How send switchcmd=On to Domoticz?
ekrzychoooo
#1 Post by ekrzychoooo » 24 Jan 2018, 00:37
I have rules:
On sw0#Switch do
SendToHTTP 192.168.0.87,8080,/json.htm?type=command&param=switchlight&idx=22&switchcmd=On
In Domoticz log:
Admin initiated a switch command (22/GAZ/on)
It not working.
When I send from browser:
http://192.168.0.87:8080/json.htm?type=command&param=switchlight&idx=22&switchcmd=On
In Domoticz log is:
 User: Admin initiated a switch command (22/GAZ/On)
It work OK.
How send "On" not "on" from rules?
wim16
Re: How send switchcmd=On to Domoticz?
#2 Post by wim16 » 24 Jan 2018, 09:50
It can be done the way you did (and I think it actually does because you write it is in the Domoticz log).
But why not us a Domoticz HTTP (or MQTT) controller to do it for you? Than you do not need the rule.
Edit: I see I did not read well. Your problem is about the 'On'. Still, using a controller will fix that.
Edit2: I just tested (using v2.0-20180124) and it does send exactly the string I entered, no change in capitals or whatever.
ACT  : SendToHTTP 192.168.178.230,8080,/json.htm?type=command&param=switchlight&idx=71&switchcmd=On
2018-01-24 10:13:57.536 User: Admin initiated a switch command (71/Test/On)
ekrzychoooo
#3 Post by ekrzychoooo » 24 Jan 2018, 14:48
When I flashing this version : ESP_Easy_v2.0-20180124_normal_ESP8266_1024.bin work OK
When I flashing this version : ESP_Easy_v2.0-20180124_test_ESP8266_1024.bin Does not work properly. Sends "on" instead "On"
Ineed test version because I use a buzzer.
Users browsing this forum: No registered users and 106 guests
