly found with Google):
https://www.hw-group.com/software/hw-vs ... erial-port
It would be great if a Nextion plugin user that has experience with Ser2Net would chime in and offer some insight on this idea.
Posted: 31 Oct 2018, 19:03
by ManS-H
Wiki wrote: 24 Oct 2018, 18:46 In Nextion, I have a textfield named "WZt", when I am tying to send esp_ip/control?cmd=NEXTION,page0.WZt.txt="hallo" nothing happens.
Wiki, is it possible to send me that HMI file or a printscreen of the Nextion Editor? I do something wrong, but i don't see the light.
Thanks in advance, Herman
Posted: 01 Nov 2018, 00:31
by Wiki
I think, a printscreen would not be helpful.
Pls give some more input.
Posted: 01 Nov 2018, 11:09
by ManS-H
Wiki wrote: 01 Nov 2018, 00:31 I think, a printscreen would not be helpful.
Wiki,
I did the same as you, setup the Nextion plugin. And put in the first line: page0.WZt.txt="24.5"
Then i start Nextion Editor, I have selected a font. Then i select in in the Toolbox the first line, Text.
Give it as objname: WZt
Compile it and save is as WZt. After that i bring the two files to the Nextion. I see on the screen "newtxt"
When i do esp_ip/control?cmd=NEXTION,page0.WZt.txt="hallo" it respond with NEXTION075 : WRITE = page0.WZt.txt="hallo"
But i don't see "24.5" on the Nextion screen.
I do something wrong in the Nextion Editor part, and here i need some help.
Posted: 01 Nov 2018, 11:32
by Wiki
What you have done is absolutely correct. Talking to the Nextion using the Nextion-plugin is really that simple - if you do have a working serial communication.
Check your wiring twice and triple, assure you have connected GND ESP and GND Nextion, use baudrate 9600, disable serial communication in ESPEasy Tools/Advanced.
In my first step I followed This wiring diagram, except diode and resistor, they are not necessary. My first configuration RX/TX of ESPEasy-plugin is shown here. To use hard serial my Nextion is meanwhile connected to the RX/TX pins of the Wemos.
Posted: 01 Nov 2018, 16:31
by ManS-H
Wiki wrote: 01 Nov 2018, 11:32 What you have done is absolutely correct. Talking to the Nextion using the Nextion-plugin is really that simple - if you do have a working serial communication.
Thanks Wiki, it works now. You have right, a wiring problem. I was looking to much too the colors. But the wiring of my screen was reversed. Better looking at the rear side of the print was the solution.
Posted: 09 Nov 2018, 16:21
by ManS-H
BertB wrote: 22 Jan 2017, 15:34
First I added two variables va0 and va1 and unchecked the Send Component ID of
Bt0, b0 and down buttons.
Next I put some code under the buttons:
Under Tough Release Event of bt0:
if(va1.val==0)
va1.val=1
print "|s,i99,sOn"
printh 0a
}else
va1.val=0
print "|s,i99,sOff"
printh 0x0a
I also added some rules to the ESP.
on Nextion#idx=99 do
if [Nextion#value]=1
sendtohttp 192.168.0.243,8080,/json.htm?param=switchlight&type=
command&idx=304&switchcmd=On
command&idx=304&switchcmd=Off
on Nextion#idx=230 do
sendtohttp 192.168.0.243,8080,/json.htm?param=udevice&type=
command&idx=79&nvalue=0&svalue=[Nextion#value]
With the code below, you can now also send values.
As for now I distinguish |u for update and |s for switch
First of all I will thanks BertB and ThomasB for this plugin. After a lot of reading and trying i can now switched the three lights in the livingroom on and off with the Nextion Display.
With the help of the part I quote it runs fine.
I have only one problem. Domoticz switched the lights automatic on. But i dont seen the state changing of the Nextion.
How can i made that visible?
Posted: 10 Nov 2018, 10:39
by Wiki
In general its no problem to show every information you desire on the Nextion using some rules.
But to get help you should provide more information about the infrastructure you are using.
Posted: 13 Nov 2018, 11:17
by ManS-H
Wiki wrote: 10 Nov 2018, 10:39 In general its no problem to show every information you desire on the Nextion using some rules.
My situation, i have three table lights with a ESP01 and ESPEasy build 145.
I switched they on/off with Domoticz with this command:192.168.178.xxx/control?cmd=GPIO,0,1 and 192.168.178.xxx/control?cmd=GPIO,0,0
For this moment i try to use a Nextion as Remote Control. That works good, only when Domoticz switched on a table Light the Remote Control overruled the switch in Domoticz.
My wish, switch the lamp on with Domoticz, see changing the state on the Nextion, and switched the lamp off on the Nextion.
And how to do that i don't seen the light. ;)
Posted: 14 Nov 2018, 00:43
by Wiki
Is the Nextion connected to the same device which is switching the lights or are these two different devices? Or are the lights switched by three different devices?
Posted: 14 Nov 2018, 10:51
by ManS-H
Wiki wrote: 14 Nov 2018, 00:43 Is the Nextion connected to the same device which is switching the lights or are these two different devices? Or are the lights switched by three different devices?
Nextion has his own device, a Wemos D1 mini, The table lamp has a ESP01 and Domoticz a Raspberry Pi
Posted: 14 Nov 2018, 14:48
by Wiki
OK, lets go.
There might be a smarter solution, but I would go through rules. I assume that you have the domoticz configured as MQTT-controller in your ESP12. I assume that you have define a dual-state button in Nextion.
If not already done so, define the gpio port of the relay as a device, an example you can find here, third image of the example using your GPIO 0 as 1st GPIO. On your ESP12 enable rules in the Webgui "Tools/Advanced". Define a rule:
On Relay#State do
  if [Relay#State]=0
      Publish domoticz/in,{"idx":123456,"nvalue":0,"svalue":"0"} //replace idx 123456 with the correct idx of the switch in domoticz, domoticz will change the state by itself
      SendToHTTP 192.168.xxx.xxx,80,/control?cmd=event,RelayState=0  //put in the ip of your wemos
      Publish domoticz/in,{"idx":123456,"nvalue":1,"svalue":"1"} //replace idx 123456 with the correct idx of the switch in domoticz
      SendToHTTP 192.168.xxx.xxx,80,/control?cmd=event,RelayState=1
On your Wemos enable rules, too.
Define a rule on your Wemos:
On RelayState do
  if %eventvalue%=0
    //Here place the action you want to send to Nextion using the correct name 'pagex.bty' for yout button
    //e.g. changing the value of your button: NEXTION,page0.bt0.val=0
    //Here place the action you want to send to Nextion as opposite to switching off
    //e.g. changing the value of yout button: NEXTION,page0.bt0.val=1
These two rules should change the state of the switch in domoticz as well as the state of your button in Nextion.
Posted: 17 Nov 2018, 16:06
by ManS-H
Wiki wrote: 14 Nov 2018, 14:48 OK, lets go.
On Relay#State do
  if [Relay#State]=0
On RelayState do
  if %eventvalue%=0
Wiki, Thanks for the rules, after a lot of trying it works for 90%
On the Nextion i have a button on page0 with objname bt0 and vscope global, Touch Release Event Send Component ID active.
This is what i see on my Wemos, the second Sendto is a switch I made for control.
692784: EVENT: RelayState=0
1692798: ACT : SendToHTTP 192.168.178.127,80,/control?cmd=NEXTION,page0.bt0.val=0
1692812: ACT : SendToHTTP 192.168.178.127,80,/control?cmd=GPIO,12,0
1710719: EVENT: RelayState=1
1710735: ACT : SendToHTTP 192.168.178.127,80,/control?cmd=NEXTION,page0.bt0.val=1
1710752: ACT : SendToHTTP 192.168.178.127,80,/control?cmd=GPIO,12,1
It's sends a state but the color of the button didn't change, also the state of the switch didn't change.
When i send in the browser: http://192.168.178.127/control?cmd=NEXT ... .bt0.val=0 of http://192.168.178.127/control?cmd=NEXT ... .bt0.val=1
The colors are changing. Did you maybe have a solution for this behavior?
Posted: 17 Nov 2018, 19:07
by ThomasB
I'm a bit confused, but here's what I think is going on.
1. The Nextion is wired to the ESP12 and has IP address 192.168.178.xxx.
2. The Relay is on ESP01 and has IP address 192.168.178.127.
3. The ESP12's rule is sending the NEXTION http command to the ESP01. This is not what is wanted because the NEXTION is wired to the EPS12.
What is needed is a rule in the ESP01 relay device that sends the NEXTION's http commands whenever the relay changes states. For example, in the ESP01 rules try this:
On Relay#State do
  if [Relay#State]=0
      SendToHTTP 192.168.178.xxx,80,/control?cmd=NEXTION,page0.bt0.val=0  //put in the ip of your NEXTION's ESP12
      SendToHTTP 192.168.178.xxx,80,/control?cmd=NEXTION,page0.bt0.val=1
If I have misunderstood how things are wired then please ignore my comments.
Posted: 17 Nov 2018, 20:15
by ManS-H
ThomasB wrote: 17 Nov 2018, 19:07 I'm a bit confused, but here's what I think is going on.
On Relay#State do
  if [Relay#State]=0
Hello ThomasB, thanks your answer. Instead of the ESP01 i use a Sonoff Pow for testing.
On the Sonoff Pow with IP: 192.168.178.126 i use this rule:
On Relay#State do
if [Relay#State]=0
SendToHTTP 192.168.178.53,8080,/json.htm?type=command&param=udevice&idx=1534&nvalue=0&svalue=0
SendToHTTP 192.168.178.127,80,/control?cmd=event,RelayState=0
SendToHTTP 192.168.178.53,8080,/json.htm?type=command&param=udevice&idx=1534123456&nvalue=1&svalue=1
SendToHTTP 192.168.178.127,80,/control?cmd=event,RelayState=1
On theWemos with the Nextion display, IP: 192.168.178.127 i use this rule:
On RelayState do
if %eventvalue%=0
Maybe it's so a litle bit clear for you.
Posted: 17 Nov 2018, 20:58
by ThomasB
On RelayState do
if %eventvalue%=0
I see that the Nextion Wemos (192.168.178.127) is sending http to itself. That is not supported. The Wemos NEXTION commands that originate from its own rules must use its serial port instead of the http.
As one example, on the Nextion Wemos device you would replace this rule line:
with this:
Also, what is the reason for these two rules on the Wemos Nextion (IP 192.168.178.127) that are sent to itself?
As mentioned, a device should not http to itself. If there is a GPIO-12 I/O controlled device on the Wemos then use direct GPIO statements instead.
Posted: 18 Nov 2018, 14:22
by ManS-H
ThomasB wrote: 17 Nov 2018, 20:58
On RelayState do
if %eventvalue%=0
with this:
ThomasB, thanks for the tips. It let me learn more about rules.
The two rules with GPIO,12,0 and GPIO,12,1 was for me only a check if the rules works, thats all.
In my case Domoticz switched with timers the lights on/off in the livingroom.
The only thing what i want is a rule for a button that send a on/off command from the Nextion to, for example, the Sonoff Pow on 192.168.178.126
Then I can use the Nextion as a Remote Control.
Posted: 18 Nov 2018, 17:38
by Wiki
OK, the rules on the ESP12/Sonoff seem to be correct.
On your Nextion the Touch Release event should look like something like this:
if(bt0.val==0)
  print "|s,i99,sOff"
  printh 0a
}else
  print "|s,i99,sOn"
  printh 0x0a
The term "i99" is interpreted by the Nextion plugin of ESPEasy as Nextion#idx
So on your Wemos you need these rules:
    SendToHTTP 192.168.178.126,80,/control?cmd=gpio,12,1
    SendToHTTP 192.168.178.126,80,/control?cmd=gpio,12,0
On RelayState do
  if %eventvalue%=0
Should work...
Posted: 19 Nov 2018, 21:25
by ManS-H
When i With Domoticz switch on/off the Sonoff Pow it works fine, it shows on the display the correct state.
Do i the same on the Nextion same result Pow on/ff and on the nextion the correct state.
When i switch on the Pow on Domoticz and off on the Nextion the Pow switched directly on again.
I believe the state of [Relay#State] and [Nextion#value] has a conflict with eachother.
But how to solve that.
Code on Sonoff Pow:
On Relay#State do
 if [Relay#State]=0
      SendToHTTP 192.168.178.53,8080,/json.htm?type=command&param=udevice&idx=1534&nvalue=1&svalue=1
Code on Wemos with Nextion:
On RelayState do
  if %eventvalue%=0
    NEXTION,bt0.txt="Off"
    NEXTION,bt0.txt="On"
Posted: 20 Nov 2018, 13:31
by Wiki
Well for me it looks like a misbehaviour of the dual state button - hard to say without knowing the protocol of the wemos, but possible.
Let's try to get full control of the buttons behaviour in Nextion by the wemos.
So replace the dual state button in Nextion by a normal one. If its the first button it will be named b0 (instead of bt0 as name of a dual state button)
Add a variable to the page. If its the first variable it will be named va0.
In the following example codes replace the object names I am assuming by the correct names.
In the touch release event of the button place the action:
if(va0.val==0)
  va0.val=1
  print "|s,i99,sOn"
  printh 0a
}else
  va0.val=0
  print "|s,i99,sOff"
  printh 0x0a
Define the following rules in the wemos:
On Nextion#idx=99 do
On RelayState do
  if %eventvalue%=1
    NEXTION,page0.b0.txt="On"
    NEXTION,page0.b0.bco=1024
    NEXTION,page0.va0.val=1
    NEXTION,page0.b0.txt="Off"
    NEXTION,page0.b0.bco=48631
    NEXTION,page0.va0.val=0
If the wemos is rebooted the button might not show the correct state but after the first action of the relay it will be and stay correct. To avoid this you might define an additional pair of request and answer rules between wemos and sonoff for getting the correct state of the relay during boot time of the wemos and setting the button state in Nextion accordingly.
Posted: 21 Nov 2018, 12:58
by ManS-H
Thanks Wiki,
Yesterday morning i found the same solution with the trail and error method. It works for me good enough.
I saw the same thing with working with your code and my code.
When i start the Sonoff Pow from Domoticz and i will stop it on the Nextion i must sometimes press the button twice.
That's depend of the state of the variable on the Nextion. But I can live with it.
Thanks for your help, it was a learning period for me.
Posted: 21 Nov 2018, 18:19
by Wiki
You're welcome, good to hear it works.
ManS-H wrote: 21 Nov 2018, 12:58 [...]
I have already seen a similar behaviour of my Netxion. I think its a timing problem of the serial connection between your Wemos and the Nextion because the variable - at least in my example - is set to the correct value because the Sonoff should trigger the event RelayState on the Wemos if switched on by Domoticz.
I solved this issue by switching to hard serial using GPIO3 and GPIO1 (on Wemos board these are the RX/TX pins) for connecting the Nextion and chose 115200 baud speed.
Posted: 21 Nov 2018, 18:24
by grovkillen
Wiki wrote: 21 Nov 2018, 18:19 You're welcome, good to hear it works.
Totally agree, nextion should always use hardware serial. I have seen problems over time when bit banging the S8 sensor. Using hardware serial works "forever".
Posted: 21 Nov 2018, 19:09
by ThomasB
+1: Hardware serial.
Hardware serial is needed for ESPEasy to reliably receive Nextion touch screen button presses. If the Nextion is only used as a display (touch feature not used) then soft serial is fine.
Posted: 21 Nov 2018, 19:31
by ManS-H
i used from the beginning a hard serial with GPIO13 and GPIO15.
