Good afternoon..
I have tried to start using the ESP Easy, and when trying to install the firmware through Arduino IDE .. I showed these errors and I can not find duplicate libraries. I appreciate your help..
Sincerely.
---------ERRORS FROM ARDUINO IDE ------------
Se encontraron múltiples librerías para "Servo.h"
Usado: /Users/gustavocastro/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/Servo
No usado: /private/var/folders/1p/x693p8v53w7f7l991fjk0vy40000gn/T/AppTranslocation/97F15350-F716-4F02-A501-3D07F667AE7D/d/Arduino.app/Contents/Java/libraries/Servo
Se encontraron múltiples librerías para "SD.h"
/Users/gustavocastro/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: /var/folders/1p/x693p8v53w7f7l991fjk0vy40000gn/T/arduino_build_141352/ESPEasy.ino.elf section `.irom0.text' will not fit in region `irom0_0_seg'
Usado: /Users/gustavocastro/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/SD
collect2: error: ld returned 1 exit status
No usado: /private/var/folders/1p/x693p8v53w7f7l991fjk0vy40000gn/T/AppTranslocation/97F15350-F716-4F02-A501-3D07F667AE7D/d/Arduino.app/Contents/Java/libraries/SD
First firmware UPLOAD ERROR during compile , libraries
Re: First firmware UPLOAD ERROR during compile , libraries
I had the exact same error, solved it by changing the flash size.
The IDE defaults to 512kb/64 SPIFFS, i changed it to 4M/3MSPIFFS. (I'm using ESP-12)
Good Luck..
Good Luck..
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 127 guests
