¶m bug on rules
¶m bug on rules
Even with the latest firmware remains the bug with the word "¶m" which is converted to ¶m.
You may not be able to correct it?
Re: ¶m bug on rules
Yes, please, it will be fine to send alerts to Domoticz, instead of waiting 5 minutes for a device refresh...
Re: ¶m bug on rules
It seems that if ¶ is shown somewhere in a webform, the ¶ is interpreted as the HTML escape sequence for a paragraph sign, looking like a backwards P.
I don't know where it should be fixed and it's possible that it does not occur on all browsers.
But there's a workaround for this particular bug: Use the ¶m as the first name-value pair in the URL so it becomes ?param and it will no longer be misinterpreted.
Example:
change this:
sendtohttp 192.168.0.8,8080,/json.htm?type=command¶m=udevice&idx=286&svalue=%eventvalue%
into:
sendtohttp 192.168.0.8,8080,/json.htm?param=udevice&type=command&idx=286&svalue=%eventvalue%
So we've just changed the order in which the url is build up.
Example:
change this:
into:
Re: ¶m bug on rules
Thanks Martinus, no more bad characters!
Re: ¶m bug on rules
Thanks Martinus, cool
Users browsing this forum: No registered users and 161 guests
