If I have a dummy device configured as task 2 and I send the following command "http://192.168.1.121/control?cmd=TaskValueSet,2,2,10", should it not set the second slot of task 2 to value 10? It is not doing it...
I am running v2.0-20180228.
Need a quick sanity check... TaskValueSet...
Re: Need a quick sanity check... TaskValueSet...
Well, correct but that command is not accessible using http. See :
https://www.letscontrolit.com/wiki/inde ... _Reference
Create a rule with an event and call it by this syntax :
event,<eventName>=<eventValue>
- budman1758
Well, if your here at all methinks sanity left the room long ago for all of us.Need a quick sanity check
Users browsing this forum: No registered users and 35 guests
