rc-switch plugin
kniazio
rc-switch plugin
#1 Post by kniazio » 30 Dec 2016, 13:28
I have a proven operating sketch to control wall switches https://pl.aliexpress.com/item/EU-Stand ... =200001056
Is there a person who remodel this sketch for a plugin for EspEasy?
I really want this.
 *  This sketch demonstrates how to set up a simple HTTP-like server.
 *  The server will set a switch depending on the request
 *    http://server_ip/sw1/0 will turn sw1 off
 *    http://server_ip/sw1/1 will turn sw1 on
 *  server_ip is the IP address of the ESP8266 module, will be
 *  printed to Serial when the module is connected.
#include <RCSwitch.h>
#include <ESP8266WiFi.h>
RCSwitch mySwitch = RCSwitch();
const char* ssid = "your_ssid";
const char* password = "your_password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
void setup() {
  Serial.begin(115200);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  // Transmitter is connected to ESP8266 PIN #2
  mySwitch.enableTransmit(2);
  //EtekCity ZAP Remote Outlets use pulse of approximately 189
  mySwitch.setPulseLength(189);
  mySwitch.enableReceive(0); // Receiver on interrupt 0 => that is pin #2
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.println(WiFi.localIP());
void loop() {
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String req = client.readStringUntil('\r');
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  int swi;
  // **** SWITCH 1 ****
  if (req.indexOf("/sw1/0") != -1)
    {val = 0;
    swi = 1;
    // Insert your "OFF" code here, before ", 24)"
    mySwitch.send(5260604, 24);}
  else if (req.indexOf("/sw1/1") != -1)
    {val = 1;
    swi = 1;
    // Insert your "ON" code here, before ", 24)"
    mySwitch.send(5260595, 24);}
  // **** SWITCH 2 ****
  else if (req.indexOf("/sw2/0") != -1)
    {val = 0;
    swi = 2;
    mySwitch.send(1234567, 24);}
  else if (req.indexOf("/sw2/1") != -1)
    {val = 1;
    swi = 2;
    mySwitch.send(2345678, 24);}
  // **** SWITCH 3 ****
  else if (req.indexOf("/sw3/0") != -1)
    {val = 0;
    swi = 3;
    mySwitch.send(3456789, 24);}
  else if (req.indexOf("/sw3/1") != -1)
    {val = 1;
    swi = 3;
    mySwitch.send(4567890, 24);}
    // **** SWITCH 4 ****
  else if (req.indexOf("/sw4/0") != -1)
    {val = 0;
    swi = 4;
    mySwitch.send(5678901, 24);}
  else if (req.indexOf("/sw4/1") != -1)
    {val = 1;
    swi = 4;
    mySwitch.send(6789012, 24);}
  // **** SWITCH 5 ****
  else if (req.indexOf("/sw5/0") != -1)
    {val = 0;
    swi = 5;
    mySwitch.send(7890123, 24);}
  else if (req.indexOf("/sw5/1") != -1)
    {val = 1;
    swi = 5;
    mySwitch.send(8901234, 24);}
  // **** SWITCH 6 ****
  else if (req.indexOf("/sw6/0") != -1)
    {val = 0;
    swi = 6;
    mySwitch.send(9012345, 24);}
  else if (req.indexOf("/sw6/1") != -1)
    {val = 1;
    swi = 6;
    mySwitch.send(1098765, 24);}
    // **** SWITCH 7 ****
  else if (req.indexOf("/sw7/0") != -1)
    {val = 0;
    swi = 7;
    mySwitch.send(4478268, 24);}
  else if (req.indexOf("/sw7/1") != -1)
    {val = 1;
    swi = 7;
    mySwitch.send(4478259, 24);}
    // **** SWITCH 8 ****
  else if (req.indexOf("/sw8/0") != -1)
    {val = 0;
    swi = 8;
    mySwitch.send(87124, 24);}
  else if (req.indexOf("/sw8/1") != -1)
    {val = 1;
    swi = 8;
    mySwitch.send(87121, 24);}
  else {
    Serial.println("invalid request");
    client.stop();
    return;
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nSwitch ";
  s += String(swi, DEC);
  s += " is now ";
  s += (val)?"ON":"OFF";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
kniazio
Re: rc-switch plugin
#2 Post by kniazio » 07 Jan 2017, 19:40
Is there anyone who can help me?
BertB
#3 Post by BertB » 08 Jan 2017, 10:25
You could look if RFLINK ( also in this forum) controls the device.
If not, you could ask them to implement it.
I use RFLINK for numerous RF applications.
data
#4 Post by data » 08 Jan 2017, 15:19
Have you tried the KAKU Plugin from the Playground?
https://github.com/letscontrolit/ESPEas ... 3_KaKu.ino
Stuntteam
Site Beheer
#5 Post by Stuntteam » 08 Jan 2017, 16:24
BertB wrote:You could look if RFLINK ( also in this forum) controls the device.
It is very likely that RFLink supports it.. If not, we will add support for it.
kniazio
#6 Post by kniazio » 08 Jan 2017, 16:39
I would like to have but easyesp.
I do not want to engage other devices.
kniazio
#7 Post by kniazio » 08 Jan 2017, 19:07
data wrote:Have you tried the KAKU Plugin from the Playground?
Yes, I checked.
It only works with sockets type kaku_switch sold in stores Jula
NietGiftig
#8 Post by NietGiftig » 08 Jan 2017, 21:43
kniazio wrote:I do not want to engage other devices.
Thats clear then!
You have work to do :D
s4nder
#9 Post by s4nder » 19 Jan 2017, 12:19
I made a 2 plugins with RC-Switch, but did not find the time to test it or publish it. Here is the code:
_P112_RFTX.ino:
//########################### Plugin 112: Output 433 MHZ - RF  				        ###########################
  Version: 1.0
  Description: use this script to send RF with a cheap FS1000A alike sender
  Example of usage:
  Learn codes via _P111_RF.ino plugin!
  Needs: RCSwitch library
  Tested on GPIO:14
  Author: S4nder
  Copyright: (c) 2015-2016 Sander Pleijers (s4nder)
  License: MIT
  License URI: http://en.wikipedia.org/wiki/MIT_License
  Status : "Proof of concept"
  Usage:
  1=RFSEND
  2=commando
  3=repeat (if not set will use default settings)
  4=bits (if not set will use default settings)
                                    1      2              3  4
  http://<ESP IP address>/control?cmd=rfsend,blablacommando,10,24
  This program was developed independently and it is not supported in any way.
RCSwitch *rcswitchSender;
#define PLUGIN_112
#define PLUGIN_ID_112         112
#define PLUGIN_NAME_112       "RF Transmit - FS1000A alike sender"
unsigned long Plugin_112_Repeat;
unsigned long Plugin_112_Bits;
unsigned long Plugin_112_Pulse;
boolean Plugin_112(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_112;
        Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_112);
    case PLUGIN_WEBFORM_LOAD:
        char tmpString[128];
        Plugin_112_Bits = ExtraTaskSettings.TaskDevicePluginConfigLong[0];
        if (Plugin_112_Bits < 100) Plugin_112_Bits = 24;
        Plugin_112_Pulse = ExtraTaskSettings.TaskDevicePluginConfigLong[1];
        if (Plugin_112_Pulse > 1000) Plugin_112_Pulse = 165;
        Plugin_112_Repeat = ExtraTaskSettings.TaskDevicePluginConfigLong[2];
        if (Plugin_112_Repeat > 10) Plugin_112_Pulse = 1;
        sprintf_P(tmpString, PSTR("<TR><TD>Bits (default=24):<TD><input type='text' name='plugin_112_bits' value='%u'>"), Plugin_112_Bits);
        string += tmpString;
        sprintf_P(tmpString, PSTR("<TR><TD>Pulselength (default=165):<TD><input type='text' name='plugin_112_pulse' value='%u'>"), Plugin_112_Pulse);
        sprintf_P(tmpString, PSTR("<TR><TD>Repeat (default=1):<TD><input type='text' name='plugin_112_repeat' value='%u'>"), Plugin_112_Repeat);
        success = true;
    case PLUGIN_WEBFORM_SAVE:
        String plugin1 = WebServer.arg("plugin_112_bits");
        Plugin_112_Bits = plugin1.toInt();
        String plugin2 = WebServer.arg("plugin_112_pulse");
        Plugin_112_Pulse = plugin2.toInt();
        String plugin3 = WebServer.arg("plugin_112_repeat");
        Plugin_112_Repeat = plugin3.toInt();
        if (Plugin_112_Bits > 100) Plugin_112_Bits = 24;
        if (Plugin_112_Pulse > 10) Plugin_112_Repeat = 1;
        ExtraTaskSettings.TaskDevicePluginConfigLong[0] = Plugin_112_Bits;
        ExtraTaskSettings.TaskDevicePluginConfigLong[1] = Plugin_112_Pulse;
        ExtraTaskSettings.TaskDevicePluginConfigLong[2] = Plugin_112_Repeat;
        SaveTaskSettings(event->TaskIndex);
        success = true;
    case PLUGIN_WEBFORM_SHOW_CONFIG:
        string += String(ExtraTaskSettings.TaskDevicePluginConfigLong[0]);
        string += String(ExtraTaskSettings.TaskDevicePluginConfigLong[1]);
        string += String(ExtraTaskSettings.TaskDevicePluginConfigLong[2]);
        success = true;
    case PLUGIN_INIT:
        LoadTaskSettings(event->TaskIndex);
        //if (Plugin_112_Bits > 100) Plugin_112_Bits = 24;
        //if (Plugin_112_Repeat > 10) Plugin_112_Repeat = 1;
        int txPin = Settings.TaskDevicePin1[event->TaskIndex];
        if (rcswitchSender == 0 && txPin != -1)
          addLog(LOG_LEVEL_INFO, "INIT: RF433 TX created!");
          //rcswitchSender = new RCSwitch(txPin);
          rcswitchSender = new RCSwitch();
          rcswitchSender->enableTransmit(txPin);
          rcswitchSender->setPulseLength(Plugin_112_Pulse);
        if (rcswitchSender != 0 && txPin == -1)
          addLog(LOG_LEVEL_INFO, "INIT: RF433 TX REMOVED!");
          delete rcswitchSender;
          rcswitchSender = 0;
        success = true;
    case PLUGIN_TEN_PER_SECOND:
    case PLUGIN_WRITE:
        String Plugin_112_Result = "";
        unsigned int Plugin_112_DeviceNr = 0;
        unsigned int Plugin_112_Value = 0;
        char command[80]; command[0] = 0;
        char TmpStr1[80]; TmpStr1[0] = 0;
        string.toCharArray(command, 80);
        String tmpString = string;
        if (argIndex) tmpString = tmpString.substring(0, argIndex);
        if (GetArgv(command, TmpStr1, 2)) Plugin_112_Value = str2int(TmpStr1);
        if (GetArgv(command, TmpStr1, 3)) Plugin_112_Repeat = str2int(TmpStr1);
        if (GetArgv(command, TmpStr1, 4)) Plugin_112_Bits = str2int(TmpStr1);
        if (tmpString.equalsIgnoreCase("RFSEND") && rcswitchSender != 0 && Plugin_112_Bits != 0)
          Serial.println("RFSEND");
          success = true;
          Plugin_112_Result = "Unknown RF command or structure !!!";
          for (int i = 0; i <= Plugin_112_Repeat; i++) {
            rcswitchSender->send(Plugin_112_Value, Plugin_112_Bits);
            //delay(1000);
          addLog(LOG_LEVEL_INFO, "RF Code Sent: " + String(Plugin_112_Value));
          if (printToWeb)
            String url = String(Settings.Name) + "/control?cmd=" + string;
            printWebString += F("RCSwitch Code Sent!");
            printWebString += F("<BR>Value: ");
            printWebString += String(Plugin_112_Value);
            printWebString += F("<BR>Repeats: ");
            printWebString += String(Plugin_112_Repeat);
            printWebString += F("<BR>Bits: ");
            printWebString += String(Plugin_112_Bits);
            printWebString += F("<BR>Pulselength: ");
            printWebString += String(Plugin_112_Pulse);
            printWebString += F("<BR><BR>");
            printWebString += F("<BR>Use URL: <a href=\"http://");
            printWebString += url;
            printWebString += F("\">http://");
            printWebString += F("</a>");
  return success;
And _P111_RF.ino:
//#################################### Plugin 111: Input RF #############################################
Version: 1.1
Description: use this script to recieve RF with a cheap MX-05V alike reciever
Author: S4nder
License: MIT
RCSwitch *rfReceiver;
#define PLUGIN_111
#define PLUGIN_ID_111         111
#define PLUGIN_NAME_111       "RF Recieve - MX-05V alike reciever"
#define PLUGIN_ValueNAME1_111 "RF"
boolean Plugin_111(byte function, struct EventStruct *event, String& string)
  switch (function)
        Device[++deviceCount].Number = PLUGIN_ID_111;
        Device[deviceCount].VType = SENSOR_TYPE_LONG;
        Device[deviceCount].ValueCount = 1;
        Device[deviceCount].TimerOption = false;
        Device[deviceCount].GlobalSyncOption = true;
        string = F(PLUGIN_NAME_111);
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_ValueNAME1_111));
    case PLUGIN_INIT:
        int rfPin = Settings.TaskDevicePin1[event->TaskIndex];
        //Serial.println(String(rfPin));
        if (irReceiver != 0) {
          String log = F("BUG: Cannot use IR reciever and RF reciever at the same time!");
          Serial.print(log);
          addLog(LOG_LEVEL_INFO, log);
          delete rfReceiver;
          rfReceiver = 0;
        } else {
          if (rfPin != -1)
            Serial.println("INIT: RF433 RX created!");
            rfReceiver = new RCSwitch();
            rfReceiver->enableReceive(rfPin);
          if (rfReceiver != 0 && rfPin == -1)
            Serial.println("INIT: RF433 RX removed!");
            rfReceiver->resetAvailable();
            delete rfReceiver;
            rfReceiver = 0;
        success = true;
    case PLUGIN_ONCE_A_SECOND:
        if (irReceiver != 0) break;
        if (rfReceiver->available())
          Serial.print("RF recieved");
          int valuerf = rfReceiver->getReceivedValue();
          if (valuerf == 0) {
            Serial.print("Unknown encoding");
            String log = F("RF Code Recieved: ");
            log += String(valuerf);
            log += " =Unknown encoding";
          } else {
            Serial.print("Received ");
            Serial.print( rfReceiver->getReceivedValue() );
            Serial.print(" / ");
            Serial.print( rfReceiver->getReceivedBitlength() );
            Serial.print("bit ");
            Serial.print("Protocol: ");
            Serial.println( rfReceiver->getReceivedProtocol() );
            UserVar[event->BaseVarIndex] = (valuerf & 0xFFFF);
            UserVar[event->BaseVarIndex + 1] = ((valuerf >> 16) & 0xFFFF);
            Usage:
            1=RFSEND
            2=commando
                                                1      2              3  4
            http://<ESP IP address>/control?cmd=RFSEND,blablacommando,10,24
            Output this in logging:
            String url = String(Settings.Name) + "/control?cmd=RFSEND," + String(rfReceiver->getReceivedValue()) + ",1," + String(rfReceiver->getReceivedBitlength()) ;
            String printString = F("For sending this command,");
            addLog(LOG_LEVEL_INFO, printString);
            printString = F("use URL: <a href=\"http://");
            printString += url;
            printString += F("\">http://");
            printString += url;
            printString += F("</a>");
            sendData(event);
        success = true;
  return success;
But as said, it may be buggy! It works perfect for me on a Wemos D1 mini... ;)
kniazio
#10 Post by kniazio » 19 Jan 2017, 16:44
You do not know how long I waited for this plugin :)
It works perfectly
I checked out the sockets
Kemot, http://allegro.pl/3x-gniazdo-gniazdko-s ... 94168.html
Clarus https://www.google.pl/search?q=gniazdka ... ikR01VM%3A
and wallswitches https://pl.aliexpress.com/item/EU-Stand ... =200001056
Many, many thanks
Regards and Respect
data
#11 Post by data » 19 Jan 2017, 20:49
Which receiver do you use?
kniazio
#12 Post by kniazio » 20 Jan 2017, 07:27
I use this.
https://www.aliexpress.com/snapshot/824 ... 2219996465
It is expensive but good.
data
#13 Post by data » 20 Jan 2017, 07:44
This is an RXB6 receiver. You can get the receiver module alone for about US$1.21 here: http://s.click.aliexpress.com/e/IybEuny
I hope the next release will make use of the RSSI output available on v2.0 of this receiver:
viewtopic.php?f=11&t=2502
data
#14 Post by data » 20 Jan 2017, 08:47
@s4nder
Thank you very much for these plugins. I hope they'll find their way into the regular build.
Works fine on both - R147_RC8 and R148
s4nder
#15 Post by s4nder » 24 Jan 2017, 10:26
No problem, glad i can contribute something back to the community.
There is only one annoying bug with my plugin; if you use the _P016_IR.ino plugin (IR recieve) on the same device the RF receiver 'receives' strange codes (that the IR receiver actually receives it seems...). But my code has a check for that. If someone is able to find a solution for that he/she would be the hero of the day! ;)
Can someone post this to the development playground on git?
gaetandu80fr
#16 Post by gaetandu80fr » 26 Jan 2017, 14:17
Hello S4ander,
Thank you for sharing.
Is the plugin receiver compatible with DIO CHACON remote control (ref: 54760 / model: PBT-707)?
This remote uses NEXA / HOME EASY protocols
Cordially
s4nder wrote:I made a 2 plugins with RC-Switch, but did not find the time to test it or publish it. Here is the code:
_P112_RFTX.ino:
  Version: 1.0
  Example of usage:
  Tested on GPIO:14
  Author: S4nder
  License: MIT
  Usage:
  1=RFSEND
  2=commando
                                    1      2              3  4
#define PLUGIN_112
  switch (function)
        success = true;
        success = true;
        success = true;
    case PLUGIN_INIT:
          rcswitchSender = 0;
        success = true;
    case PLUGIN_WRITE:
          success = true;
            //delay(1000);
          if (printToWeb)
  return success;
And _P111_RF.ino:
Version: 1.1
Author: S4nder
License: MIT
#define PLUGIN_111
  switch (function)
    case PLUGIN_INIT:
          Serial.print(log);
          delete rfReceiver;
          rfReceiver = 0;
        } else {
          if (rfPin != -1)
            delete rfReceiver;
            rfReceiver = 0;
        success = true;
          if (valuerf == 0) {
          } else {
            Usage:
            1=RFSEND
            2=commando
                                                1      2              3  4
            printString += url;
            printString += url;
            sendData(event);
        success = true;
  return success;
s4nder
#17 Post by s4nder » 28 Jan 2017, 14:52
Good question, I think that should work but i cannot test it. NEXA / HOME EASY is a quite simple protocol but unfortunately I cannot find a 'compatibility'-list for the rc-switch library.
Maybe someone has already done a fork for it: https://433mhz.codeplex.com/SourceControl/latest
For me at home I can control quite some devices. Even a 433mhz doorbel, and the older KAKU switches in the garden from my neighbors.... :lol: :twisted:
kniazio
#18 Post by kniazio » 28 Jan 2017, 16:13
gaetandu80fr
#19 Post by gaetandu80fr » 01 Feb 2017, 12:10
thank you for your reply
This plug-in uses a modified version of NexaCtrl library that no longer supports Home Easy
And this plug-in works only in emission off I have indicated that I needed the reception
kniazio wrote:viewtopic.php?t=1103
Raimund
#20 Post by Raimund » 04 Feb 2017, 21:19
s4nder
#21 Post by s4nder » 24 Feb 2017, 09:02
Can someone post my plugins to the Github Plugin playground?: https://github.com/letscontrolit/ESPEas ... Playground
No clue how to do this... :lol: Maybe this way the plugins will find their way to the final builds.
By the way, i also use these modules now: https://www.aliexpress.com/item/433-Mhz ... 52611.html they work fine and are nice and small.
ipua
#22 Post by ipua » 24 Feb 2017, 17:41
Hi s4nder,
Thanks for yur plugin!
I am using it and it workrks great!
Also I am using modules from exactly same seller - they working fine.
oisisi
#23 Post by oisisi » 25 Feb 2017, 21:28
For my understanding, under 'commando' it expects the raw binary sequence? Higher level command from rc-switch (like the ones mentioned here) are not supported, right?
s4nder
#24 Post by s4nder » 28 Feb 2017, 10:10
oisisi wrote:For my understanding, under 'commando' it expects the raw binary sequence? Higher level command from rc-switch (like the ones mentioned here) are not supported, right?
It uses a 8 digit code that is received with the reciever plugin. Then you can use it like this:
http://*yourwemos*/control?cmd=RFSEND,10939202,2
Where '10939202' should be the code u see in the esp-easy logging, from the reciever plugin. The plugins i made do not have support for tri-state (.sendTriState) or other commands (.switchOn) yet, it uses only .send(). But in most cases for me, the 8 digit codes do somehow work here...
oisisi
#25 Post by oisisi » 28 Feb 2017, 14:59
Thanks for the reply. I now hacked together my own standalone sketch. Regrettably, I lack the skills to work it into a plugin.
data
#26 Post by data » 28 Feb 2017, 21:36
Post it here, we might try to create a plugin out of it...
oisisi
#27 Post by oisisi » 01 Mar 2017, 13:22
data wrote:Post it here, we might try to create a plugin out of it...
I was afraid this would pop up. It is currently very ugly, I'll clean it up a bit and post it.
oisisi
#28 Post by oisisi » 01 Mar 2017, 21:00
Well you were warned. Here it is. It works with sockets that have dip switches for selecting the code and ones with two rotary code selectors.
  MQTT -> ESP8266 -> RC controlled socket
  parsing JSON formatted topic and turns 433.92 MHz
  radio controlled sockets on or off using library RCSwitch
  two protocols are defined:
  prot 1 uses two five-digit binary codes
  prot 2 uses two int values
  The topic of choice is "home/action/rfbridge"
  Command line examples as published using mosquitto:
  mosquitto_pub -t home/action/rfbridge -m "{prot: 1, state: 1, ident: 10000, unit: 10000}"
  mosquitto_pub -t home/action/rfbridge -m "{prot: 2, state: 1, ident: 2, unit: 4}"
  The JSON library isn't to picky about properly formatted objects. From Node_RED I would send
  as payload {"prot": 2, "state": 1, "ident": 2, "unit": 4}
  -- oisisi
#include <PubSubClient.h>
#include <ArduinoJson.h>
// #define DEBUG
const char* ssid = "....";
const char* password = "....";
const char* mqtt_server = "....";
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  // sender's data in pin is connected to WEMOS pin D6
  mySwitch.enableTransmit(D6);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("IP address: ");
// MQTT message received callback
void callback(char* topic, byte* payload, unsigned int length) {
  // prep JSON buffer
  StaticJsonBuffer<90> jsonBuffer;
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  Serial.println("");
  Serial.println("length: " + String(length));
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  // copy MQTT payload into JSON object
  JsonObject& root = jsonBuffer.parseObject(payload);
  if (!root.success()) {
    Serial.println("parseObject() failed");
    return;
  // JSON values -> vars
  // state 1 is on, 0 is off
  int swstate = root["state"];
  // store protocol
  int swprot = root["prot"];
  // reject if protocol declaration is missing/wrong
  if (swprot != 2 && swprot != 1) {
    Serial.print(swprot);
    Serial.println(" no protocol defined");
    return;
  // if switch should be turned on
  if ( swstate == 1 ) {
    // if protocol is of type 2
    if ( swprot == 2) {
      // store values as INTs
      int swunit = root["unit"];
      int swident = root["ident"];
      // pass values to RCSwitch
      mySwitch.switchOn(swunit, swident);
    // if protocol is of type 1
    if ( swprot == 1) {
      // store values as const char*
      const char* swunit = root["unit"];
      const char* swident = root["ident"];
    // everything below this is redundant or debug stuff
  // if switch should be turned off
  } else {
    if ( swprot == 2) {
      mySwitch.switchOff(swunit, swident);
    if ( swprot == 1) {
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // this is the topic we're listening to
      client.subscribe("home/action/rfbridge");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  yield();
s4nder
#29 Post by s4nder » 07 Mar 2017, 17:41
oisisi wrote:
01 Mar 2017, 21:00
Ill try to see if I can get any logic in the plugin to support dip switches. But for now, my time is limited.
Does anyone know how to publish scripts to the Github repository (or playground or wherever)? I always get this message when syncing: 'Sync failed to push local changes, it seems you do not have permission to push your changes to this repository'... :?
Any developers here willing to share some knowledge on this?
paxi
#30 Post by paxi » 08 Mar 2017, 12:52
I'm not very versed with github but generally you fork into your own repo online, submit your commit(s) to that and then file a pull request against the original repo.
Minims
#31 Post by Minims » 22 Mar 2017, 21:31
Hi s4nder,
Thx for code, it works well for me.
I've made a pull request on ESPEasyPluginPlayground to integrate your plugins.
Minims
#32 Post by Minims » 23 Mar 2017, 19:01
s4nder
#33 Post by s4nder » 23 Mar 2017, 22:51
Strange, I tried to upload them a few days ago and the files where there for a few hours. Now i still can't find them. Why are they removed? :?
ipua
#34 Post by ipua » 14 Apr 2017, 14:48
s4nder,
First of all thanks for your RF Tx/Rx plugins - works great!
Can you add to your Plugin 111: Input RF option to receive data from Livolo switches based on this arduino scetch?
I am using OpenHab and many of rc-switch compatible devices plus Livolo switches in my house, so it will be very convinient to control them.
As of today I am using arduino connected to serial port of ESP for this purpose.
I think that many other ESPEasy users will be happy to use this option.
Thanks in advance,
Igor
annakin
#35 Post by annakin » 21 Apr 2017, 17:56
When I try to compile u plugin i have error:
'irReceiver' was not declared in this scope
on this line:
s4nder
#36 Post by s4nder » 24 Apr 2017, 09:56
@ipua; I think it would be better if someone would create a new plugin for that. This plugin only supports the RC-switch library.
@annakin; Also use the _P035_IRTX.ino and _P016_IR.ino plugins, then it will work.
I tried to make a newer version that can control Tristate/ Dip Switch/ Intertechno swithes. But, I do not have any hardware to test this, so can someone test this for me? :roll:
You can view the latest plugins on my github page: https://github.com/sanderpleijers/EspEasy-RC-Switch
psy0rz
#37 Post by psy0rz » 24 Apr 2017, 11:16
We also have another rcswitch plugin on the playground? anyone knows whats going on with that?
https://github.com/letscontrolit/ESPEas ... -Switch-TX
Please support ESPEasy development via Patreon or buy us a coffee.
s4nder
#38 Post by s4nder » 25 Apr 2017, 09:41
@psy0rz; verry good question, I did not see that until now! It is not of my making... Code looks a wee bit shorter that what I stamped together... :lol:
I cannot say that my version is better or not, I barely have time to code everything... Ill leave that to you pro-coders ;)
Mics78
#39 Post by Mics78 » 15 May 2017, 08:27
Hi s4nder!
Thank you for your plugin.
Unfortunately, ESPEasy crashes with it. I think it is rcswitch issues. I use version 2.52.
Could you send me link for library you use?
trs
#40 Post by trs » 15 May 2017, 13:06
I use this RC-Switch plugin from playground to send RF commands to my DIP-coded RF power outlets, works great!
it can send
  • binary code with any length ("RC,SEND=000000000001010100010001")
  • tristate code with any length ("RC,SEND=00000FFF0F0F")
  • 24 bit decimal code ("RC,SENDDEC=5393")
  • binary code for simple 10 DIP switch devices ("RC,ON=1010100010")
  • switch position for simple 2 rotary switch devices ("RC,ON=42")
  • switch position for Intertechno devices ("RC,ON=a42")
[/list]
s4nder
#41 Post by s4nder » 16 May 2017, 15:10
@Mics78; I used rc-switch 2.6.2 (straight from github) together with the ESP-easy mega dev8 release. That works for me...
@trs: Your code looks great, my own code is kinda messy with conversions/variables but for me it works. What I really use from my own code is that I can save the pulselength or repeats in the settings so you don't have to worry about that anymore.
It seems to me that lots of people want this functionality in ESP-Easy, can we somehow kindly inform the developers to include these plug-ins in upcoming ESP easy (mega?) releases?
toffel969
#42 Post by toffel969 » 16 May 2017, 17:29
s4nder wrote:
16 May 2017, 15:10
+1
Mics78
#43 Post by Mics78 » 23 May 2017, 19:40
Thank you.
I try to use rc-switch 2.6.2 with Arduino IDE 1.8.1 and 1.8.2 and receive an compilation's error:
C:/users/michael/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\Michael\AppData\Local\Temp\arduino_build_252850/ESPEasy.ino.elf section `.text' will not fit in region `iram1_0_seg'
collect2.exe: error: ld returned 1 exit status
If I return 2.5.2 version I have no error compilation but I have reboots my device...
I need receiver functionality in ESPEasy...
s4nder
#44 Post by s4nder » 31 May 2017, 16:19
@Mics78; remove some un-needed plugins from the ESP-Easy source. The error you get means that the firmware is too big...
ManS-H
#45 Post by ManS-H » 02 Jun 2017, 11:35
Hello All,
I've a question. Can i use this plugin for a stand alone version of Vhome Smart Home RF433MHZ Switch Shape Smart Remote Control in combination with ESP Easy, RfxCom and Domoticz?
Or did i need extra hardware for this unit?
https://nl.aliexpress.com/item/Vhome-Sm ... Title=true
oisisi
#46 Post by oisisi » 05 Jun 2017, 18:35
I am now using "Plugin 144: RC-Switch TX" from the plugin playground together with the current Mega release. It works nicely with my dip switch and rotary type sockets. Regrettably, I can't get it to work with MQTT so I have to to issue get requests (e.g. http://192.168.4.151/control?cmd=RC,ON=1000010000,5).
If anyone knows the proper topic and syntax to publish the command I would be even more happy. I've tried all thinkable variations of topics and payloads (e.g. 'mosquitto_pub -t "home/esp014/cmd" -m "RC,ON=1000010000,5"' while the module is subscribed to "home/esp/#") but nothing happens.
ipua
#47 Post by ipua » 06 Jun 2017, 08:18
I am using openhab and items file contains:
 mqtt=">[broker:/ESP1/cmd:command:on:rfsend,1111111],>[broker:/ESP1/cmd:command:off:rfsend,22222222]
In your case - try 'mosquitto_pub -t "home/esp014/cmd" -m "rfsend,1000010000,5"
Hope this helps..
oisisi
#48 Post by oisisi » 07 Jun 2017, 19:11
ipua wrote:
06 Jun 2017, 08:18
Hope this helps..
Regrettably this and variants thereof don't work. My device is named "rcswitch" so I tried `mosquitto_pub -t "home/esp014/cmd" -m "rcswitch,ON=1000010000,5"` - no dice. I think a command beginning with 'rc' is expected:
    case PLUGIN_WRITE:
        String command = parseString(string, 1);
        if (command == F("rc"))
          String param;
          byte paramIdx = 2;
          string.replace("  ", " ");
          string.replace(" =", "=");
          string.replace("= ", "=");
I guess I have to stick to GET requests. :(
JKD
#49 Post by JKD » 10 Jun 2017, 10:56
All command names are independent of the task names. To trigger the RCswitch you have to use the command "RC".
-> "RC,ON=1000010000,5" should work
Note: commands are only be executed on enabled tasks.
oisisi
#50 Post by oisisi » 13 Jun 2017, 17:57
JKD wrote:
10 Jun 2017, 10:56
Thanks for the advice. Regrettably it doesn't work. I can see that the payload arrives in the log:
shows up in the log as
375247309 : MQTT : Topic: home/esp014/cmd
375247309 : MQTT : Payload: RC,ON=1000010000,5
But nothing happens.
While the get request
wget -qO- "http://192.168.178.151/control?cmd=RC,ON=1000010000,5"
appears in the log as
375429728 : on=1000010000
375429728 : ON
375429728 : 1000010000
375430269 : 5
and the switch is toggled.
