Ping Plugin
Neutrino
Ping Plugin
#1 Post by Neutrino » 13 Oct 2017, 08:12
Hello everybody,
In my Home automation system, a wemos reboots my raspberry in case of crash.
I made a plugin which pings an IP address.
I use the ESP8266Ping library. https://github.com/dancol90/ESP8266Ping
Here the plugin :
//#################################### Plugin 085: Ping  ################################################
#define PLUGIN_085
#define PLUGIN_ID_085         85
#define PLUGIN_NAME_085       "Ping Device"
#define PLUGIN_VALUENAME1_085 "Ping"
#include <ESP8266Ping.h>
boolean Plugin_085(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  static byte switchstate[TASKS_MAX];
  static byte outputstate[TASKS_MAX];
  char deviceTemplate[1][41];    // variable for saving the subscription topics
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_085;
        Device[deviceCount].VType = SENSOR_TYPE_SINGLE;
        Device[deviceCount].ValueCount = 1;
        Device[deviceCount].GlobalSyncOption = true;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_085);
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_085));
    case PLUGIN_WEBFORM_LOAD:
        LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
          addFormTextBox(string, String(F("IP ")), String(F("Plugin_085_template")), deviceTemplate[0], 40);
        success = true;
    case PLUGIN_WEBFORM_SAVE:
        String argName;
          argName = F("Plugin_085_template");
          strncpy(deviceTemplate[0], WebServer.arg(argName).c_str(), sizeof(deviceTemplate[0]));
         success = true;
    case PLUGIN_READ:
        String AdrIp;
      //  Loop over all tasks looking for a 085 instance
      for (byte y = 0; y < TASKS_MAX; y++)
          if (Settings.TaskDeviceNumber[y] == PLUGIN_ID_085)
            LoadCustomTaskSettings(y, (byte*)&deviceTemplate, sizeof(deviceTemplate));
            // Now loop over all import variables and subscribe to those that are not blank
              AdrIp = deviceTemplate[0];
        int Parts[4] = {0,0,0,0};
        int Part = 0;
        for ( int i=0; i<AdrIp.length(); i++ )
          char c = AdrIp[i];
          if ( c == '.' )
            Part++;
            continue;
          Parts[Part] *= 10;
          Parts[Part] += c - '0';
        IPAddress ip( Parts[0], Parts[1], Parts[2], Parts[3] ); // The remote ip to ping
        String log = F("Ping ");
        bool ret = Ping.ping(ip);
        log += AdrIp;
        log += " state ";
        log += ret;
        addLog(LOG_LEVEL_INFO,log);
        UserVar[event->BaseVarIndex] = ret;
        event->sensorType = SENSOR_TYPE_SWITCH;
        success = true;
  return success;
You are free to use it, edit it, improve it ;)
Jeff
Re: Ping Plugin
#2 Post by Jeff » 13 Oct 2017, 22:13
It's a WOL function :?
Neutrino
Re: Ping Plugin
#3 Post by Neutrino » 13 Oct 2017, 23:01
Jeff wrote:
13 Oct 2017, 22:13
No, just ping (icmp), not a WOL function. ;)
I use it with a dummy and rules.
If 10 pings fail, it resets my raspberry with a relay.
Re: Ping Plugin
#4 Post by grovkillen » 13 Oct 2017, 23:05
Aaah, and you could also have a ESP Easy unit ping Google DNS server (8.8.8.8) and see if the internet connection is working. If not, kill the power to your router for a sec and reboot it. Will try!
Wouldn't mind this being a part of the main code. Will you propose that on GitHub?
lyndondr
Re: Ping Plugin
#5 Post by lyndondr » 06 Oct 2018, 00:20
Is this going to be added to the build?
I'd like to setup a ESP Easy outlet to detect if the internet connection is down and if it is power off the router for a few seconds and then turn back on.
Is this possible with the current mega builds?
I see in the system info there is a web traffic output but I havn't found the details of what it is tracking and it seems to reset and I don't know why.
Re: Ping Plugin
#6 Post by grovkillen » 06 Oct 2018, 10:38
I haven't seen the request on GitHub. Maybe you could open one?
Re: Ping Plugin
#7 Post by TD-er » 06 Oct 2018, 12:31
There is only one minor thing about using this ping library.
It will block execution of other code as long as it is waiting for a reply.
So if you combine this with plugins that really need some real-time behavior, data/connections will be lost when a ping is taking a long time to reply.
Re: Ping Plugin
#8 Post by grovkillen » 06 Oct 2018, 13:04
Ah, I now remember you telling me that way back. So we should somehow make blocking plugins/commands stand out so users understand that these are in fact blocking.
lyndondr
Re: Ping Plugin
#9 Post by lyndondr » 06 Oct 2018, 22:46
Anything else you can think of for my post?
Re: Ping Plugin
#10 Post by grovkillen » 06 Oct 2018, 23:11
lyndondr wrote:
06 Oct 2018, 22:46
It's not in the official repository so you first need to add a request for it to be merged/included. If you do that you will get notifications on any update on the matter.
lyndondr
Re: Ping Plugin
#11 Post by lyndondr » 07 Oct 2018, 01:21
I was wondering if there were any other ways to solve my problem without that type of plugin?
boby1
Re: Ping Plugin
#12 Post by boby1 » 07 Oct 2018, 02:52
Hello guys,
I am freshly starting my experience on ESP8266 and I plan for my first project to make a king of "reset plug" for my internet modem.
The idea is not new, but I did not find anywhere a ready to use solution for my ESP. The plugin you propose here may perfectly answer my need but I am stuck on compiling the firmware after adding the plugin.
--> Would you please help me, I would really appreciate if anyone could send me a compiled binary ? I wanted to do it with ESPeasy 2.0.0 for ESP8266 normal 4096.
Re: Ping Plugin
#13 Post by TD-er » 07 Oct 2018, 11:14
We can add it to the official repository, and later make it less blocking.
I just added it to the GitHub:
https://github.com/letscontrolit/ESPEasy/issues/1863
Neutrino
Re: Ping Plugin
#14 Post by Neutrino » 07 Oct 2018, 15:36
I'm very happy to see that !
I'm using it with an LCD 16x2 without any problem since 1 year. :)
etrubin
Re: Ping Plugin
#15 Post by etrubin » 13 Nov 2018, 11:33
Hi!
Pease help.
try to do but have an errors after adding this plugin.
P085_esp8266ping.ino: In function 'boolean Plugin_085(byte, EventStruct*, String&)':
_P085_esp8266ping:53:107: error: invalid conversion from 'char*' to 'int' [-fpermissive]
_P085_esp8266ping:53:107: error: too many arguments to function 'void addFormTextBox(const String&, const String&, const String&, int)'
\arduino-1.8.7\ESPEasy_mega-20181112\source\src\ESPEasy\WebServer.ino:3048:6: note: declared here
 void addFormTextBox(const String& label, const String& id, const String&  value, int maxlength)
Or maybe somebody can give compiled firmware to update by web?
Thank you
enesbcs
Re: Ping Plugin
#16 Post by enesbcs » 25 Nov 2018, 21:00
etrubin wrote:
13 Nov 2018, 11:33
Hi!
Pease help.
Thank you
Hi!
I rewrite Neutrino's plugin with using a non-blocking pinger library.
Some changes: only 3 ping device can be added, only IP address can be specified by entering all four octets as plugin parameters.
Source:
https://github.com/enesbcs/ESPEasyPlugi ... 6_Ping.ino
4M binary download
Wiki
Re: Ping Plugin
#17 Post by Wiki » 21 Mar 2019, 16:01
works pretty good, tested with the custom bin posted before.
I want to try to get more stability on four critical nodes concerning the WD timeout reboots following the recommendation of TD-er on github. On the device I want to use for continuous pings I need the max6675 plugin, too.
Is there any possibility to get a binary version which allows one more ping device, means four instead of three and which is based on the actual sources?
enesbcs
Re: Ping Plugin
#18 Post by enesbcs » 23 Mar 2019, 22:01
Wiki wrote:
21 Mar 2019, 16:01
New binary attached. UNTESTED! Use only your own risk.
(Prepare with some screwdrivers and soldering iron and serial-USB programmer, before using these binaries.)
Wiki
Re: Ping Plugin
#19 Post by Wiki » 24 Mar 2019, 12:11
you're the best. Pinging four devices works like a charme. Thank you.
Only thing thats missing now is the max6675.
enesbcs
Re: Ping Plugin
#20 Post by enesbcs » 24 Mar 2019, 16:03
Wiki wrote:
24 Mar 2019, 12:11
Temperature Thermocouple is already in these binaries. I do not know any other plugin that supports max6675...
mahodk
Re: Ping Plugin
#21 Post by mahodk » 24 Mar 2019, 16:24
Was this plugin ever added to the official release?
I have not been able to find it as a device in the device list on any of the precompiled firmwares.
- I do not mind if it is blocking other functions, key functionality would be to ping external server and toggle relay based on that.
If not included in a past release I guess I will have to take the plunge and learn how to compiler a custom version.
Any good tutorials on this? I have done a bit of Arduino work in the past, but I have very limited experience with compiling firmware.
Thanks for your help
mahodk
Wiki
Re: Ping Plugin
#22 Post by Wiki » 24 Mar 2019, 16:58
@enesbcs: "Temperature Thermocouple " doesn't work, there is no chip available to be chosen.
The plugin I was using before is named "Environment Thermocouple", there you get a dropdown to choose the chip.
But don't put too much efforts in it, I personally am fine with the four pings - you made my day, seriously. The max6675 would be more or less a nice-to-have.
Wiki
Re: Ping Plugin
#23 Post by Wiki » 24 Mar 2019, 17:02
mahodk wrote:
24 Mar 2019, 16:24
No, thats why I was asking for a modified binary. The plugin still is on playground. My coding skills are not sufficient either, even in the past I was not able to get a running environment to compile myself.
enesbcs
Re: Ping Plugin
#24 Post by enesbcs » 24 Mar 2019, 19:10
Wiki wrote:
24 Mar 2019, 16:58
No problem. It seems that you need the P039 plugin which is in fact located in the main ESPEasy repository. Recompiled.
update: I've just tried it on a D1 Mini and it is almost unusable.. (freezing, disconnecting) i reverted back to 2018.dec ESPEasy sources with core 2.4.1 and the device works OK. I guess core 2.5.0 is the reason.
ESPEasy_bin_20190311.zip
ESPEasy bin_unstable_core_250
(1.05 MiB) Downloaded 52 times
Wiki
Re: Ping Plugin
#25 Post by Wiki » 24 Mar 2019, 21:06
You're my hero, works. Thank you.
If you stay one time in DE just come along, I'll buy you a beer (or two).
enesbcs
Re: Ping Plugin
#26 Post by enesbcs » 25 Mar 2019, 10:17
Wiki wrote:
24 Mar 2019, 21:06
Thanks! :)
Finally i've succesfully compiled the same on the newest Core 2.6.0-dev which seems a lot more stable than previous "stable" 2.5.0.
ESPEasy.core260.zip
ESPEasy-dev-core_260
(1.05 MiB) Downloaded 105 times
Users browsing this forum: No registered users and 42 guests
