I used EasyESP version 2.00 and connected a DHT22 to D4 (GPIO 2). Due to the reason that the sensor in the bedroom I would like to globally disable the blue LED. I already saw and forum entry saying that in order to disable the blue led I have to set D4 to low.
Unfortunately this is not possible because the DHT22 is connected to this port and unforunately this was the only port I found where I don't need a resistor.
Does anyone have an idea to how I could disable the blue blinking led.
BR Moria8
Disable blue LED
Re: Disable blue LED
Remove the diode?
i solved this with pliers blinking leds in a sleeping room are annoying...
Keep things easy...
I'd just put a little piece of black duct tape on the led...
The led is usefull sometimes for diagnostics so i wouldn't want to remove it or otherwise "kill" it.
Usually the problem doesn't occur often with an ESP in a closed case.
Users browsing this forum: Bing [Bot] and 16 guests
