Plugin_153 MAX44009, anyone got it working ?
costo
#1 Post by costo » 23 Dec 2017, 17:19
I have a GY-49 module , it has a MAX44009 lux sensor. I found playground plugin_0153 and gave it a try.
So compiled ESPEasy 148 with plugin153. But the sensor does not show_up in the device list.
Did someone succesfully use this sensor in ESPEasy?
Re: Plugin_153 MAX44009, anyone got it working ?
#2 Post by grovkillen » 23 Dec 2017, 19:16
Please make sure that the plugin is not #def as testing or development.
costo
#3 Post by costo » 23 Dec 2017, 21:36
@grovkillen
tnx for the suggestion.
I removed at beginning the line:
#ifdef PLUGIN_BUILD_TESTING
and on the end of plugin the line
#endif
Apparently the plugin was ignored at first, now I get some compile errors like:
_P153_MAX44009.ino: In function 'boolean Plugin_153(byte, EventStruct*, String&)':
_P153_MAX44009:130: error: 'addFormSelector' was not declared in this scope
_P153_MAX44009:158: error: 'getFormItemInt' was not declared in this scope
I will see if I can fix the errors.
costo
#4 Post by costo » 26 Dec 2017, 14:35
Since a few days plugin 153 basically works for me in ESPEasy148.
To get rid of these 2 compile errors:
I had to comment out these 6 lines
In case PLUGIN_WEBFORM_LOAD
 addFormSelector(string, F("Mode"), F("plugin_153_mode"), 3, options, optionValues, choice_mode)
 addFormSelector(string, F("Current Division Ratio"), F("plugin_153_divide"), 2, options, optionValues, choice_division);
 addFormSelector(string, F("Integration Time"), F("plugin_153_time"), 8, options, optionValues, choice_time);
and in case PLUGIN_WEBFORM_SAVE:
 Settings.TaskDevicePluginConfig[event->TaskIndex][0] = getFormItemInt(F("plugin_153_mode"));
 Settings.TaskDevicePluginConfig[event->TaskIndex][1] = getFormItemInt(F("plugin_153_divide"));
 Settings.TaskDevicePluginConfig[event->TaskIndex][2] = getFormItemInt(F("plugin_153_time"));
wihout these lines the plugin basically works, gives me the lux value with 22bit definition, much better than a BH1750 sensor.
Apparently because I removed the 6 lines from the WEBFORM LOAD/SAVE part, the "Optional Settings" form in the device tab does not function anymore. I cannot use the "Formula Lux" because what is put there is not processed or saved.
Which is sad, because I would like to put there something like %value%^0.1 so that the values communicated to my RaspberryPi based Domoticz server are displayed logarithmic, just like the eye is logarithmic.
I am not used to programming with plugins, so I am not sure how to fix this.
Any clues would be appriciated a lot.
#5 Post by TD-er » 28 Dec 2017, 11:40
Why stick to the build 148, when you can also use the 2.0 dev series, or even the Mega branch?
costo
#6 Post by costo » 30 Dec 2017, 00:29
TD-er wrote:
28 Dec 2017, 11:40
I will try that asap.
Maybe the errors will disappear then.
costo
#7 Post by costo » 30 Dec 2017, 14:17
I tested the MAX44009 plugin in dev2.0 but ...
No difference, same 6 errors as with the old version 148.
There are some omissions somewhere in the sketch or the plugin. I think i must declare the string variables somewhere somehow.
I was hoping someone who has written a plugin before could see the solution and explain what needs to be changed/added.
costo
#8 Post by costo » 30 Dec 2017, 14:57
Tested dev 2.0 again with this MAX44009 plugin, but now with the latest sources from github, also latest libraries.
The compile errors disappeared :P
But . . . . . . . still cannot edit the formula field, everything entered there disappears after clicking "submit" , so it is not saved.
costo
#9 Post by costo » 30 Dec 2017, 19:34
Finally solved it.
The solution was in this post viewtopic.php?f=6&t=3689&p=20157&hilit=formula#p20157
The problem was not in the software nor in the plugin. It was the ESP8266 2.4.0.rc2 core.
When I used the 2.4.0.rc1 core I could save my optional settings agian. :P
Yeah, it took some time to find it out. :(
data
#10 Post by data » 30 Mar 2018, 19:15
Any idea, when Plugin #153 / support for MAX44009 will be added to the release?
danilodb
#11 Post by danilodb » 07 Feb 2019, 12:51
Hi everyone! Sorry to revamp an old thread, but this seems to be the only one concerning MAX44009 (plugin153).
I have updated firmware on my ESP8266 and found that this plugin is not yet there (ESPEasy Mega dev).
Has anybody any new about this? I can't find it in offcial plugin list and seems just to be vanished.
Thanks for any help.
Domosapiens
#12 Post by Domosapiens » 07 Feb 2019, 22:31
Is part of the playground
https://github.com/letscontrolit/ESPEas ... Playground
So you have to add it to your own compilation.
You could request to add it to the mega here:
https://github.com/letscontrolit/ESPEas ... +is%3Aopen
This will help: http://ko-fi.com/GrovkillenTDer
Users browsing this forum: Bing [Bot] and 20 guests
