Explanation of Rules Sets?
Hallo, I can't find any description of Rules Sets on wiki, can you help me?
There are four Sets of Rules, each for 2048 characters, can I use them all at the same time, or only one choosen Set is valid? I'd like to eliminate rules characters restriction (6K is fine for me).
I tried some tests, it seems that all Sets 'are working' together at the same time, but is it 'bug or feature', why in this case we have four Sets and not a 'big one'?
Thanks for explanation! :]
Re: Explanation of Rules Sets?
Think of them as pages in a book, they are only a way in keeping things organized and easily viewed. As of current code base they work all at the same time but optimization in the future might change this so that you need to activate them or something.
Thanks for this explanation, does it mean that there is overall character limit for all four sets 2048 characters or each set has 'own' limit?
2048 times 4. So you can have really large rules but the process time will be affected. More characters to go through means longer process time for the rules.
- budman1758
Each of the 4 pages can be up to 2048 characters for a total of 8192.
Thanks both of you, good news! :]
Maybe I can fit to 2048 limit now, when boolean logic in rules are possible, but I have to re-write it fully, after that I will see. But it's good to know that it's not necessary. Processing time does not metter in my case :]
You can also use shorter names for sensors and values. Every byte may help
A 6k rule set sounds interesting - would you mind to upload it?
Users browsing this forum: Ahrefs [Bot] and 48 guests
