Store string values for plugin settings [SOLVED]
jodur
#1 Post by jodur » 07 Jan 2018, 22:19
I cant find any examples in the current plugins how to provide the user with a texbox where he can fill in a string (api key for example).
I am able to add the textboxes with
 (addFormTextBox(string, F("Unit ID remote 1"), F("ID1"), Test1, 10) )
to te device settingspage, but the current pluging settings doesn't support the storage for strings in the ExtraTaskSetting structure.
The only way i can think off seem to be to create a specific Plugin Settingstructure who is stores and retreive its value from the flash with:
String LoadFromFile(char* fname, int index, byte* memAddress, int datasize)
and
String SaveToFile(char* fname, int index, byte* memAddress, int datasize)
Any other suggestions how to store strings for plugin sensor settings?
[SOLVED jodur 10-1-2018]
I didn't wait for a answer, there isn't an seperate forum for developers where you could post this kins of questions, so i went on to implement my own method.
For the reference have a look at the source-file i have developed;https://github.com/jodur/ESPEASY_Plugin_ITHO
After editing the above comment i just saw another post that handles custom settings, who i could have used to store the string! :oops:
I should have used:
SaveCustomTaskSettings(event->TaskIndex, (byte*)&PLUGIN_145_ExtraSettings, sizeof(PLUGIN_145_ExtraSettings));
LoadCustomTaskSettings(event->TaskIndex, (byte*)&PLUGIN_145_ExtraSetting , sizeof(PLUGIN_145_ExtraSettings));
Users browsing this forum: No registered users and 127 guests
