Hi to all,
I've been playing around with "rules" to trigger an event within ESP8266.
Although I can get the rule to trigger by sending the following URL, I can't work out what I should do in Node-Red to achieve the same result.
http://192.168.1.31/control?cmd=event,triggerme
I've pulled out nearly all my hair trying various combinations in Node-Red.
I would appreciate it if anyone can share with me what I should put in the MQTT send node.
Kind regards from David.
Trigger an event using Node-Red
- dynamicdave
Re: Trigger an event using Node-Red
have u considered MQTT ?
If u have NR running, u can easily setup a mosquitto broker in the same machine, then use MQTT pubs in NR and Mqtt import in Espeasy.....
Paolo
Paolo
I think dynamicdave has MQTT as he's asking it how to configure an output MQTT node
here it is th answer:
topic = /<ESPEasy module name>/cmd
payload = "event,<event name>"
- dynamicdave
Thanks for your responses.
I do already have MQTT running on a Raspberry Pi with Node-Red on another RPi.
I'll try out your answer this evening.
Thanks for all your help/advice.
David.
David.
- dynamicdave
Thanks for your help.
Your answer works like a "dream" - thanks.
I must have tried loads of combinations in the MQTT syntax but not the one you suggested.
Cheers from DynamicDave
my pleasure to be able to help you
Users browsing this forum: Ahrefs [Bot] and 154 guests
