Hi all. After a couple of weeks trying to solve the situation i decided to write here.
I have installed EasyESP on my Node MCU for openHab mqtt interface.
i have set. fixed ip for an easy recognized of my ESP (i have 4 node mcu in the network)
I'm trying to control a relay board with my gpio outs (used GPIO4,5,12,13,14,3,1,9)
Relay board have a separate 5v supply on the coils and i use the output of my gpio to control the optocoupler. Everything seems to be ok but when i try to enable all the output (the relay is enabled when output is 0) after a while nodeMCU reset itself and enter in a infinite loop of reset.
NodeMCU has another 5v supply on Vin.
When I'm trying to flash with nodeMCU firmware (r120) the programming session ends successfully but i cannot see the ESP_0 Acces point and the node MCU enter in reset loop again
Trying with various tool but no result.
If i try to flash with original firmware i can see the access point ESPXXXXX and the nodeMCU exit from the infinite loop.
Waths wrong? how can i do to totally flash the nodeMCU? i tried to flash with severals firmware and blank.bin but if i reflash with ESPeasy it fall in infinite reset again.
are there sectors that i can restore? usually i write in 0X00000
Any ideas?
Flashing nodeMCU
Re: Flashing nodeMCU
Hi !
If so I think you should disconnect them first, flash ESPEasy and configure ESPEasy.
And maybe you have IO problems:
4 / 5 -> is default used by I2C.
1 -> is TXD from the serial Port
9 -> really bad idea to use this. That pin is connected to the onbaord flash. Using that pin can cause reboots ...
Are all of these pins are connected to control relais?I'm trying to control a relay board with my gpio outs (used GPIO4,5,12,13,14,3,1,9)
regards
Dominik
Dominik
Maybe better the use this for a relays board
http://www.esp8266.nu/index.php/MCP23017
thanks for the advice it was very useful...
my issue was due to SD2 that it was pull to ground. for fix the problem i rebooted the nodeMCU with SD2 pull to 3.3 in a breadboard. then i have set the pin to 1 by an mqtt iPhone app...
Now the question is: if i buy the component how can i set the gpio output of the MCP23107 instead of internal mcu gpio? twice have for ex gpio1 2 3 etc...
Hi !
Look at the plugin in espeasy. It´s done there
That is an I2C device. So you have to connect it to GPIO 4 /5 and communicate via I2C.MCP23107
regards
Dominik
Dominik
Users browsing this forum: Bing [Bot], Google [Bot] and 139 guests
