Just started using ESP Easy and I was confused by the field name "delay" in the Task Settings section. After some reading of the wiki it became clear what was meant by the term "delay".
I believe for reasons of clarity, the field name should be "Interval", rather than "Delay".
It is possible that a sensor reading has both an interval (frequency at which the reading is taken) and a delay (the time between the sensor being turned on and the actual reading being taken).
Task Settings - Delay vs Interval
Re: Task Settings - Delay vs Interval
Yes that makes more sense. Possible to add an issue on git?
is it possible ...
espeasy -> sleep mode (300s) ->wakeup-> read value temperature -> value = 38 -> esp sleep (300s)
wakeup -> read value temperature -> value = 38 -> not send to mqqt, no enable wifi - because there is no change in the sensor reading -> esp sleep mode (300s)
this setting is to save a maximum of battery.
I understand this.
I understand this, but I don't understand how you would configure it to do this. Also there will be situations where this isn't a good idea. That is the reading may not have been the same, but the reading was not received because of a comms issue or something else.
I am not sure what any of this has to do with the field name though.
it has nothing to do.I am not sure what any of this has to do with the field name though.
but I thought that someone might know how to do it .. in espeasy.
example:
print("#"..i.."\t"..sid.."\currenttemperature: "..curtemp.."\lasttemperature: "..(lasttemp / div))
rtcmem.write32(i,(curtemp * div))
if (curtemp * 1) == (85 * 1) then bug85 = true end
[b] if (curtemp * 1) ~= (lasttemp / div) then[/b]
update = true
the problem is solved by reading the time of the last measurement..That is the reading may not have been the same, but the reading was not received because of a comms issue or something else.
ok sorry for leaving the topic thread.
Users browsing this forum: Google [Bot] and 152 guests
