Today I was surprised to discover that a P029 device switches it's gpio even when not enabled.
I checked the C002 plugin (which contains the P029 functionality) and it does not observe the enabled flag.
Is this a bug or as designed? If it is by design I think the enabled flag would best be removed from the settings webpage.
P029 MQTT helper works when disabled
Re: P029 MQTT helper works when disabled
Don't worry, it's just one of the many bugs.... Can you compile your own version? Then I can give you the solution....
Not yet, but I am going to try so I can learn more about espeasy.
It is not a bug that bothers me very much but my first idea would be to add it to C002.ino, is that the correct place?
Removing it from the settings webpage is no good idea. The solution is in fact in _C002. The first riddle you solved!
Perhaps something worth a new issue on the githubs?
I have no account on github. Maybe there is already an issue opened there....
I've just added an issue. Thanks for your help.
Users browsing this forum: Bing [Bot] and 130 guests
