Android app for esp easy
mahima2md
#1 Post by mahima2md » 05 Feb 2018, 12:10
Hi, I'm new for home automation. i successfully flash node mcu with ESP Easy . now i want to control it with my android phone via app.so can any one suggest me stable app or method to doing so.
thanks in advance.
Re: Android app for esp easy
#2 Post by grovkillen » 05 Feb 2018, 13:01
Best possible approach is to use MQTT as communication and the app MQTT Dash to create a tile design just as you want it.
papperone
#3 Post by papperone » 05 Feb 2018, 21:07
Well once you have MQTT broker on a local server (RaspberryPi being the cheapest) I'll advice to go for NodeRed which has a very nice extension to easily build up GUI via WebPages not having to know any language (if you are skilled with java and/or angular you can make awesome things then :) ).
mahima2md
#4 Post by mahima2md » 06 Feb 2018, 09:26
thank you for replay
is it possible that i can use old android phone as local serve with out using RaspberryPi ?
#5 Post by grovkillen » 06 Feb 2018, 09:38
You could try this one:
https://play.google.com/store/apps/deta ... r.com.mqtt
Haven't used it myself though
kniazio
#6 Post by kniazio » 06 Feb 2018, 16:32
You do not understand.
I control EasyEsp via the HTTP Request Shortcuts application
https://play.google.com/store/apps/deta ... cuts&hl=pl
It is sensational.
#7 Post by grovkillen » 06 Feb 2018, 16:36
kniazio wrote:
06 Feb 2018, 16:32
It is sensational.
That's only one way communication though.
mahima2md
#8 Post by mahima2md » 08 Feb 2018, 07:15
can anyone give me explanation about how to do this using that app?
is i need to make wifi access point in my phone and connect node mcu to that access point then connect phone into internet via 4g or connect Mcu and phone to my router?
#9 Post by grovkillen » 08 Feb 2018, 07:19
What app specifically are you talking about?
mahima2md
#10 Post by mahima2md » 08 Feb 2018, 07:45
#11 Post by grovkillen » 08 Feb 2018, 07:50
Maybe contact the developer of that app?
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
