Own idx, rules and domoticz
Re: Own idx, rules and domoticz
I agree with cyberclwn, the spaces are the problem, not the rule itself. Two events seems easier for the use case, that's why I suggested it... it works because it also doesn't have spaces
Yes, you are right. It works if there are no spaces in the command. Thanks for your help. I appreciate that!cyberclwn wrote: ↑02 Apr 2018, 23:19I think this rule works, if you remove the spaces:On my own rules i noticed that espeasy is very picky on "useless" space in lines.Code: Select all
on Gas#Switch do // Task Gas which reads GPIO-13 (D7) if [Gas#Switch]=1 // If status Switch = 1 gpio,14,1 // Statusled GPIO-14 (D5) aan else gpio,14,0 // Statusled GPIO-14 (D5) uit endif endon
I known you solved it with other rules, but thought i try explain why what you tried is not working.
For future rules
Strange that spaces are allowed when I tested in de commandline (Tools, Command) and not in the rule... I tested my thoughts over there.
I learned my lesson!
Users browsing this forum: No registered users and 127 guests
