Need some help with a complex rule set...
mattlward
#1 Post by mattlward » 03 Mar 2018, 05:46
I am importing via MQTT the wind direction in degrees. I would like to take that number and display it as n,s,e or w. Eventually I will break them down even further. I have written rulesets before but this is way out of my skill set right now.
I have started with a dummy task and a set of rules. The dummy variable 1 does get the imported value from MQTT, but the ruleset never converts it to text. I see the event in the logs that does the first part and then nothing... basically anything 45 degrees of either side of a primary direction will be assigned the letter of that primary direction...
My MQTT variable is s2#Deg and I need to end up with TaskValueSet1,2,X on the display...
Here is the ruleset that I have started...
On s2#Deg Do
TaskValueSet,1,1,[s2#Deg]
 If [Dummy#Deg]>315
  Event,SetToNorth
 EndIf
If [Dummy#Deg]>225
 Event,SetToWest
EndOn
If [Dummy#Deg]>135
 Event,SetToSouth
EndOn
If [Dummy#Deg]>45
 Event,SetToEase
EndOn
If [Dummy#Deg]>0
 Event,SetToNorth
EndOn
If [Dummy#Deg]=0
 Event,SetToNorth
EndOn
//Below is events
On SetToNorth Do
 TaskValueSet1,2,N
EndOn
On SetToWest Do
 TaskValueSet1,2,W
EndOn
On SetToMed Do
 TaskValueSet1,2,S
EndOn
On SetToHigh Do
 TaskValueSet1,2,E
EndOn
Domosapiens
Re: Need some help with a complex rule set...
#2 Post by Domosapiens » 03 Mar 2018, 10:57
Check the pairs:
On ...EndOn
If ....EndIf
#3 Post by TD-er » 03 Mar 2018, 19:06
There is already some code for the Domoticz controller to convert degrees into 8 or 16 wind directions.
I think we could add that somewhere.
Can you make an issue for that? (on Github)
mattlward
#4 Post by mattlward » 04 Mar 2018, 00:21
@TD-er, I sure will.
#5 Post by grovkillen » 09 Mar 2018, 21:34
https://www.letscontrolit.com/wiki/inde ... onversions
This is now implemented... some of the examples are not yet live for float values (the result are integer at the moment but an update is taking place as I write this).
Enjoy and a big hats off for TD-er for bringing this to the formula toolbox! :)
mattlward
#6 Post by mattlward » 09 Mar 2018, 21:42
I must agree, it is working very well!
#7 Post by TD-er » 09 Mar 2018, 23:34
grovkillen wrote: 09 Mar 2018, 21:34 [...] for bringing this to the formula toolbox! :)
Not entirely for use in a formula.
A sensor can only output float values and these conversions do float (or int) to String.
This means you can still use them anywhere where you want to modify a string.
Like rules, Publish messages, OLED display, email notifications, etc.
The input for these conversions will probably be a sensor output, like "[bme#Temp]"
Users browsing this forum: No registered users and 141 guests
