I've set up a Sonoff basic using an MQTT output helper (P029) to switch the relay on GPIO12 and a switch input on that same GPIO to monitor the status and act upon it in rules.
If I switch GPIO12 using the GPIO command an event Relay#Switch is triggered because the input device changed state.
However, if the GPIO is set by the Output helper, the event does not occur. It seems the logic behind the GPIO command and the P029 action is not the same (where I think it should be).
MQTT Output helper acts different from GPIO command
Re: MQTT Output helper acts different from GPIO command
ESPeasy is too stupid to do an event processing (no rule is processed!) after receiving an MQTT command. That's the reason why _P029 exists as a "helper"...
Thanks, too bad but good to know. I will search for a workaround (or use http).
I had another look at the code of plugin _C002. It looks like I can easily trigger rulesprocessing from there (saw an example in one of the other plugins).
I will compile my own version of ESPEasy and see if that is working.
Users browsing this forum: No registered users and 120 guests
