Sendtohttp - domoticz json
I'm trying to use a PIR connected to my esp to make a switch connected to domoticz (esp12e with 108 running)
Using the sendtohttp I added the following rule
on Landing_PIR#Switch=1 do
sendtohttp,192.168.0.93,8080,/json.htm? type=command¶m=switchlight&idx=42&switchcmd=On
However when I press submit the text is changed as below
Can anyone make any suggestions? As it replaces '¶' to ¶
Also if I remove the 2nd a within param it submits ok without changing anything but this obviously doesn't work??
Many thanks
Many thanks
Re: Sendtohttp - domoticz json
instead of using sendtohttp I found 'publish' works brilliantly
if [lux#lux]<2
Publish domoticz/in,{"idx":42,"command":"switchlight","switchcmd":"On"}
timerSet,2,20
On Rules#Timer=2 do
Publish domoticz/in,{"idx":42,"command":"switchlight","switchcmd":"Off"}
if [lux#lux]<2
timerSet,2,20
On Rules#Timer=2 do
I have exactly the same problem.
The publish doesn't work for me, I can not do it
When i do this an i push "submit"
I get this
Version R147
On BP#Switch=1 do
SendToHTTP 192.168.1.12,8080,/json.htm?type=command¶mm=switchlight&idx=46&switchcmd=On
On BP#Switch=1 do
hamster wrote:instead of using sendtohttp I found 'publish' works brilliantly
if [lux#lux]<2
timerSet,2,20
On Rules#Timer=2 do
Can you give a help how to activate mqtt in domoticz
It's just that I can not do this.
Hi Jeff,
I think you have an extra character, perhaps by using copy&paste from Windows?
Perhaps edit the rule to delete a couple of chars back from the '=', and re-add the '¶m'.
EDIT!!!
Sorry, I spoke too soon. Ignore the above.
For some reason the exact string "¶m" is displayed as "¶m"
Delete one of the two "m" and it seems to work OK
EDIT!!!
Domoticz, Sonoff, ESP32
I also have the same problem running R147
On RFID#Tag do
if [RFID#Tag]=9235734
SendToHTTP
192.168.1.2:8080/json.htm?type=command¶m=switchlight&idx=89&switchcmd=On
Becomes
On RFID#Tag do
SendToHTTP
When I push enter. And nothing happens In domoticz.
The rule works when is use Gpio,13,1 instead of SendToHTTP. Gpio 13 goes high.
Is this a bug?
Greetings Dennis
On RFID#Tag do
SendToHTTP
Becomes
On RFID#Tag do
SendToHTTP
Is this a bug?
Greetings Dennis
What is the solution?
I want rise http commands with several parameters but i am having the same problem
No solution yet for the "¶m" replacement problem?
And the Publish domoticz/in doesn't work for me either. I'd like to use mqtt to update a contact switch (it's a read only switch, used for reed sensors, and only updates with the "udevice" command on json/domoticz)
Mine has the same problem but when I see it in the Log it is ok
and all lights switch ok.
Version 147
Sonoff 16A Switch
Version 147
Sonoff 16A Switch
ESP32, Arduino's,Raspberry Pi's, ESP8266's, Nextion's, Sonoff's, LightWaveRF's, RFXCom 433, and a headache
And a HackRF One, as a present to myself.
I updated to 147, and still have the same problem (¶m gets replaced by a symbol) and the command doesnt work.
I tried something, and it worked fine.
Just invert the commands, and put "param" as the first item, without the "&".
Normal way ("¶m" gets replaced):
/json.htm?type=command¶m=switchlight&idx=174&switchcmd=On
Inverted way (working fine):
/json.htm?param=switchlight&type=command&idx=96&switchcmd=On
Hi guys,
could you please advise If I can use that in situation related to my post below
https://www.letscontrolit.com/forum/vie ... 687#p15687
I'm newbie in using scripts so any help more than appreciated.
V.
V.
Ok, replied there.vojtishek wrote: ↑07 May 2017, 22:03 Hi guys,
V.
Thank you very much!!!danielchagasrs wrote: ↑29 Jan 2017, 01:35 I tried something, and it worked fine.
Users browsing this forum: Google [Bot] and 144 guests
