Is it possible to send the Data to more than one generic HTTP server IP?
The reason i would appreciate that feature is, that i got two FHEM home automation servers running and want to get the data on both servers.
More than one generic HTTP server IP possible?
Re: More than one generic HTTP server IP possible?
I don't think so, what is it you want to send?
It would be mainly temperature data and digital i/o states.
consider using node-red as backend, that can distribute than on more...
there is info on this forum for going that way, if you like..
Could also be possible to write a new Controller which sends data to two destinations ...
regards
Dominik
Dominik
You could either use FHEM2FHEM to connect the two FHEM servers, or send the data to an MQTT broker first.
From there, an unlimited number of clients can get the data.
i know about MQTT broker and FHEM2FHEM solutions.
i tried both and absolutely don't like them.
either solution in my oppinion means unnecessary overhead, one more point of failure and increased maintainance.
the most simple, least complex and efficient solution would be the espeasy "data-source" sending the date to both servers seperately.
in sourcecode it should basically only be an array and a for-loop to be added?
Users browsing this forum: Ahrefs [Bot] and 127 guests
