Serial MCU controlled relay/switch
Re: Serial MCU controlled relay/switch
#151 Post by grovkillen » 17 Jun 2018, 13:46
Look at the wiki for the Sonoff Touch.
#152 Post by grovkillen » 17 Jun 2018, 13:48
countcobolt
#153 Post by countcobolt » 17 Jun 2018, 13:59
Heyhey
Looking further : would I be able to use this to flash it? Looked at the above link, but don't have a 3.3 + GND on the print.
Would I be able to solder on the chip
https://docs.tuya.com/en/hardware/WiFi- ... e-mcu.html
pin 16/15 and 12 for comms and 8 and 9 to put 3.3V on it?
Kind regards
Steve
countcobolt
#154 Post by countcobolt » 17 Jun 2018, 14:32
and don't bother going any further, I just literally burned some of the traces... To be honest, crappy PCB :( :( :(.
Still have a Sonoff Touch 2-gang to go with
Kind regards
Steve
desprueht
#155 Post by desprueht » 17 Jun 2018, 15:40
I have a LCTech Relay X4 board. I installed ESPEasy on the ESP-01 (ESPEasy_1M_128kSPIFFS_PUYA.zip) and the first two relays are in function, but the last two relays are not contolled.
What can I do to use all four relays?
I would like to control with HTTP commands:
HTTP commands:
Relay 0 Off: http://ESP_IP/control?cmd=relay,0,0
Relay 0 On: http://ESP_IP/control?cmd=relay,0,1
Relay 1 Off: http://ESP_IP/control?cmd=relay,1,0
Relay 1 On: http://ESP_IP/control?cmd=relay,1,1
Relay 2 Off: http://ESP_IP/control?cmd=relay,2,0
Relay 2 On: http://ESP_IP/control?cmd=relay,2,1
Relay 3 Off: http://ESP_IP/control?cmd=relay,3,0
Relay 3 On: http://ESP_IP/control?cmd=relay,3,1
Who can help me?
enesbcs
#156 Post by enesbcs » 17 Jun 2018, 15:46
desprueht wrote:
17 Jun 2018, 15:40
I have a LCTech Relay X2 board. I installed ESPEasy on the ESP-01 (ESPEasy_1M_128kSPIFFS_PUYA.zip) and the first two relays are in function, but the last two relays are not contolled.
I've never seen a 4 relay version, can you provide me the link or the datasheet, to find out what serial commands needed to operate it?
desprueht
#157 Post by desprueht » 17 Jun 2018, 15:53
Relay control instructions (hex hexadecimal):
Open the first relay: A0 01 01 A2
Turn off the first relay: A0 01 00 A1
Open the second relay: A0 02 01 A3
Close the second relay: A0 02 00 A2
Open the third relay: A0 03 01 A4
Turn off the third relay: A0 03 00 A3
Open the fourth relay: A0 04 01 A5
Turn off the fourth relay: A0 04 00 A4"
and the link:
http://www.chinalctech.com/index.php?_m ... &p_id=1288
countcobolt
#158 Post by countcobolt » 17 Jun 2018, 16:13
Hi all
sorry is this is a stupid question, but will your firmware work with the Sonoff T1 2Gang (similar to the dual?). I both 2 and want to be able to control them using ESPEasy and Domoticz.
Kind regards
Steve
enesbcs
#159 Post by enesbcs » 17 Jun 2018, 20:24
countcobolt wrote:
17 Jun 2018, 16:13
This plugin will not work with any Sonoff T1. According to Tasmota wiki:
"When pushing a button, the touch chip lift the power high to the EFM8BB1, and the EFM8BB1 chip ties the signal line for each button low, for the full duration of the keypress. There is no serial data, that i have seen at all."
The device's operation is somewhat obscure to me, i am using my own T1 2Gang with Tasmota without problmes. :)
enesbcs
#160 Post by enesbcs » 17 Jun 2018, 22:44
desprueht wrote:
17 Jun 2018, 15:53
and the link:
Ok the commands seems consistent, i expanded the plugin to support 4 relay, now it can be selected in plugin options.
countcobolt
#161 Post by countcobolt » 18 Jun 2018, 08:39
enesbcs wrote:
17 Jun 2018, 20:24
countcobolt wrote:
17 Jun 2018, 16:13
Hey Enesbcs
do you use the web or MQTT component for this? (On Tasmota)
Kind regards
enesbcs
#162 Post by enesbcs » 18 Jun 2018, 15:15
countcobolt wrote:
18 Jun 2018, 08:39
I am using the Tasmota MQTT with Sonoff T1, works perfecty with my Domoticz server.
desprueht
#163 Post by desprueht » 18 Jun 2018, 17:41
enesbcs wrote:
17 Jun 2018, 22:44
desprueht wrote:
17 Jun 2018, 15:53
and the link:
Download and try: v23
Hi, thank you very much for your work.
I have a problem with the webinterface. when i click on Devices and add a Serial MCU controlled switch, then I can't edit the device. The ESP-01 makes a restart.
enesbcs
#164 Post by enesbcs » 18 Jun 2018, 19:05
desprueht wrote:
18 Jun 2018, 17:41
You're right... i left out one index, and ESP did not honor buffer overflow. :)
Try the updated binary.
desprueht
#165 Post by desprueht » 18 Jun 2018, 21:22
enesbcs wrote:
18 Jun 2018, 19:05
desprueht wrote:
18 Jun 2018, 17:41
It's so wunderfull. Thank you for all...
Whitey
#166 Post by Whitey » 04 Aug 2018, 12:13
Very new to all this so forgive me.
Had one of these laying around as it was useless in its original state. Managed to flash the firmware and get it working.
I wish to use it to control a garage opener that only requires a momentary switch. Is it possible to do that with this?
Have tried the pulse command but had a feeling it wound not work and I was correct.
At the moment I have a script setup in home assistant that turns the off after 1 second but find this is more like 2 or 3 seconds. The script is a very crude way to do what I want so was hoping for a better solution.
enesbcs
#167 Post by enesbcs » 04 Aug 2018, 17:15
Whitey wrote:
04 Aug 2018, 12:13
What device? This plugin supports some kind from Lctech, Tuya, S.Dual.. be a little more specific. I think it can be done with EspEasy rules.
Whitey
#168 Post by Whitey » 04 Aug 2018, 22:01
enesbcs wrote:
04 Aug 2018, 17:15
Sorry about that, referring to the 12v LC Tech single channel relay (same one as the post at 116)
enesbcs
#169 Post by enesbcs » 05 Aug 2018, 09:52
Whitey wrote:
04 Aug 2018, 22:01
I see. You have to enable rules in Espeasy advanced settings, then if the serial device name is "lc" and the first relay named as "Relay0" (default) then the code below switches off the relay one seconds after switched on. It has to work, if somehow not, then i will ty to implement it inside the plugin.
on lc#Relay0>0 do
 timerset,1,1
on Rules#Timer=1 do
 relay,0,0
Whitey
#170 Post by Whitey » 05 Aug 2018, 10:08
enesbcs wrote:
05 Aug 2018, 09:52
Whitey wrote:
04 Aug 2018, 22:01
on lc#Relay0>0 do
 timerset,1,1
on Rules#Timer=1 do
 relay,0,0
Will give it a go when I get home in an hour or so.
Thanks heaps
Whitey
#171 Post by Whitey » 05 Aug 2018, 11:33
Can't get it to work. Relay still just turns on or off as if there are no rules.
Will have a play with the rules and see if I can get something working tho
enesbcs
#172 Post by enesbcs » 05 Aug 2018, 14:21
Whitey wrote:
05 Aug 2018, 11:33
Check v2:
on lc#Relay0 do
 if [lc#Relay0]>0
  timerset,1,1
on Rules#Timer=1 do
 relay,0,0
or v3:
on lc#Relay0 do
 timerset,1,1
on Rules#Timer=1 do
 if [lc#Relay0]>0
  relay,0,0
And see what EspEasy logs says..
Whitey
#173 Post by Whitey » 06 Aug 2018, 02:23
Will give V2 and v3 a try and watch the logs.
I assume the rules don't need to be enabled anywhere else in the settings to enable them? Just enable rules in advance settings then create the rule for them to work.
Thanks for for assistance and patience so far.
Whitey
#174 Post by Whitey » 06 Aug 2018, 12:12
Update.
Managed to get it working with your first code. Appears sleep and reading instructions correctly kinda help.
I had my device named Relay and say you had it name lc. A simple change in name fixed it.
Sorry for the stuff up my end.
Thanks heap in helping me out here.
Is it possible to reduce the time to less than 1 second? I will have a read and see if I can find the answer myself but just in case I fail again.
fyi all 3 rules work and give the desired result
enesbcs
#175 Post by enesbcs » 06 Aug 2018, 17:23
Whitey wrote:
06 Aug 2018, 12:12
Great news, you are welcome.
In rules one second is the smallest interval as i know.
I think i can implement a new command in the plugin for example "relaypulse" for smaller intervals, but due to the characteristics and speed of the serial connection the results will not be as you expect. I have an LCTech relay somewhere hidden in my shelf, will try it and publish the plugin if it can handle it.
Whitey
#176 Post by Whitey » 06 Aug 2018, 23:51
enesbcs wrote:
06 Aug 2018, 17:23
Whitey wrote:
06 Aug 2018, 12:12
Thanks for the offer but no need to worry if it isn't currently supported. This is just a test device I had laying around while I learnt the ropes. Have ordered some sonoff low voltage boards to use as the garage control runs off 24V DC and this test board is a 12v board so I will be using a power pack while I test.
Thanks again for your help. It was very much appreciated.
oleost
#177 Post by oleost » 22 Aug 2018, 21:12
Hi.
Anyone sucessfully used this on the "ESP8266 4CH 12V WiFi" found on aliexpress ?
https://www.aliexpress.com/wholesale?ca ... H+12V+WiFi+
enesbcs
#178 Post by enesbcs » 16 Sep 2018, 22:10
oleost wrote:
22 Aug 2018, 21:12
I do not own this model, but according to this description:
https://www.aliexpress.com/item/4CH-ESP ... 90810.html
it is controlled by the standard LCTech serial commands (A0 01 01 A2...) which is supported by this P165 plugin. Also the onboard ESP-01 may require the 1MB Puya safe binary.
Btje
#179 Post by Btje » 17 Oct 2018, 07:50
Looking for the tuya dimmer in EU format but can't find a place to buy. Any tips?
riker1
#180 Post by riker1 » 27 Oct 2018, 18:24
having this modul attached to fhem via espbridge
How can I switch the relay?
do int it at the moment via wget
but isn't there a option via esp module fhem?
enesbcs
#181 Post by enesbcs » 27 Oct 2018, 21:18
riker1 wrote:
27 Oct 2018, 18:24
How can you execute any ESPEasy command via fhem? You can use exactly the same way the relay command, mentioned at the first post of this thread. I am using relay command via HTTP and within RULES.
I am not familiar with FHEM, but with MQTT there are a third way:
<MQTT subscribe template>/cmd with payload: <command>
I think you can do it with creating some virtual switches inside ESPEasy that can be controlled by FHEM controller and maintains the changes with specific RULES.
riker1
#182 Post by riker1 » 28 Oct 2018, 11:34
thanks
good idea via mqtt
fahrt
#183 Post by fahrt » 13 Nov 2018, 21:52
enesbcs wrote:
18 Jun 2018, 19:05
desprueht wrote:
18 Jun 2018, 17:41
Hello. I was looking for firmware to control LCTech 4ch board and I've found this forum. Unfortunetly above link is not working anymore :( . Could you attach file once again.
enesbcs
#184 Post by enesbcs » 13 Nov 2018, 21:56
fahrt wrote:
13 Nov 2018, 21:52
As always, you can find the compiled binaries attached to the first post in this thread. Try the PUYA safe binary if you are not sure which one is for your ESP-01.
fahrt
#185 Post by fahrt » 14 Nov 2018, 21:08
enesbcs wrote:
13 Nov 2018, 21:56
fahrt wrote:
13 Nov 2018, 21:52
I've flashed with "ESPEasy_Mega_P165_1M_128kS_lwip20_PUYA.bin" but This one works only with 2 relays
enesbcs
#186 Post by enesbcs » 14 Nov 2018, 21:47
fahrt wrote:
14 Nov 2018, 21:08
enesbcs wrote:
13 Nov 2018, 21:56
fahrt wrote:
13 Nov 2018, 21:52
Sorry, i left out the Puya binary, i forgot that previous version is not capable to handle 4ch. :)
Try this:
ESPEasy_Mega_P165_1M_128kS_lwip20_PUYA.zip
ESPEasy dev with P165
(388.99 KiB) Downloaded 1583 times
fahrt
#187 Post by fahrt » 15 Nov 2018, 20:07
enesbcs wrote:
14 Nov 2018, 21:47
fahrt wrote:
14 Nov 2018, 21:08
enesbcs wrote:
13 Nov 2018, 21:56
Try this:
Thank You for the file I'll test it on weekend :)
fahrt
#188 Post by fahrt » 22 Nov 2018, 19:25
fahrt wrote:
15 Nov 2018, 20:07
enesbcs wrote:
14 Nov 2018, 21:47
fahrt wrote:
14 Nov 2018, 21:08
Try this:
I've tested it and works great :D, many thanks. There are little delays but probably because i use HTTP commands to control it by Domoticz.
enesbcs
#189 Post by enesbcs » 22 Nov 2018, 22:03
fahrt wrote:
22 Nov 2018, 19:25
You are welcome. Maybe you can try faster serial speed, some device can be used at 115200 baud. Some can not. :)
Also disable command doubling if device works without it. Anyway, Wifi devices have some delays basically.
riker1
#190 Post by riker1 » 04 Dec 2018, 20:37
using latest firmware,
but FHEM is not available as controller?
Could you make a version with Fhem enabled in controller list?
OpenHAB MQTT and FHEM would be perfect
Thanks T
enesbcs
#191 Post by enesbcs » 04 Dec 2018, 21:23
riker1 wrote:
04 Dec 2018, 20:37
Thanks T
Yes i can. 4MB version will be OK?
riker1
#192 Post by riker1 » 04 Dec 2018, 22:07
thanks
perfect,
No i would need a small version for esp01S
LC TEch with 2 relays
Thanks a lot T
enesbcs
#193 Post by enesbcs » 05 Dec 2018, 19:15
riker1 wrote:
04 Dec 2018, 22:07
Thanks a lot T
OpenHab+FHEM included
riker1
#194 Post by riker1 » 05 Dec 2018, 19:19
Thanksgiving perfekt
riker1
#195 Post by riker1 » 06 Dec 2018, 00:20
could you please double check.
Do not see FHEM as Controller?
Thanks Thomas
Firmware
Build 20102 - Mega
Libraries ESP82xx Core 2_4_0, NONOS SDK 2.1.0(deb1901), LWIP: 2.0.3
GIT version (custom)
Plugins 11 [Normal]
Build Md5 4d44355f4d44355f4d44355f4d44355f
Build time Dec 5 2018 18:55:03
Binary filename ThisIsTheDummyPlaceHolderForTheBinaryFilename64ByteLongFilenames
enesbcs
#196 Post by enesbcs » 06 Dec 2018, 20:27
riker1 wrote:
06 Dec 2018, 00:20
Yep, sorry i forgot, that i not just deleted the file, but removed my pluginset completely before.
Recompiled.
ESPEasy_P165.zip
ESPEasy P165 1MB
(781.87 KiB) Downloaded 344 times
riker1
#197 Post by riker1 » 06 Dec 2018, 22:07
thanks, perfect, working now!!
xonecell
#198 Post by xonecell » 06 Jan 2019, 17:24
Hello, I have LC Tech relay x2 12v, I followed post #138 on installing ESP Easy (ESPEasy_1M_128kSPIFFS_PUYA.zip)
Everything works, MQTT, HTTP, and I can hear the switch clicking when turning it on or off, but I am not getting any output voltage from both relays, what could be the cause? This is the second board I have bought already, the first one burned(https://www.aliexpress.com/item/12V-WIF ... 34092.html) and I dont want to order another one, any ideas? Thanks
enesbcs
#199 Post by enesbcs » 06 Jan 2019, 18:08
xonecell wrote:
06 Jan 2019, 17:24
If the relay clicks the works.. my first idea is: the 12V power supply is weak to power the relays, try with larger, 1A,2A...
Second thought: Check soldering points of the relays at the back side, resolder them if necessary - of course check NO/NC with a multimeter previously.
mikeoh90
#200 Post by mikeoh90 » 23 Feb 2019, 20:36
Is there a way to use this with the 4x channel LC Tech relay? Works on my 2ch version, but the only option in 'number of relays' is 1 or 2.
Users browsing this forum: No registered users and 63 guests
