Newbie Rules Question
I have a setup running with Openhab, MQTT and multiple ESP nodes.
One of the ESPEasy nodes running R120 is named "ESP1" and is configured with Subscribe Template "/ESP1/#". Through Openhab, user action generates a MQTT message "/ESP1/aaa/bbb 1".
What is the event syntax in ESPEasy Rules that I need for the above message?
I have read many posts on the ESPEasy rules but have not been able to figure it out as I am a newbie to the rules.
Thanks in advance.
Thanks in advance.
Re: Newbie Rules Question
Tried a few things and found that "MQTT Import" provided the best solution.
on <event> dosmathur wrote: ..MQTT message "/ESP1/aaa/bbb 1".
publish /ESP1/aaa/bbb,1
Thanks timsson. However, I need to subscribe rather than publish as the publishing is done by Openhab. Based on the content of the topic subscribed in the ESPEasy device, I want to process a rule.
timsson wrote: on <event> do
I am not sure how this works as I have not tried to use the subscribe, but can you tell me what shows up in the log when the MQTT message arrives? If it is an event, try to use it as an event in "rules".
I haven't found anything else, but this is where I would start. Syntax is probably the same as any event based rule.
Please post if it works!
Several posts showing you cannot subscribe to MQTT published data on ESPEasy. See also http://www.letscontrolit.com/wiki/index ... _Variables
However, you can use it this way:
In OpenHAB: executeCommandLine("curl http://192.168.1.201/control?cmd=event,myEventNo1=123")
on myEventNo1 do
timerSet 1,%eventvalue%
or for a Dummy Device (like a variable).....
on myEventNo1 do
TaskValueSet 1,1,%eventvalue%
on myEventNo1 do
on myEventNo1 do
https://github.com/ESP8266nu/ESPEasyPlu ... Import.inoStephenF wrote:Several posts showing you cannot subscribe to MQTT published data on ESPEasy. ......
I am using Esp Easy Mega, and the MQTT Import works very well... Excellent plugin. Thankstimsson wrote:https://github.com/ESP8266nu/ESPEasyPlu ... Import.inoStephenF wrote:Several posts showing you cannot subscribe to MQTT published data on ESPEasy. ......
Users browsing this forum: No registered users and 134 guests
