%sysday% not working?
rayE
#1 Post by rayE » 07 Nov 2017, 09:39
Hi All,
%systime% works OK and returns HH:MM:SS but i get nothing back with %sysday% or %sysmonth%
GIT version: v2.0.0-dev12
Triggered from timer1 in system boot. Rule below.
On Rules#Timer=1 do                                // When Timer1 expires, do
    GPIO,5,1                                              // Turn SerialIRQ ON
    $Time=%systime%                                 // Send this comment out to serial
    $Day=%sysday%                                    // Send this comment out to serial
    $Month=%sysmonth%                            // Send this comment out to serial
    Delay 100                                            // Delay 100mS
    GPIO,5,0                                             // Turn SerialIRQ OFF
    timerSet,1,10                                     // Set Timer 1 for the next event in 60 second
TIA
Ray
vader
Re: %sysday% not working?
#2 Post by vader » 07 Nov 2017, 11:17
Tested and works. Returns 07 and 11 today. See source code...
newString.replace(F("%sysname%"), Settings.Name);
newString.replace(F("%systime%"), getTimeString(':'));
newString.replace(F("%syshour%"), getHourString());
newString.replace(F("%sysmin%"), getMinuteString());
newString.replace(F("%syssec%"), getSecondString());
newString.replace(F("%sysday%"), getDayString());
newString.replace(F("%sysmonth%"), getMonthString());
newString.replace(F("%sysyear%"), getYearString());
newString.replace(F("%sysyears%"), getYearStringShort());
newString.replace(F("%uptime%"), String(wdcounter / 2));
rayE
#3 Post by rayE » 07 Nov 2017, 12:11
Hi Vadar,
Are you using v2.0.0-dev12?
Ray
vader
#4 Post by vader » 07 Nov 2017, 13:09
Yep. Self-compiled version with sources from GIT.
%sysday%.%sysmonth%.%sysyear%
HELLO
on OLED shows this:
rayE
#5 Post by rayE » 07 Nov 2017, 13:43
All that works on mine from the list above is............
sysname
systime
uptime
I have searched all the source files in V2.0.0 dev12 and can find no reference to the non working sys names. Is the code snippet you posted in the Misc.ino file?
Cheers
Ray
rayE
#6 Post by rayE » 07 Nov 2017, 13:46
AH self compiled version :-)
i don't suppose you could be a real star and share your compiled version with me? im a newby and have not gone down the "build road" yet. If you could id send you a "virtual" cold beer :-)
Ray
jjansen
#7 Post by jjansen » 07 Nov 2017, 14:48
Are you sure a date is present in the system? Is NTP-time enabled in settings?
rayE
#8 Post by rayE » 07 Nov 2017, 14:59
Yes NTP is enabled and i can get %systime%. I have searched all the source files in V2.0.0 dev12 and can find no reference to the non working sys names. Im guessing %sysdate% etc is supposed to be in Misc.ino file?
Ray
jjansen
#9 Post by jjansen » 07 Nov 2017, 16:32
Yes, misc.ino line 1726
https://github.com/letscontrolit/ESPEas ... .ino#L1726
But only submitted so long ago... https://github.com/letscontrolit/ESPEasy/pull/485
So I guess it is not included in your version.
vader
#10 Post by vader » 07 Nov 2017, 18:36
jjansen wrote:
07 Nov 2017, 16:32
1. That's the same as I already posted in #2!
2. How would you explain, that it works with my version from GIT? See #4
3. You wrote: Are you sure a date is present in the system? Is NTP-time enabled in settings?
Read #1: %systime% works OK and returns HH:MM:SS
You should read all posts first before answering!
jjansen
#11 Post by jjansen » 07 Nov 2017, 20:35
vader wrote:
07 Nov 2017, 18:36
jjansen wrote:
07 Nov 2017, 16:32
Oh, I did.
1. rayE responded to that with
Apparently it is not in his source files.
2. I guess rayE uses the dev12 release downloaded from https://github.com/letscontrolit/ESPEas ... .0.0-dev12. You use the last source from github?
3. Fair enough, just to be sure...
vader
#12 Post by vader » 07 Nov 2017, 21:31
Yep, that's the same source I compiled my version from. It's in the Misc.ino, as you already know... ;)
rayE
#13 Post by rayE » 07 Nov 2017, 23:56
Thanks for the help from you BOTH. I will go down the "build" road today and fix the issue.
@ Vandar, Having never used GTI or compiled my own version of ESP Easy the question i posted may have seemed DUMB but we have all been there at one point, correct!
Anyway thanks again.
Ray
adval40
#14 Post by adval40 » 08 Nov 2017, 00:39
I have found my problem
i didn't have the mega version
rayE
#15 Post by rayE » 08 Nov 2017, 08:29
Well i went down the build path and followed the instructions exactly................Atom/Platformio is the MOST BUGGY and HORRIBLE installation i have EVER performed (Win7 64). It took 3 attempts before it "felt" like it "may" be working, Even the uninstall procedure is pretty "wild". BUT after much swearing and at least 6 computer "CRASHES" and 4 hours it now somehow seems to work and i just performed my first successful build :-)
And by the way i now have the system vars i was originally looking for. If anyone wants a copy of the build 2.0.0 V12_Normal_4096 with the added system vars then just ask.
Ray
bthome
#16 Post by bthome » 20 Nov 2017, 18:41
rayE wrote:
08 Nov 2017, 08:29
Ray
@rayE Would appreciate a link to your build or your best instructions on how to build. Would be nice if this could be put together in a Docker. :-)
#17 Post by TD-er » 20 Nov 2017, 19:32
In my experience it is best to disable the virusscanner during install of PlatformIO
speedie
#18 Post by speedie » 23 Nov 2017, 11:35
Ray can you share your working copy of the build 2.0.0 V12?
