Hi @all,
today I installed a SOnOff with ESPEasy R136. It´s just a plain R136 compilation with the switch input and 2 system information tasks.
I included the SonOff to my FHEM setup and just call http://192.168.xxx.xxx/control?cmd=GPIO,12,0|1 to switch the relais on or off.
This works - mostly.
After some time I figured out that the response was very slow - sometimes more than 9 seconds
So I run Fiddler to check the request / response time. See the first picture where everthing is ok. The response time is around 30-40 milliseconds.
At the second picture the serial port is enabled in the advanced settings. And from time to time the communication hangs
There are response times from over 9 seconds. And that results in a timeout
So can anyone of the devs check if there is something blocking on the serial part? I should mention that the serial port is not connected to a computer during this test.
But I have never had such a problem before.
BUG: Is the serial port blocking the webserver?
- Response is OK
- WebServerResponse01.PNG (48.16 KiB) Viewed 3273 times
- Response is BAD
- WebServerResponse02.PNG (38.31 KiB) Viewed 3273 times
regards
Dominik
Dominik
Re: BUG: Is the serial port blocking the webserver?
I'm using this little VB script to verify webrequests:
It toggles GPIO2 on and off using http requests. I let it run for about 10 minutes on my Sonoff device with serial and weblogging both set to level 2. Last part of the logfile:
More than 600 requests fired, one request per second, no errors, average response 93 milliSeconds and maximum 2098 mSeconds.
4 requests took longer than 1 second.
Sonoff runs R140
ip = WScript.Arguments.Item(0)
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objLogFile = objFSO.createTextFile("webtestlog_" & ip & ".txt", True)
count=0 ' count number of requests
errors=0 ' count request with returncode <> 200
min=10000 ' keep track of fastest response
max=0 ' keep track of slowest response
onesecond=0 ' count number of requests beyond one second response time
total=0 ' count total time
state=1 ' track gpio toggle state
do while true
if state =1 then
state = 0
state = 1
end if
Set objHTTP = CreateObject( "WinHttp.WinHttpRequest.5.1" )
objHTTP.Open "GET", "http://" & ip & "/control?cmd=gpio,2," & state, False
objHTTP.SetRequestHeader "User-Agent", "Mozilla/4.0 (compatible; MyApp 1.0; Windows NT 5.1)"
on error resume next
start = timer()
objHTTP.Send
duration = (timer()-start) * 1000
intStatus = objHTTP.Status
Set objHTTP = Nothing
on error goto 0
if intStatus = 200 then
count = count + 1
total = total + duration
if duration > 1000 then
onesecond = onesecond + 1
end if
if duration > max then
max = duration
end if
if duration < min then
min = duration
end if
logging = "Cnt:" & count & " Dur:" & round(duration) & "mS Min:" & round(min) & "mS Max:" & round(max) & "mS Avg:" & round(total/count) & "mS >1s:" & round(onesecond) & " Err:" & round(errors)
errors = errors + 1
logging = "Errors: " & errors
end if
Wscript.echo logging
objLogFile.writeline(logging)
Wscript.sleep 1000
loop
Cnt:606 Dur:94mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:607 Dur:98mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:608 Dur:98mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:609 Dur:90mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:610 Dur:82mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:611 Dur:86mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:612 Dur:78mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:613 Dur:74mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:614 Dur:102mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:615 Dur:94mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:616 Dur:82mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:617 Dur:86mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:618 Dur:148mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:619 Dur:82mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:620 Dur:74mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Cnt:621 Dur:94mS Min:62mS Max:2098mS Avg:93mS >1s:4 Err:0
Sonoff runs R140
Hi Martinus,
this is strange
I will try the latest Github version today and test if it works better ...
this is strange
regards
Dominik
Dominik
Hi Martinus,
I flashed the 141 today and at first it looks ok. But ofter some tests it seems that the problem still exists.
This is what I did:
* Compile & Flash R141
* Enable Web and Serial Logging
* Set Loglevel serial to 2 (Default)
At this stage everthing seems to be ok.
But after setting the serial Loglevel to 4 there are sometimes delays if you toggle the Output relais of the SonOff very fast.
It seems a little bit better than the test with R136. But anyway ... Looks like to serial Output generates some delay.
I wasn´t able to reproduce these really long delays from ~9 seconds like in my initial posting.
But maybe you can give it a try with loglevel 4 on serial Log.
This is what I did:
regards
Dominik
Dominik
Users browsing this forum: Google [Bot] and 102 guests
