Introducing the Dummy Device on ESP Easy (Github R118!)
Martinus
#1 Post by Martinus » 03 Aug 2016, 15:17
In my testlab i have used the Dummy Device quite often during development and testing. I use it to test communications when the actual device is not available or i need to set specific values. Or when i need a counter that does not link to a GPIO pin but more like counting events in rules. Advantage in using a device is that you can benefit from already existing functionality like periodically sending this data to a controller without using rules or display them on local LCD using the already known template feature that also works on this dummy device.
I think this device can also be used in real life to benefit other users, so i decided to add it to the production repository. And it makes my life easier because now it is always available on any sensor that i run.
It uses a special rule command to set the values:
TaskValueSet <task nr>, <variable nr>, <value>
Instead of a fixed value, you can a value template like it is used on LCD/OLED displays and you can even use some simple calculations. But the formula field within the dummy device should not be used as this will give unexpected results. Maybe i should remove these fields from the device page. Or try to fix this, but this will not be so 'easy' because of how the current program logic is setup.
Just some rule samples where the first two values are set during boot and all four values are incremented each minute, using the system clock event. The dummy device is set for task nr 1, named "Dummy" and the valuenames are Dummy1, Dummy2, etc:
on System#Boot do
  TaskValueSet 1,1,123.45 // default value at boot
  TaskValueSet 1,2,234.56 // default value at boot
On Clock#Time do // this event comes in every minute
  TaskValueSet 1,1,[Dummy#Dummy1]+1  // you can use a template and use things like +1 or -1 or /1000 or *100
  TaskValueSet 1,2,[Dummy#Dummy2]+1
  TaskValueSet 1,3,[Dummy#Dummy3]+1
  TaskValueSet 1,4,[Dummy#Dummy4]+1
You can also retrieve values from other active devices, just by using the right template.
And you can also use it to simulate something like a DHT22 when you do not have one. The required sensor data type can be set within the task.
Some people have requested variables within rules. And maybe some day we will have stuff like that. In the mean time, you may be able to use a Dummy Device for the requested purpose as it brings 4 floating number values that can be manipulated using rules. Using a dummy device also means that you can see the actual values from within the ESP web gui and you can have them send automatically like any other sensor.
rtenklooster
Re: Introducing the Dummy Device on ESP Easy
#2 Post by rtenklooster » 03 Aug 2016, 21:02
Nice feature,
Thanx :-) will come in handy!
Richard - Groningen (NL) - Image
Yves911
#3 Post by Yves911 » 05 Aug 2016, 15:03
Thanks @Martinus
I am using that now in a rule to reset value of the pulse counter that i have to monitor gas consumption:
on System#Boot do
 TaskValueSet 4,1,0
 Publish /esp02/Gaz/conso,0
On Gaz#Count do
 if [Gaz#Count] > 0
  TaskValueSet 4,1,3600000/[Gaz#Time]
  Publish /esp02/Gaz/conso,[Dummy#Gaz]
  timerSet,1,100
On Rules#Timer=1 do
 TaskValueSet 4,1,0
Works fine
gibbon_
#4 Post by gibbon_ » 08 Aug 2016, 12:02
Using this to keep track of the values of a state machine. Can I set the values using the names in any way? I keep forgetting which numbers to type into TaskValueSet :)
paulv888
#5 Post by paulv888 » 09 Aug 2016, 20:54
A quick note for people like me, who get all excited and spend hours on trying to make this work.
There is actually a device type you need to setup as a task of type "Dummy Device" and it is not available int R108, today you need to get he github version to play with this.
Martinus
#6 Post by Martinus » 09 Aug 2016, 21:19
paulv888 wrote:A quick note for people like me, who get all excited and spend hours on trying to make this work.
Sorry about that, should have mentioned that it's only available on github as of R118.
poe
Re: Introducing the Dummy Device on ESP Easy (Github R118!)
#7 Post by poe » 13 Aug 2016, 13:01
In rules "taskvalueset 4,1,1" works just fine, but "http://#.#.#.#/control?cmd=taskvalueset 4,1,1" gives me a "Unknown or restricted command!".
I thought that every command from rules can be used with "control?cmd="
Am i doing it wrong, is it not possible or is there another way to set a value on a dummy device from a browser?
/Preben
daxkamala
#8 Post by daxkamala » 04 Sep 2016, 14:31
Is there any way to set a value (floating point) into a Dummy variable from 'outside', preferably for me by MQTT?
This would allow controlled timers, RGB values, pwm rates and the like.
Henkje1234567890
#9 Post by Henkje1234567890 » 03 Oct 2016, 11:49
Martinus wrote:In my testlab i have used the Dummy Device quite often during development and testing. I use it to test communications when the actual device is not available or i need to set specific values. Or when i need a counter that does not link to a GPIO pin but more like counting events in rules. Advantage in using a device is that you can benefit from already existing functionality like periodically sending this data to a controller without using rules or display them on local LCD using the already known template feature that also works on this dummy device.
on System#Boot do
What i want to do is, get data from two sensors, and bring it into one dummy sensor, and this sensor brings the data outside
for now i have make rules, and see the data from the sensors.
but how can i put this dat into the dummy sensor??
which command do i need
Martinus
#10 Post by Martinus » 03 Oct 2016, 16:00
Use TaskValueSet <task nr>,<value number>,<value>
Henkje1234567890
#11 Post by Henkje1234567890 » 04 Oct 2016, 10:46
Martinus wrote:Use TaskValueSet <task nr>,<value number>,<value>
i have now this:
  TaskValueSet 1,1,[Luchtdruk#Tempratuur]
  TaskValueSet 1,2,[Temp/hum#Luchtvochtigheid]
  TaskValueSet 1,3,[Luchtdruk#Luchtdruk]
and in the log, i see the values.
but how can i push this values to a dummy sensor, i have tried it with TaskValueSet 4,1,value, (4 is my dummy sensor)but its not working
Henkje1234567890
#12 Post by Henkje1234567890 » 11 Oct 2016, 17:10
anybody have suggestions about this??
Martinus
#13 Post by Martinus » 11 Oct 2016, 18:30
Could you post a device screen print here? Maybe that makes things more clear about your setup.
Henkje1234567890
#14 Post by Henkje1234567890 » 11 Oct 2016, 20:25
this is what i have now.
my goal is to combine the two sensors (number 1 and 2) to one sensor (4)
this one send the data to domoticz, like a Temp/Hum/Baro sensor.
Now i have in domoticz a temp/hum/Baro sensor, and a temp/hum sensor, but in the temp/hum/Baro sensor, there is no value for the Humidity (its always 0%)
Martinus
#15 Post by Martinus » 12 Oct 2016, 16:37
With that config, it should work these rules:
  TaskValueSet 4,1,[Luchtdruk#Temperature]
  TaskValueSet 4,2,[Temp/hum#RH]
  TaskValueSet 4,3,[Luchtdruk#Pressure]
Henkje1234567890
#16 Post by Henkje1234567890 » 13 Oct 2016, 17:10
the log gives this, and i see no values in the sensor
EVENT: Dummy#Temperature=0.00
711300421 : EVENT: Dummy#%RH=0.00
711300431 : EVENT: Dummy#Pressure=0.00
711300442 : EVENT: Dummy#=0.00
my log gives also this
Content-Type: application/json;charset=UTF-8
711350484 : Cache-Control: no-cache
711350485 : Pragma: no-cache
711350486 : Access-Control-Allow-Origin: *
711350487 :
711350488 : {
711350490 : "status" : "OK",
711350491 : "title" : "Update Device"
711350492 : }
711350493 : HTTP : closing connection
don't know what this mean
Martinus
#17 Post by Martinus » 13 Oct 2016, 17:54
I've tried to setup a system similar to yours and this works:
My log shows this when the rule triggers:
122756022 : EVENT: Clock#Time=Thu,17:51
122756027 : ACT : TaskValueSet 4,1,19.48
122756033 : ACT : TaskValueSet 4,2,52.00
122756038 : ACT : TaskValueSet 4,3,1012.93
Can you check if this kind of event is logged on your system:
Martinus
#18 Post by Martinus » 13 Oct 2016, 18:05
Did you turn on NTP?
Without NTP, there will not be any clock events created. Then the rules based on clock events will never be triggered.
Henkje1234567890
#19 Post by Henkje1234567890 » 14 Oct 2016, 08:48
many thanks, switching on the ntp function was the trick
Thotti
#20 Post by Thotti » 22 Oct 2016, 09:41
poe wrote:In rules "taskvalueset 4,1,1" works just fine, but "http://#.#.#.#/control?cmd=taskvalueset 4,1,1" gives me a "Unknown or restricted command!".
/Preben
Is it possible to set the values of the dummy device via url command?
Martinus
#21 Post by Martinus » 22 Oct 2016, 11:16
Thotti wrote:Is it possible to set the values of the dummy device via url command?
Currently not in a direct way. But if you upgrade to the current Release Candidate image, you can accomplish this:
Setup a dummy device on task one, add this to the rules section:
on Setpoint do
  TaskValueSet 1,1,%eventvalue%
And send ../control?cmd=event,setpoint=123
"Setpoint" is just an example. You could use other names for this event...
wendl
#22 Post by wendl » 24 Jan 2017, 17:00
on Setpoint do
TaskValueSet 5,1,%eventvalue%
with %eventvalue%=-3 sets dummy device value to -1
All values under 0 is set +2
MonkeyTown
#23 Post by MonkeyTown » 07 Mar 2017, 05:24
This may be a really stupid question, but I seem to be stumped and want to thank you in advance for your patience.
I am using a Switch input - button connected to gpio 14, active low, pulled up. Every push toggles the value from 0 to 1 and vice versa, exactly as it's supposed to.
I wanted to make sure, that every push of the button registers as 1, making sure it activates a dummy switch in Domoticz to ON on every press.
The dummy switch in Domoticz has a 5 sec off delay, so it is basically always off and after a button push is supposed to turn it On, that triggers an event and 5 sec later Dummy switch turns off.
The problem is, that ESP only sends button value 1 on every second push, as it works as a toggle.
I used
on BUTTON1#Switch do
 if [BUTTON1#Switch] = 1
 TaskValueSet 1,1,0
This works, log shows it, on Devices page I can see the Value 0 and yet, if I press the button after this, log shows Event BUTTON1#Switch = 0 and yet another push sends 1.
Am I going about this completely wrong? Any way to use a momentary switch (button) to always trigger ON and not a toggle?
paxi
#24 Post by paxi » 08 Mar 2017, 12:29
Simple: set the switch type to "normal switch", then the value is 1 as long as you hold the button and returns to 0 when you release it.
tim_k
#25 Post by tim_k » 15 Oct 2017, 19:07
poe wrote:
13 Aug 2016, 13:01
/Preben
I found it to be possible to send values to a unit by making a rule and get the value with %eventvalue% like documented in https://www.letscontrolit.com/wiki/inde ... _Variables
Example:
on TempOutside do
  TaskValueSet 2,1,%eventvalue%
This way it is possible to change the value of a dummy device on one unit by another unit (for example the value "Temperature" from the device "DHT"):
http://<your esp ip>/control?cmd=event,TempOutside=[DHT#Temperature]
It took me a while to figure this out as well. Hope it helps anyone in the future.
Tim
HAbuild
#26 Post by HAbuild » 13 Feb 2018, 07:33
GIT version: v2.0-20180209
I can't seem to pick up DHT readings in dummy device. DHT seems hard to call at all really.
It doesn't seem to be my lack of naming or coding. I have been fiddling around for awhile with it.
I can get it to pick up VCC. is it possibly a symptom of the recent DHT changes? I think I read that there were changed in the last couple of months.
Dummy Device.PNG (18 KiB) Viewed 12355 times
Alt rules.PNG (18.17 KiB) Viewed 12355 times
Alt Rules log.PNG (23.86 KiB) Viewed 12355 times
Picks up VCC.PNG (16.5 KiB) Viewed 12355 times
HAbuild
#27 Post by HAbuild » 13 Feb 2018, 07:36
moar vcc.PNG (15.7 KiB) Viewed 12354 times
cyberclwn
#28 Post by cyberclwn » 20 Feb 2018, 23:14
HAbuild wrote:
13 Feb 2018, 07:33
Hey,
Not sure if you got this sorted yet, but i think you are doing some bits wrong.
I think it should be like this:
TaskValueSet 7,1,[Garage#Temperature]
TaskValueSet 7,2,[Garage#Humidity]
TaskValueSet 7,3,([Garage#Temperature]-(100-[Garage#Humidity])/5)
This is how i combine a DHT + BMP into 1 device
HAbuild
#29 Post by HAbuild » 22 Feb 2018, 00:32
Thanks I got it with some mucking around. I think I had the wrong trigger.
MonkeyTown
#30 Post by MonkeyTown » 08 Feb 2019, 06:01
Thanks to all the info in this thread I was able to use the Nextion display, showing values from sensors around the house!
Using Dummy sensor on the Nextion nodemcu and having 3 other units with different sensors send data and update it. All using dummy sensor, rules and sendtohttp. Then using the Nextion plugin to display values on the screen. So far, works like a charm!!!
Thank you!!
