Two OLED SSD1306 on one ESP8266
Re: Two OLED SSD1306 on one ESP8266
Okay, understand.
So how is the procedure?
Should somebody start an issue and/or a pull request on github? (I have no idea what is correct and how to do this exactly)
Who can fix it?
Thanks and best regards,
Chris
Who can fix it?
Chris
i have a simple quick fix, which makes 2 displays work, but that fix has the side effect that the screen goes black for a second, every time the screen refreshes... i am not sure if i will pull this, because it better would be a complete rewrite based on the same library which is uses for the framedOLED display..
if you are able to compile youself you can fetch my draft from my github fork: https://github.com/krikk/ESPEasy ...this one works with 2 oled displays, only thing broken is the oled commands...
+1 for thatkrikk wrote: ↑14 Jun 2017, 22:26 i have a simple quick fix, which makes 2 displays work, but that fix has the side effect that the screen goes black for a second, every time the screen refreshes... i am not sure if i will pull this, because it better would be a complete rewrite based on the same library which is uses for the framedOLED display..
It's better to re-develop the display plugins based on one library.
Anything new with this issue?
I still want to use more then one display.....
I'm also waiting for it
Any news on this?
Here having exactly the same issue as Shardan described at viewtopic.php?p=16423#p16423.
Two LCD2004 via I2C and different adresses, just one works.
How to differentiate between both LCD's through the LCD-command?
regards,
ao16
regards,
ao16
We're working super hard for a stable and focus 100% on core issues and don't want to introduce new features until then. A stable is out very soon.
Thanks for this info and promising outlook, grovkillen
- budman1758
You can use a workaround. If you use the "framed" OLED and a regular OLED at the same time that works fine. As long a they are on different I2C addresses then it works no problem. Have a couple units doing it for some time now.
Users browsing this forum: No registered users and 47 guests
