Hi all,
I have various ESP's running with ESPEasy for tem reading but also for various domotica and this works great.
The current situation is like:
-ESP sends via UDP values to InfluxDB
-ESP Switches via IDX to Domoticz pusht
-HA Bridge the switches from Domoticz pushed to Alexa
- Grafana creates visuals like the link below.
Now i want to calculate the deltaT from 2 sensors (A-B=dT) and since Grafana cant do calculations over multiple queries it expects to see the values A & B in 1 string.
At this moment i write to Influx over UDP like:
The values coming from:
No i would require to have both values from 2 different sensors into 1 message to get the names and values of 2 different tasks.
I could create a second controller with UDP Push but what would be required to be able to create this string.
Below you see what values i would require.
Hope its a bit clear what i want to do and of course this is how it now looks like in Grafana
https://snapshot.raintank.io/dashboard/ ... 0A1i3LsIbu
Thanks,
Jerome
Multiple readings in 1 message via UDP > InfluxDB
Re: Multiple readings in 1 message via UDP > InfluxDB
Create dummy variable dT
Calculate this dT via rules from both others sensors and send dT to Influx?
Users browsing this forum: No registered users and 127 guests
