electric pulse count to domoticz
alexswart
#1 Post by alexswart » 18 Jun 2017, 23:20
i have in my house an old electric meter with a rotatingwheel,
my wheel rotates 600 times for 1 kw
i have the hardware part ready but i dont know how i setup it in ESPEasy
i make a sensor pulse counter and bekome 3 values
Count
Total
Time
witch value do i set in espeasy to show it correct in domoticz?
i hope someone can help me
Re: electric pulse count to domoticz
#2 Post by grovkillen » 19 Jun 2017, 06:08
I use Delta/Count as type. You then need to use the formula: %value%/600 in you case to make the pulses into kW.
Depending on the delay your ESP Easy will report how many kW has been used during that time (Delta).
alexswart
#3 Post by alexswart » 19 Jun 2017, 07:12
Is that formule for count, total or time?
#4 Post by grovkillen » 19 Jun 2017, 08:50
Count (as I tried to state in my previous post "Delta/Count").
Delta is the new Count as of 2.0.0 (when it is released).
alexswart
#5 Post by alexswart » 19 Jun 2017, 18:01
thank you
what kind of formule do you have for time and total?
#6 Post by grovkillen » 19 Jun 2017, 18:22
What do you need them for? Total is the total pulses since last power cut and reboot. Time is the total time (I think) of the pulses. I don't use them myself.
If you want to use Total you use the same formula as for Count.
Martinus
#7 Post by Martinus » 19 Jun 2017, 19:22
Use the incremental counter in Domoticz and the Delta setting in ESP Easy.
Domoticz is a single value counter device so you can only send one value...
alexswart
#8 Post by alexswart » 19 Jun 2017, 22:50
So it is not possible to calculate the time between the pulses to the actual consumtion and the count for the total watts ? Like a p1 cabel can?
#9 Post by grovkillen » 19 Jun 2017, 23:09
If you lets say have the delay for 60 seconds between the reports you could use the Count (aka Delta) with this formula to present consumption (speed) in kWh:
%value%/600*60
Thus
%value%/100
But this is only momentary consumption, not the true value since that need to take the Watts used during 1 hour. Not a snatched value. So report the Watts as suggested in the first post I wrote and do the sum on the Domoticz side.
alexswart
#10 Post by alexswart » 19 Jun 2017, 23:35
But the actual usage must normaly calculate by the time between the pulses or do i have it wrong? Is it possible to send that to domoticz?
alexswart
#11 Post by alexswart » 18 Sep 2017, 20:24
is there already another solution to monitor my electric meter with esp-easy and domoticz?
alexswart
#12 Post by alexswart » 18 Sep 2017, 20:25
with actual usage calculated on time between the pulses?
alexswart
#13 Post by alexswart » 19 Sep 2017, 21:00
Nobody?
olleman
#14 Post by olleman » 04 Oct 2017, 13:57
I have the same question. I use incremental counter in Domoticz and Delta in ESPEasy. Have only ran it a couple of hours but it seems to give me the correct usage for each hour.
BUT I too want to have the momentary value as well to be able to see what my house uses in just this instant. I have tried all the meters in Domoticz and non of the others seems to give me correct readings...
,Olle
kimot
#15 Post by kimot » 12 Oct 2017, 22:24
But calculate the time between the pulses is not actual usage. It is usage between last two pulses only.
With heavy load, its close to actual usage, but less power - less actuality of data.
Imagine what happens, when power goes to zero. Sensor wait for last pulse, wait, wait, wait ....
You never know in first seconds ( minutes ) , that power is zero now.
rkoppen
#16 Post by rkoppen » 13 Oct 2017, 07:56
Have you looked at Plugin 112 in the playground ?
I believe this is what you are looking for.
https://github.com/letscontrolit/ESPEas ... _Power.ino
TommySharp
#17 Post by TommySharp » 30 Apr 2018, 05:34
How do we use the plugins that are not part of the standard version?
Flying Domotic
#18 Post by Flying Domotic » 05 Sep 2019, 09:36
Not so sure to fully understand initial request, but I'll try to bring my 2 cents: As this is Domoticz, and it saves last time you wrote a value, I would suggest writting a small script that save last value, computes current value - last value/current time - last stored time to get the average consumption within the interval.
