Task Settings - Delay vs Interval
whatsupskip
#1 Post by whatsupskip » 28 Feb 2018, 07:49
Just started using ESP Easy and I was confused by the field name "delay" in the Task Settings section. After some reading of the wiki it became clear what was meant by the term "delay".
I believe for reasons of clarity, the field name should be "Interval", rather than "Delay".
It is possible that a sensor reading has both an interval (frequency at which the reading is taken) and a delay (the time between the sensor being turned on and the actual reading being taken).
Re: Task Settings - Delay vs Interval
#2 Post by grovkillen » 28 Feb 2018, 08:59
Yes that makes more sense. Possible to add an issue on git?
7keys
#3 Post by 7keys » 28 Feb 2018, 09:57
is it possible ...
espeasy -> sleep mode (300s) ->wakeup-> read value temperature -> value = 38 -> esp sleep (300s)
wakeup -> read value temperature -> value = 38 -> not send to mqqt, no enable wifi - because there is no change in the sensor reading -> esp sleep mode (300s)
this setting is to save a maximum of battery.
whatsupskip
#4 Post by whatsupskip » 28 Feb 2018, 10:27
7keys wrote: 28 Feb 2018, 09:57 espeasy -> sleep mode (300s) ->wakeup-> read value temperature -> value = 38 -> esp sleep (300s)
I understand this.
7keys wrote: 28 Feb 2018, 09:57 wakeup -> read value temperature -> value = 38 -> not send to mqqt, no enable wifi - because there is no change in the sensor reading -> esp sleep mode (300s)
I understand this, but I don't understand how you would configure it to do this. Also there will be situations where this isn't a good idea. That is the reading may not have been the same, but the reading was not received because of a comms issue or something else.
I am not sure what any of this has to do with the field name though.
7keys
#5 Post by 7keys » 28 Feb 2018, 10:40
it has nothing to do.
but I thought that someone might know how to do it .. in espeasy.
example:
print("#"..i.."\t"..sid.."\currenttemperature: "..curtemp.."\lasttemperature: "..(lasttemp / div))
        rtcmem.write32(i,(curtemp * div))
        if (curtemp * 1) == (85 * 1) then bug85 = true end
       [b] if (curtemp * 1) ~= (lasttemp / div) then[/b]
            update = true
the problem is solved by reading the time of the last measurement..
ok sorry for leaving the topic thread.
