Switch rules
Jufo
Switch rules
#1 Post by Jufo » 16 Mar 2017, 22:56
I'm currently using this configuration:
on SwitchAOn do
   gpio 16,0
   inputswitchstate 14,1
on SwitchAOff do
   gpio 16,1
   inputswitchstate 14,0
on SwitchBOn do
   gpio 12,0
   inputswitchstate 13,1
on SwitchBOff do
   gpio 12,1
   inputswitchstate 13,0
on SwitchA#switch do
   if [SwitchA#switch]=1
      event SwitchAOn
      event SwitchAOff
on SwitchB#switch do
   if [SwitchB#switch]=1
      event SwitchBOn
      event SwitchBOff
It works, but it needs to turn on or off the relay with every change of position of the physical switch (no matter if this is a state from 1 to 0 or 0 to 1), it can be done?
Thanks,
Robert
paxi
Re: Switch rules
#2 Post by paxi » 16 Mar 2017, 23:36
Sure.
Create a new switch device (i. e. Name RelayA, valuename state) with gpio 16 as input.
Rule:
On switchA#switch do
  If [RelayA#state]=0
    Gpio 16,1
  Else
    Gpio 16,0
  Endif
Similar for your second switch/relay of course.
You may need to delete the "inputswitchstate" commands if you call the first 4 events remotely. Or omit them at all and just use the gpio command from outside.
Jufo
Re: Switch rules
#3 Post by Jufo » 16 Mar 2017, 23:45
I do not quite understand, my configuration:
GPIO-14 = SwitchA
GPIO-16 = RelayA
GPIO-13 = SwitchB
GPIO-12 = RelayB
paxi
Re: Switch rules
#4 Post by paxi » 16 Mar 2017, 23:50
I know. Just try it. ;)
The new "pseudo" switch stores the status of the relay which my suggested rule then uses to toggle it.
Jufo
Re: Switch rules
#5 Post by Jufo » 16 Mar 2017, 23:59
I've tested, unfortunately, it does not work properly. He falls into a loop when, they try to turn off.
paxi
Re: Switch rules
#6 Post by paxi » 17 Mar 2017, 00:00
See my edit above re inputswitchstate.
Jufo
Re: Switch rules
#7 Post by Jufo » 17 Mar 2017, 00:08
I lost me at all, use remotely from domoticz and two physical buttons to control two relays. Can you give me the full code for Rules?
Thx
Robert
paxi
Re: Switch rules
#8 Post by paxi » 17 Mar 2017, 00:29
  If [RelayA#state]=0
    Gpio 16,1
  Else
    Gpio 16,0
  Endif
On switchB#switch do
  If [RelayB#state]=0
    Gpio 12,1
  Else
    Gpio 12,0
  Endif
Nothing else.
I don't use domoticz and therefore can't exactly advice how to reconfigure it.
Make only the pseudo switches send data to the controler so it knows if the relays are on or off, untick "pullup" in task settings, enter an IDX and reboot the esp. Use the gpio command to switch the relays from the controler.
The general idea is to use the relay state instead of the switch state for the whole control logic.
Jufo
Re: Switch rules
#9 Post by Jufo » 17 Mar 2017, 08:56
Your script (Rules) only works properly when you turn on the relay. It does not work turn off (another change of state the switch).
paxi
Re: Switch rules
#10 Post by paxi » 17 Mar 2017, 10:11
It works for me. This is my switch setup:
Jufo
Re: Switch rules
#11 Post by Jufo » 17 Mar 2017, 13:44
I use bistable switch
paxi
Re: Switch rules
#12 Post by paxi » 17 Mar 2017, 14:28
Then select "normal switch". ;)
Jufo
Re: Switch rules
#13 Post by Jufo » 17 Mar 2017, 23:02
But I have already tested this configuration and it does not work. Maybe something is wrong, tomorrow it will analyze ...
Jufo
Re: Switch rules
#14 Post by Jufo » 18 Mar 2017, 15:25
I tested again, and unfortunately for me does not work :(
paxi
Re: Switch rules
#15 Post by paxi » 18 Mar 2017, 17:21
"It does not work" is not sufficient info to help. ;)
Post your complete setup:
-devices like above
-rules
-schematic of switches
-domoticz code
Describe exactly what happens when and preferably provide logs from the serial interface.
Jufo
Re: Switch rules
#16 Post by Jufo » 19 Mar 2017, 15:53
Rules based on your code:
On SwitchA#switch do
  If [SpeakersA#state]=0
    Gpio 16,1
  Else
    Gpio 16,0
  Endif
On SwitchB#switch do
  If [SpeakersB#state]=0
    Gpio 12,1
  Else
    Gpio 12,0
  Endif
Configuration ESP Easy:
Connection GPIO to switch:
Dual 5V Relay module (connected IN1 to GPIO16, IN2 to GPIO12):
paxi
Re: Switch rules
#17 Post by paxi » 20 Mar 2017, 01:20
"inversed" setting for SpeakersA switch is the culprit: value is 0 with gpio high and vice versa - this way the rules can't work. ;)
Jufo
Re: Switch rules
#18 Post by Jufo » 20 Mar 2017, 11:33
paxi wrote:
20 Mar 2017, 01:20
yes, but I have to be Inversed (Domoticz get the flag 0 is off)
paxi
Re: Switch rules
#19 Post by paxi » 20 Mar 2017, 21:29
Then change
to
If [SpeakersA#state]=1
Jufo
Re: Switch rules
#20 Post by Jufo » 20 Mar 2017, 21:43
I tested this version, but I only manage to turn on the relay, I can not turn it off.
paxi
Re: Switch rules
#21 Post by paxi » 20 Mar 2017, 22:15
I think there is something conflicting in domoticz.
But honestly: its no fun trying to help you - you didn't provide the information asked for (there is still no hint what you're doing in domoticz) and most of your replies are just "it didn't work".
Again: it works perfect for me in standalone
Jufo
Re: Switch rules
#22 Post by Jufo » 20 Mar 2017, 22:30
I try as I can :) Domoticz allows remote control buttons with Easy ESP, commands, respectively:
Amp / Speakers A
On Action: http://192.168.3.120/control?cmd=GPIO,16,0
Off Action: http://192.168.3.120/control?cmd=GPIO,16,1
Amp / Speakers B
On Action: http://192.168.3.120/control?cmd=GPIO,12,0
Off Action http://192.168.3.120/control?cmd=GPIO,12,1
Your Rules does not want to work off (changing any state of the physical button when the relays are on does not turn them off)
Thank you for your support and patience.
paxi
Re: Switch rules
#23 Post by paxi » 20 Mar 2017, 22:58
I've overlooked that your relays are active low - my mistake. Anyhow it should work with the latest code.
But:
Earlier you wrote "bistable switch" now "physical button". Different things and a momentary button (opposed to a toggle switch) needs to be configured as pushbutton (active low from your schematic).
Jufo
Re: Switch rules
#24 Post by Jufo » 20 Mar 2017, 23:07
I'm sorry for my mistake
I use the physical bistable button/switch (press this button in this position)
paxi
Re: Switch rules
#25 Post by paxi » 20 Mar 2017, 23:40
It's still unclear what you mean:
- toggle switch
- momentary pushbutton
- latching pushbutton
Jufo
Re: Switch rules
#26 Post by Jufo » 22 Mar 2017, 12:08
I use toggle switch (on/off) for example:
paxi
Re: Switch rules
#27 Post by paxi » 22 Mar 2017, 22:28
Hmm, I've just noticed you configured speakersA to send boot state but it is default (and thus possibly undefined) in the hardware page. Set the gpio to the desired output state but I'm not sure it will help.
Another test is to disconnect espeasy from domoticz (i. e. with a non-valid conroller IP) and check if the rule works locally.
In all your testing you should update the devices page after each action and carefully observe the values. More info can be obtained from the log, best is via serial since the weblog is rather short.
