on my NodeMCU i use GPIO 0 (D3) connected to a door switch. If the door is closed GPIO 0 is connected to ground.
Everything works fine.... but in the case that GPIO 0 is connected to ground and the node reeboots (power failure...) it dosn´t start.
I first have to disconnect the contact from ground and reconnect the power that it boots again and i can use it.
Has anybody the same problem or can help me?
Andreas
Problems with Restarting while Gpio 0 is connected to Ground
Re: Problems with Restarting while Gpio 0 is connected to Ground
Please read here: https://www.letscontrolit.com/wiki/inde ... figuration
During boot GPIO 0 need to be HIGH (1).
Users browsing this forum: No registered users and 125 guests
