I experienced the high load 98% between 85 and 98
I disabled some sensors, having only 2 attached and one system info.
using: v2.0-2018012
there are events created for disabled sensors, why?
66514090 : EVENT: IP_04#IP_04=139.00
disabling controllers fhem and thingsspeak reduced load to 27%
any exerience what is driving the load?
Thanks T
load of esp too high?
Re: load of esp too high?
Very short delays on some sensors result in high loads. I found that for example pulse devices with delay under 10 second always gives high loads(even with controllers disabled). Do you have other sensors with very short delays?riker1 wrote: ↑08 Apr 2018, 11:02 Hi
using: v2.0-2018012
Thanks T
Note to wiki+Dev people:
We might need to add GUI warnings for settings that might cause issues... At least describe this on the wiki.
Users browsing this forum: Ahrefs [Bot] and 115 guests
