hello all,
I'm new with espeasy and whould like to send a http message (DHT11 temperature) to my jeedom server.
The classic message in jeedom is something like this :
http://192.168.1.15/core/api/jeeApi.php ... emperature%
may i use the SendToHTTP function ?
like this ?
SendToHTTP 192.168.1.15,80,/json.htm?/core/api/jeeApi.php?apikey=y7pcfIMvcGffk0hNff1dLtvFJNjpSOff&type=virtual&id=48&value=%Temperature%
What is the correct syntax ?
In reality i just want to send this http message from the ESP !
I also tried a
on TEMP1 (using rules)
http://.... or SendToHTTP ?
EndOn
Thanks for your help
SendToHTTP usgae ?
Re: SendToHTTP usgae ?
Did you find a solution @cdx ?
I have the same problem, I was hoping that a publish would do the job.
This is my exact (api key changed) working syntax for posting temp and humidity values to thingspeak
On Thermometer#Temperature do
SendToHTTP,api.thingspeak.com,80,/update?api_key=XXXXXXXXXXXXXXXXXXXX&field1=[Thermometer#Temperature]&field2=[Thermometer#Humidity]
https://thingspeak.com/channels/33034
-D
-D
-D
You can include the [name#value] syntax in the URL also.
For example:
SendToHTTP example.com,80,api/add/single?id=%mac_int%&long=[gps#long]&lat=[gps#lat]&co2=[S8#co2]
So hostname,port,rest_of_url
See also the documentation: https://espeasy.readthedocs.io/en/lates ... sendtohttp
Please note that we currently do not support https url's
For example:
I'm not a big fan to hard code a API key in an espeasy (no offense to the team !).
I'm using Lunorak's plugin for espeasy (using http general). I prefer to avoid the usage of a different plugin on the jeedom side.
TD-er provided a solution with taskrun
Thanks again for the feed back
Users browsing this forum: Bing [Bot] and 46 guests
