Manual IP in ESPEasy
Is it possible to add a manual entry of the IP address, for example in the last four bytes of the firmware?
regards
regards
Regards, Freddy
Regards, Freddy
Re: Manual IP in ESPEasy
Please elaborate what you mean. Manual IP have been around for a long time.
- budman1758
Maybe wants to hardcode it into the firmware and compile it?
I know that manual IP addresses is possible for a long time.
My ask is to make it possible to correct the IP address in the compiled code, because AP does not always allow connection.
I do not know if I described it well
Regards, Freddy
Regards, Freddy
There are some default defines in the code (look for "#define DEFAULT_") which you can change.
There will be a change very soon to allow to have a separate file with all those defines you can use for your own compiles.
But if you set the IP as static in the config, it will always have that IP. Just make sure it isn't one from the range used by the DHCP server on your modem, or else you will experience other issues.
Note that when you cannot connect to the accesspoint, setting the IP to static doesn't make a difference, since it is still not connected to the network.
#define default it's good idea
I know about static IP address, My DHCP is starting from 192.168.0.10, and I have pool of 20 addresses.
I already have static addresses for printer, and scanner, so that's ... no problem
That's why I must change my address from 192.168.4.1 to 192.168.0.110 f.e .
Regards, Freddy
Regards, Freddy
That 192.168.4.xxx address is only for initial setup when you cannot yet connect to a network and the ESP thus acts as an accesspoint.
Then you can connect to it via your mobile (or laptop) and start initial setup of the ESP module.
I changed the initial address 192.168.4.xxx for my 192.168.0.110
I saved the settings I made reboot, but the address 192.168.4.xx is still active, and 192.168.0.110 is not working
Regards, Freddy
Regards, Freddy
The 192.168.4.x address in the code is only used when the ESP is an accesspoint for initial configuration.
When you want to set a fixed IP, do it through the web interface.
Thanks,
do I must to switch something to not work in AP mode, but it was visible in the router?
Regards, Freddy
Regards, Freddy
Users browsing this forum: No registered users and 130 guests
