rule not triggering for distance SR04 (solved)
having a distance sensor attached
log is saying:
0843707 : EVENT: Dist_139#Dist_V=152.64
10844706 : SR04 : Distance: 151.78
10844707 : EVENT: Dist_139#Dist_V=151.78
device is defined: with value, also tried state. but as well no trigger
rule for event:
on Dist_139#Dist_V<100.00 do
GPIO,14,1
is not triggering?
what am I doing wrong?
Thanks T
log is saying:
rule for event:
GPIO,14,1
is not triggering?
Thanks T
Re: rule not triggering for distance SR04
Your rule test on values < 100 but the values in the log are all > 100 so it is correct the rule is not being executed.
thanks for checking,
of course I have values lower than 100
still rule not triggered.
any way to check if a rule is tiggered/passed? - debugging ?
rule and execution should show up in log, right?
like
: EVENT: Dist_139#Dist_V=6.03
4665343 : SR04 : Distance: 7.76
4665344 : EVENT: Dist_139#Dist_V=7.76
4666343 : SR04 : Distance: 7.34
4666344 : EVENT: Dist_139#Dist_V=7.34
4667342 : SR04 : Distance: 7.64
4667344 : EVENT: Dist_139#Dist_V=7.64
4668342 : SR04 : Distance: 7.66
4668344 : EVENT: Dist_139#Dist_V=7.66
4669342 : SR04 : Distance: 7.64
4669344 : EVENT: Dist_139#Dist_V=7.64
4670342 : SR04 : Distance: 7.50
4670344 : EVENT: Dist_139#Dist_V=7.50
4671342 : SR04 : Distance: 8.24
4671344 : EVENT: Dist_139#Dist_V=8.24
like
What if you leave out the condition in the on statement?
And what firmware do you use?
Rules are not easily tested indeed, you might change the loglevel to see if it shows more info.
do you mean :
on Dist_139#Dist_V do
GPIO,16,0
led 16 not triggered.
log does not say anything about GPIO command
did set loglevel to debug, but does not show me a hint.
using: mega-20180409
did switch on debug serial and see more
but only
RuleDebug: 100: dist_139#dist_v<100.00 do
RuleDebug: 101: gpio,16,0
but does not show execution of gpio command.
EVENT: Dist_139#Dist_V=125.34 Processing time:47 milliSeconds
HTTP : connecting to 192.168.0.9:8383
HTTP : closing connection
SR04 : Distance: 13.12
EVENT: Dist_139#Dist_V=13.12
RuleDebug Processing:rules1.txt
flags CMI parse output:
RuleDebug Processing:rules2.txt
RuleDebug Processing:rules3.txt
RuleDebug Processing:rules4.txt
EVENT: Dist_139#Dist_V=13.12 Processing time:49 milliSeconds
HTTP/1.1 200 OK
HTTP : Success
Content-Type: text/plain
Connection: close
Content-Length: 0
SR04 : Distance: 7.16
EVENT: Dist_139#Dist_V=7.16
EVENT: Dist_139#Dist_V=7.16 Processing time:47 milliSeconds
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
but only
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
also tried now using state with threshold.
values are correct, but rule still not executed....
is it maybe a problem upper lower letters?
SR04 : State 1
EVENT: Dist_139#Dist_V=1.00
RuleDebug: 100: dist_139#dist_v=1.00 do
EVENT: Dist_139#Dist_V=1.00 Processing time:47 milliSeconds
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
SR04 : State 0
EVENT: Dist_139#Dist_V=0.00
EVENT: Dist_139#Dist_V=0.00 Processing time:47 milliSeconds
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
SR04 : State 1
SR04 : State 1
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
SR04 : State 0
HTTP/1.1 200 OK
HTTP : Success
Connection: close
Content-Length: 0
SR04 : State 1
solved it.
looks like it was caused by some blanks in the ruleset.!!!!!
Thanks for helping
Thanks for helping
Users browsing this forum: Semrush [Bot] and 51 guests
