Need a Build R20 With all
Need a Build R20 with all the goods up to Build (Last one)
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Re: Need a Build R20 With all
Yes I know, but the newest one is from 2015-09-13. And even that has a lot of bugs.
A lot of bugs?asm7100 wrote:Yes I know, but the newest one is from 2015-09-13. And even that has a lot of bugs.
Currently i'm using 8 esp modules in my whole house. None of them is showing any bug.
how about DS18B20 showing minus degrees?
More than one DS18B20 how does that work. ?
But now R39 works.
But now R39 works.
I still don't see how this means: "a lot of"asm7100 wrote:how about DS18B20 showing minus degrees?
But now R39 works.
For as far as i can see it's one bug you're pointing out.
A quote from the wiki:
It's not a problem you're talking about issues, that's why we are here.. to help each other and to make the esp code more stable and more useful."The ESP Easy firmware is currently in alpha stage where we're working on design, functionality and stability."
But a lot of bugs... that's way to negative for as far as I can judge.
I second that. ESP Easy is very stable from my point of view and I am very happy with it.rtenklooster wrote:It's not a problem you're talking about issues, that's why we are here.. to help each other and to make the esp code more stable and more useful."The ESP Easy firmware is currently in alpha stage where we're working on design, functionality and stability."
Users browsing this forum: Bing [Bot], Google [Bot] and 131 guests
